2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: Re: Problem booting vxWorks with base 7.0.4
From: "Johnson, Andrew N. via Core-talk" <core-talk at aps.anl.gov>
To: "Rivers, Mark L." <rivers at cars.uchicago.edu>
Cc: EPICS core-talk <core-talk at aps.anl.gov>, Michael Davidsaver <mdavidsaver at gmail.com>
Date: Thu, 4 Jun 2020 00:38:20 +0000
Hi Mark,
On Jun 3, 2020, at 7:29 PM, Mark Rivers <rivers at cars.uchicago.edu> wrote:
The problem was indeed related to that message.  Somehow this file in my base/configure/os got changed.  I changed it back:
diff --git a/configure/os/CONFIG_SITE.Common.vxWorksCommon b/configure/os/CONFIG_SITE.Common.vxWorksCommon
index 0b0654a..6a1d6bb 100644
--- a/configure/os/CONFIG_SITE.Common.vxWorksCommon
+++ b/configure/os/CONFIG_SITE.Common.vxWorksCommon
@@ -21,5 +21,5 @@ VXWORKS_VERSION = 6.9
# WIND_BASE is where you installed the Wind River software.
#WIND_BASE = /usr/local/vw/tornado22-$(ARCH_CLASS)
-WIND_BASE = /usr/local/vw/vxWorks-$(VXWORKS_VERSION)
+WIND_BASE = /usr/local/vw/vxWorks-6.9.4
#WIND_BASE = /ade/vxWorks/$(VXWORKS_VERSION)
Your “wrong” configuration is the APS Accelerator IOC’s “right” configuration and hence how the EPICS source code normally comes. If you can you might want to rename your old vxWorks-6.9 directory to something else to catch this sooner in case it happens again with another release; or just remove the original 6.9 tree completely and make that a soft-link to the newer release.
- Andrew
Complexity comes for free, simplicity you have to work for.
RE: Problem booting vxWorks with base 7.0.4 Mark Rivers via Core-talk
Re: Problem booting vxWorks with base 7.0.4 Michael Davidsaver via Core-talk
Re: Problem booting vxWorks with base 7.0.4 Mark Rivers via Core-talk
Prev: Re: Problem booting vxWorks with base 7.0.4 Mark Rivers via Core-talk
Next: [Bug 1881563] Re: Empty arrays have undefined behavior Andrew Johnson via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Next: RE: Problem booting vxWorks with base 7.0.4 Mark Rivers via Core-talk
ANJ, 04 Jun 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
