2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: Re: getVersionHelper.pl ignore -V option
From: "Johnson, Andrew N. via Core-talk" <core-talk at aps.anl.gov>
To: Jeong Han Lee <citadel.lee at gmail.com>
Cc: EPICS core-talk <core-talk at aps.anl.gov>, Michael Davidsaver <mdavidsaver at gmail.com>
Date: Tue, 18 Aug 2020 18:45:50 +0000
Hi Han,
On Aug 18, 2020, at 1:26 PM, Jeong Han Lee via Core-talk <core-talk at aps.anl.gov> wrote:
CONFIG_SITE_ENV is always needed to be changed. There is no local file
support. If you can make this happen, it would be greatly appreciated.
I agree that this file should have .local support, but I don’t think you should be relying on it (see below).
However, I still think we need an option to override the message which
is shown in the running IOC, because it gives operators or others
wrong signs about the quality of EPICS base.
I recommend that you make the changes you need to the CONFIG_SITE_ENV and any other files, and commit them to a local branch (note that to commit files matching configure/*.local you would have to use git add —force so I would recommend modifying the other files anyway). This will remove the -dirty flag and also give you a local tag (e.g. 7.0.4.1-ESS-1) which captures all the local changes you need to make for a new release and will appear in your git version number.
- Andrew
Complexity comes for free, simplicity you have to work for.
Re: getVersionHelper.pl ignore -V option Jeong Han Lee via Core-talk
Re: getVersionHelper.pl ignore -V option Michael Davidsaver via Core-talk
Prev: Re: getVersionHelper.pl ignore -V option Johnson, Andrew N. via Core-talk
Next: Re: getVersionHelper.pl ignore -V option Jeong Han Lee via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Prev: Re: getVersionHelper.pl ignore -V option Jeong Han Lee via Core-talk
ANJ, 18 Aug 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
