2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: Re: getVersionHelper.pl ignore -V option
From: Jeong Han Lee via Core-talk <core-talk at aps.anl.gov>
To: Michael Davidsaver <mdavidsaver at gmail.com>
Cc: EPICS Core Talk <core-talk at aps.anl.gov>
Date: Tue, 18 Aug 2020 11:26:37 -0700
Hi Michael,
CONFIG_SITE_ENV is always needed to be changed. There is no local file
support. If you can make this happen, it would be greatly appreciated.
However, I still think we need an option to override the message which
is shown in the running IOC, because it gives operators or others
wrong signs about the quality of EPICS base.
Best,
Han
On Tue, Aug 18, 2020 at 11:14 AM Michael Davidsaver
<mdavidsaver at gmail.com> wrote:
> On 8/18/20 11:03 AM, Jeong Han Lee wrote:
> > Hi Michael,
> > Thank you for clarifying this.  Without it, so far I cannot override
> > the -dirty git describe within the ioc console.
> > Do you know how to remove -dirty description? It is dirty according to
> > the git, but this is not dirty, because I didn't change anything on
> > source code, but changed CONFIG_SITE_ENV only.
> Our script gets this revision by running:
> > git describe --always --tags --dirty --abbrev=20
> So you could patch it to remove '--dirty'.
> "man git-describe" says of '--dirty':
> > Describe the state of the working tree. When the working tree matches HEAD, the output is the same as "git
> > describe HEAD". If the working tree has local modification "-dirty" is appended to it.
> So the simplest way to is to commit changes to all VCS tracked files.
> (eg. not configure/RELEASE.local)
> The intent of including '-dirty' is to capture the case where
> a running IOC (or whatever) may not be reproduced by a clean
> checkout and build.
> I'm not sure what to think about 'configure/CONFIG_SITE_ENV'.
> Do we need a CONFIG_SITE_ENV.local?
> > Best,
> > Han
> > On Tue, Aug 18, 2020 at 8:07 AM Michael Davidsaver
> >> On 8/18/20 2:17 AM, Jeong Han Lee via Core-talk wrote:
> >>> Hi,
> >>>    I don't know if this feature is intentionally designed.  From my
> >>> naive perspective, there is a logic to check whether option -V is
> >>> defined or not. This is a quick-and-dirty P0 patch.
> >> As I recall, '-V <ver>' was intended as a fallback if/when no VCS info
> >> is available.  So it should be overridden if any of the conditions
> >> are matched.
> >> If you always want to use a version string stored in a Make variable,
> >> then you might be better off using expandVars.pl (or just 'cat' if you're
> >> in a hurry).
> >>> $ ./bin/linux-x86_64/genVersionHeader.pl -h
> >>> Usage:
> >>>         -V version - Version if no VCS (e.g. '2020-08-18T08:01-0700')
Re: getVersionHelper.pl ignore -V option Johnson, Andrew N. via Core-talk
getVersionHelper.pl ignore -V option Jeong Han Lee via Core-talk
Re: getVersionHelper.pl ignore -V option Michael Davidsaver via Core-talk
Re: getVersionHelper.pl ignore -V option Jeong Han Lee via Core-talk
Prev: Re: getVersionHelper.pl ignore -V option Michael Davidsaver via Core-talk
Next: Re: getVersionHelper.pl ignore -V option Johnson, Andrew N. via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
ANJ, 18 Aug 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
