2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: RE: Problem booting vxWorks with base 7.0.4
From: Mark Rivers via Core-talk <core-talk at aps.anl.gov>
To: "'Johnson, Andrew N.'" <anj at anl.gov>
Cc: EPICS core-talk <core-talk at aps.anl.gov>, Michael Davidsaver <mdavidsaver at gmail.com>
Date: Thu, 4 Jun 2020 13:48:36 +0000
Hi Andrew,
I am trying what you suggested, but I am having problems.  I deleted /usr/local/vw/vxWorks-6.9 and made that a soft link to /usr/local/vw/vxWorks-6.9.4.
corvette:local/epics/base-7.0.4>ls -ld /usr/local/vw/vx*
-rw-rw-r-- 1 epics domain users 980391644 Jan  6  2017 /usr/local/vw/vxWorks-6.8.tar.gz
lrwxrwxrwx 1 epics domain users        13 Jun  4 08:10 /usr/local/vw/vxWorks-6.9 -> vxWorks-6.9.4
drwxrwsr-x 5 epics domain users       122 Sep 24  2014 /usr/local/vw/vxWorks-6.9.4
If I use the distribution version of CONFIG_SITE.Common.vxWorksCommon from base 7.0.4 I then get these errors:
corvette:local/epics/base-7.0.4>make -sj
make[4]: /usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc: Command not found
That is because the compiler path is
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9.4/x86-linux2/bin/ccppc
not
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc.
If I change CONFIG_SITE.Common.vxWorksCommon as follows:
index 0b0654a..9e97ec5 100644
--- a/configure/os/CONFIG_SITE.Common.vxWorksCommon
+++ b/configure/os/CONFIG_SITE.Common.vxWorksCommon
@@ -11,7 +11,7 @@
#VXWORKS_VERSION = 6.6
#VXWORKS_VERSION = 6.7
#VXWORKS_VERSION = 6.8
-VXWORKS_VERSION = 6.9
+VXWORKS_VERSION = 6.9.4
make[4]: /usr/local/vw/vxWorks-6.9.4/gnu/-vxworks-6.9.4/x86-linux2/bin/ccppc: Command not found
What do I need to do to use the distributed version of CONFIG_SITE.Common.vxWorksCommon?
My /usr/local/vw/vxWorks-6.9.4 tree is a direct copy from APSshare.
Sent: Wednesday, June 3, 2020 7:38 PM
To: Mark Rivers <rivers at cars.uchicago.edu>
Cc: Michael Davidsaver <mdavidsaver at gmail.com>; EPICS core-talk <core-talk at aps.anl.gov>
Subject: Re: Problem booting vxWorks with base 7.0.4
Hi Mark,
On Jun 3, 2020, at 7:29 PM, Mark Rivers <rivers at cars.uchicago.edu> wrote:
The problem was indeed related to that message.  Somehow this file in my base/configure/os got changed.  I changed it back:
diff --git a/configure/os/CONFIG_SITE.Common.vxWorksCommon b/configure/os/CONFIG_SITE.Common.vxWorksCommon
index 0b0654a..6a1d6bb 100644
@@ -21,5 +21,5 @@ VXWORKS_VERSION = 6.9
# WIND_BASE is where you installed the Wind River software.
#WIND_BASE = /usr/local/vw/tornado22-$(ARCH_CLASS)
-WIND_BASE = /usr/local/vw/vxWorks-$(VXWORKS_VERSION)
+WIND_BASE = /usr/local/vw/vxWorks-6.9.4
#WIND_BASE = /ade/vxWorks/$(VXWORKS_VERSION)
Your “wrong” configuration is the APS Accelerator IOC’s “right” configuration and hence how the EPICS source code normally comes. If you can you might want to rename your old vxWorks-6.9 directory to something else to catch this sooner in case it happens again with another release; or just remove the original 6.9 tree completely and make that a soft-link to the newer release.
- Andrew
Complexity comes for free, simplicity you have to work for.
Re: Problem booting vxWorks with base 7.0.4 Johnson, Andrew N. via Core-talk
Problem booting vxWorks with base 7.0.4 Mark Rivers via Core-talk
Re: Problem booting vxWorks with base 7.0.4 Michael Davidsaver via Core-talk
Re: Problem booting vxWorks with base 7.0.4 Mark Rivers via Core-talk
Prev: Re: EPICS 7 and VxWorks 6.9 for PPC604? Michael Davidsaver via Core-talk
Next: Re: Problem booting vxWorks with base 7.0.4 Johnson, Andrew N. via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Prev: Re: Problem booting vxWorks with base 7.0.4 Johnson, Andrew N. via Core-talk
ANJ, 04 Jun 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
