I've pushed 19146a597b42bc5f03aed1d97ccef56b4c4d0fac which I think fixes
this issue. Which I've noted as:
https://bugs.launchpad.net/epics-base/+bug/1884339
I'm still working on unittest coverage of the two functions in osdSockAddrReuse.cpp.
There is a PR for this change as I'd like to get comments on the UDP fanout test
before merging.
https://github.com/epics-base/epics-base/pull/79
It passes on Windows/appveyor with this fix, and fails without it.
So I think I've fixed the bug. However, one travis-ci configuration
is still failing. I think this is due to VM network configuration.
On 6/19/20 1:58 PM, Mark Rivers wrote:
> Hi Michael,
> I tested your suggestion of resurrecting the original WIN32/osdSockAddrReuse.cpp. I just had to tweak the decorations. It fixed the problem.
> I just posted to tech-talk so there is a known workaround until there is a patch release.
> Thanks,
> Mark
> ________________________________
> From: Michael Davidsaver <mdavidsaver at gmail.com>
> Sent: Friday, June 19, 2020 1:04 AM
> To: Mark Rivers
> Cc: Johnson, Andrew N.; EPICS core-talk
> Subject: Re: Possible problem with base 7.0.4 on Windows (regression)
> Hi Mark,
> I suppose it's fitting for you to report this regression which
> has its roots in my attempt to fix another issue you reported.
> https://epics.anl.gov/core-talk/2020/msg00050.php
> db6e7c7a22b73f70a8b93e2aa4b6fa505e0218a6 was one of a series
> of commits effecting this code and can't simply be reverted
> in full. Copying in the original WIN32/osdSockAddrReuse.cpp
> should do as a quick workaround.
> https://github.com/epics-base/epics-base/blob/5064931aa6e54481832951b4f27a982c5003233d/modules/libcom/src/osi/os/WIN32/osdSockAddrReuse.cpp
> The changes which cause this were made during the Feb. codeathon
> at DLS. At the time I added a new unittest to osiSockTest which
> checks the behavior of bind(), but doesn't actually send/receive
> any traffic.
> I would have liked to test this as well. The problem is that I
> don't know of a portable way to send broadcast traffic through
> the loopback. Using other interfaces would be a violation of
> the usual practice of unittest isolation, as other hosts could
> see this traffic.
> Right now, I'm inclined towards doing this though. With a test
> which sends legitimate CA search broadcasts on 5064 through all
> interfaces with a random/invalid PV name.
> I think the risk of adverse external effects would be minimal,
> and the benefit of avoiding future regressions sufficient
> to justify it.
> On 6/18/20 8:37 PM, Johnson, Andrew N. via Core-talk wrote:
>> Hi Mark,
>> On Jun 18, 2020, at 9:39 PM, Mark Rivers via Core-talk <core-talk at aps.anl.gov <mailto:core-talk at aps.anl.gov>> wrote:
>>> I am writing to report a possible problem with base 7.0.4 on Windows.
>>> Today I updated EPICS on a Windows machine from base 7.0.3.1 to 7.0.4. This machine runs 3 EPICS IOCs; 2 are areaDetector camera IOCs and the third runs various serial and TCP devices.
>>> The behavior I observed was strange.
>>> - The first 2 IOCs to start worked fine, I could connect to them from Channel Access clients.
>>> - The third IOC started fine, and dbl showed all the PVs. However, I could not connect to them from any Channel Access client (medm ,caget, etc.)
>>> If I changed the order in which I started the IOCs it appears that the last IOC to start is the one that cannot connect with Channel Access.
>>> I rolled back to the 7.0.3.1 versions of the IOCs and they all connect fine.
>>> I cannot say that I have conclusively proved the above by starting the IOCs in all different orders, etc. But it looking like a problem.
>> I just started 2 IOCs on windows-x64. I can connect to the first, but not to the second:
>>> *tux% *caget 1:BaseVersion
>>> 1:BaseVersion 7.0.4.1-DEV
>>> *tux% *caget 2:BaseVersion
>>> Channel connect timed out: '2:BaseVersion' not found.
>> I tested this first on my Mac laptop and was able to connect to 6 IOCs with no problems, so this looks like it’s a Windows issue.
>> It is often useful to see the output of running ‘casr 1’ which shows how the IOC has configured its network connections. This was casr on my first IOC:
>>> epics> casr 1
>>> Channel Access Server V4.13
>>> No clients connected.
>>> CAS-TCP server on 0.0.0.0:5064 with
>>> CAS-UDP name server on 0.0.0.0:5064
>>> Sending CAS-beacons to 1 address:
>>> 164.54.11.255:5065
>> This was the complete startup of my second IOC (while the first was still running):
>>> C:\epics\base-7.0\bin\windows-x64>softIoc -x 2
>>> dbLoadDatabase("C:\epics\base-7.0\bin\windows-x64\..\..\dbd\softIoc.dbd")
>>> softIoc_registerRecordDeviceDriver(pdbbase)
>>> iocInit()
>>> Starting iocInit
>>> ## EPICS R7.0.4.1-DEV
>>> ## Rev. R7.0.4-11-g786c4c2ca29f750bc49c-dirty
>>> iocRun: All initialization complete
>>> epics> dbl
>>> 2:BaseVersion
>>> 2:exit
>>> epics> casr
>>> epics> casr 1
>>> 164.54.11.255:5065
>> Note that the output from iocInit there does not contain the usual warning about the configured TCP port being unavailable, and both CAS-TCP servers claim to have TCP port 5064 open. That is a big tell that we have a bug.
>>> Were there any changes in 7.0.4 that might have caused such a problem?
>> Yes, although I don’t know the details myself, and unfortunately nothing appears in the Release Notes to describe those changes. One commit which looks particularly interesting was this:
>>> commit db6e7c7a22b73f70a8b93e2aa4b6fa505e0218a6
>>> Author: Michael Davidsaver <mdavidsaver at gmail.com <mailto:mdavidsaver at gmail.com>>
>>> Date: Wed Feb 5 10:30:58 2020 -0800
>>> use one osdSockAddrReuse impl for all targets
>>> drop win32 specialization of osdSockAddrReuse
>> A fairly prominent comment in the deleted files said:
>>> - * Note: WINSOCK appears to assign a different functionality for
>>> - * SO_REUSEADDR compared to other OS. With WINSOCK SO_REUSEADDR indicates
>>> - * that simultaneously servers can bind to the same TCP port on the same host!
>>> - * Also, servers are always enabled to reuse a port immediately after
>>> - * they exit ( even if SO_REUSEADDR isnt set ).
>> I just tried reverting that commit and had to fix up the symbol decoration macros in the WIN32 file, but with that done when I start two IOCs, the second one shows the expected TCP warning and I can connect to both with no problem.
>> I think that means we’ll be able to provide a fix fairly quickly, but I will leave it to Michael to decide exactly what changes to make.
>> Thanks for the report,
>> - Andrew
>> Complexity comes for free, simplicity you have to work for.
- Possible problem with base 7.0.4 on Windows Mark Rivers via Core-talk
- Re: Possible problem with base 7.0.4 on Windows Johnson, Andrew N. via Core-talk
- Re: Possible problem with base 7.0.4 on Windows (regression) Michael Davidsaver via Core-talk
- Re: Possible problem with base 7.0.4 on Windows (regression) Mark Rivers via Core-talk
[Bug 1884339] Re: Inaccessible CA servers on Windows mdavidsaver via Core-talk
<2020>
2025
2026
makefile include order Ben Franksen via Core-talk
<2020>
2025
2026
