2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: Re: getVersionHelper.pl ignore -V option
From: Michael Davidsaver via Core-talk <core-talk at aps.anl.gov>
To: Jeong Han Lee <citadel.lee at gmail.com>
Cc: EPICS Core Talk <core-talk at aps.anl.gov>
Date: Tue, 18 Aug 2020 11:14:16 -0700
On 8/18/20 11:03 AM, Jeong Han Lee wrote:
> Hi Michael,
> Thank you for clarifying this.  Without it, so far I cannot override
> the -dirty git describe within the ioc console.
> Do you know how to remove -dirty description? It is dirty according to
> the git, but this is not dirty, because I didn't change anything on
> source code, but changed CONFIG_SITE_ENV only.
Our script gets this revision by running:
> git describe --always --tags --dirty --abbrev=20
So you could patch it to remove '--dirty'.
"man git-describe" says of '--dirty':
> Describe the state of the working tree. When the working tree matches HEAD, the output is the same as "git
> describe HEAD". If the working tree has local modification "-dirty" is appended to it.
So the simplest way to is to commit changes to all VCS tracked files.
(eg. not configure/RELEASE.local)
The intent of including '-dirty' is to capture the case where
a running IOC (or whatever) may not be reproduced by a clean
checkout and build.
I'm not sure what to think about 'configure/CONFIG_SITE_ENV'.
Do we need a CONFIG_SITE_ENV.local?
> Best,
> Han
> On Tue, Aug 18, 2020 at 8:07 AM Michael Davidsaver
> <mdavidsaver at gmail.com> wrote:
>> On 8/18/20 2:17 AM, Jeong Han Lee via Core-talk wrote:
>>> Hi,
>>>    I don't know if this feature is intentionally designed.  From my
>>> naive perspective, there is a logic to check whether option -V is
>>> defined or not. This is a quick-and-dirty P0 patch.
>> As I recall, '-V <ver>' was intended as a fallback if/when no VCS info
>> is available.  So it should be overridden if any of the conditions
>> are matched.
>> If you always want to use a version string stored in a Make variable,
>> then you might be better off using expandVars.pl (or just 'cat' if you're
>> in a hurry).
>>> $ ./bin/linux-x86_64/genVersionHeader.pl -h
>>> Usage:
>>>         -V version - Version if no VCS (e.g. '2020-08-18T08:01-0700')
Re: getVersionHelper.pl ignore -V option Jeong Han Lee via Core-talk
Re: getVersionHelper.pl ignore -V option Johnson, Andrew N. via Core-talk
Re: getVersionHelper.pl ignore -V option Michael Davidsaver via Core-talk
Prev: Re: getVersionHelper.pl ignore -V option Jeong Han Lee via Core-talk
Next: Re: getVersionHelper.pl ignore -V option Jeong Han Lee via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
ANJ, 18 Aug 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
