2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: Re: Problem booting vxWorks with base 7.0.4
From: "Johnson, Andrew N. via Core-talk" <core-talk at aps.anl.gov>
To: "Rivers, Mark L." <rivers at cars.uchicago.edu>
Cc: EPICS core-talk <core-talk at aps.anl.gov>
Date: Thu, 4 Jun 2020 16:41:20 +0000
Hi Mark,
On Jun 4, 2020, at 8:48 AM, Mark Rivers <rivers at cars.uchicago.edu> wrote:
I am trying what you suggested, but I am having problems.  I deleted /usr/local/vw/vxWorks-6.9 and made that a soft link to /usr/local/vw/vxWorks-6.9.4.
corvette:local/epics/base-7.0.4>ls -ld /usr/local/vw/vx*
-rw-rw-r-- 1 epics domain users 980391644 Jan  6  2017 /usr/local/vw/vxWorks-6.8.tar.gz
lrwxrwxrwx 1 epics domain users        13 Jun  4 08:10 /usr/local/vw/vxWorks-6.9 -> vxWorks-6.9.4
drwxrwsr-x 5 epics domain users       122 Sep 24  2014 /usr/local/vw/vxWorks-6.9.4
If I use the distribution version of CONFIG_SITE.Common.vxWorksCommon from base 7.0.4 I then get these errors:
corvette:local/epics/base-7.0.4>make -sj
make[4]: /usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc: Command not found
That is because the compiler path is
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9.4/x86-linux2/bin/ccppc
not
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc.
If I change CONFIG_SITE.Common.vxWorksCommon as follows:
index 0b0654a..9e97ec5 100644
--- a/configure/os/CONFIG_SITE.Common.vxWorksCommon
+++ b/configure/os/CONFIG_SITE.Common.vxWorksCommon
@@ -11,7 +11,7 @@
#VXWORKS_VERSION = 6.6
#VXWORKS_VERSION = 6.7
#VXWORKS_VERSION = 6.8
-VXWORKS_VERSION = 6.9
+VXWORKS_VERSION = 6.9.4
make[4]: /usr/local/vw/vxWorks-6.9.4/gnu/-vxworks-6.9.4/x86-linux2/bin/ccppc: Command not found
What do I need to do to use the distributed version of CONFIG_SITE.Common.vxWorksCommon?
My /usr/local/vw/vxWorks-6.9.4 tree is a direct copy from APSshare.
Oops, yeah unfortunately APSshare is a slightly non-standard VxWorks installation because of the need for APSShare to support both 6.9 and 6.9.4.1 simultaneously, so Ron Sluiter moved some things around inside when he added the 6.9.4 tree, sorry I forgot about those internal paths.
You would need to add soft-links inside your tree or rename two internal vxWorks-6.9.4 directories to go back to using my standard paths. Here’s your full recipe using soft-links (untested):
cd /usr/local/vw
ln -s vxWorks-6.9.4 vxWorks-6.9
cd vxWorks-6.9.4
ln -s gnu/4.3.3-vxworks-6.9.4 gnu/4.3.3-vxworks-6.9
HTH,
- Andrew
Sent: Wednesday, June 3, 2020 7:38 PM
To: Mark Rivers <rivers at cars.uchicago.edu>
Cc: Michael Davidsaver <mdavidsaver at gmail.com>; EPICS core-talk <core-talk at aps.anl.gov>
Hi Mark,
On Jun 3, 2020, at 7:29 PM, Mark Rivers <rivers at cars.uchicago.edu> wrote:
The problem was indeed related to that message.  Somehow this file in my base/configure/os got changed.  I changed it back:
diff --git a/configure/os/CONFIG_SITE.Common.vxWorksCommon b/configure/os/CONFIG_SITE.Common.vxWorksCommon
index 0b0654a..6a1d6bb 100644
@@ -21,5 +21,5 @@ VXWORKS_VERSION = 6.9
# WIND_BASE is where you installed the Wind River software.
#WIND_BASE = /usr/local/vw/tornado22-$(ARCH_CLASS)
-WIND_BASE = /usr/local/vw/vxWorks-$(VXWORKS_VERSION)
+WIND_BASE = /usr/local/vw/vxWorks-6.9.4
#WIND_BASE = /ade/vxWorks/$(VXWORKS_VERSION)
Your “wrong” configuration is the APS Accelerator IOC’s “right” configuration and hence how the EPICS source code normally comes. If you can you might want to rename your old vxWorks-6.9 directory to something else to catch this sooner in case it happens again with another release; or just remove the original 6.9 tree completely and make that a soft-link to the newer release.
- Andrew
Complexity comes for free, simplicity you have to work for.
RE: Problem booting vxWorks with base 7.0.4 Mark Rivers via Core-talk
Re: Problem booting vxWorks with base 7.0.4 Michael Davidsaver via Core-talk
Re: Problem booting vxWorks with base 7.0.4 Mark Rivers via Core-talk
Re: Problem booting vxWorks with base 7.0.4 Johnson, Andrew N. via Core-talk
Prev: RE: Problem booting vxWorks with base 7.0.4 Mark Rivers via Core-talk
Next: [Bug 1882120] [NEW] EPICS Open License - add to SPDX License List? Jilayne Lovejoy via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Next: RE: Problem booting vxWorks with base 7.0.4 Mark Rivers via Core-talk
ANJ, 04 Jun 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
