2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026
Subject: Re: Announcement: Legacy libnetworking will be removed from RTEMS and will be placed in a separate repository
From: Vijay Kumar Banerjee via Core-talk <core-talk at aps.anl.gov>
To: Joel Sherrill <joel at rtems.org>
Cc: Core talk <core-talk at aps.anl.gov>, "rtems-devel at rtems.org" <devel at rtems.org>
Date: Thu, 4 Mar 2021 08:33:00 -0700
On Thu, Mar 4, 2021 at 7:26 AM Joel Sherrill <joel at rtems.org> wrote:
> On Thu, Mar 4, 2021 at 8:22 AM Heinz Junkes <junkes at fhi-berlin.mpg.de> wrote:
>> I have installed the legacy package but the files are not there.
>> I guess they were just forgotten in the legacy package.
> I'd guess Vijay forgot to install them. Certainly easy enough to do.
they're getting installed in the lib/ directory in the prefix:
beatnik/lib/include/rtems/telnetd.h
beatnik/lib/librtemsNfs.h
beatnik/lib/rtems/rtems_bsdnet.h
For rtems_bsdnet.h and librtemsNfs.h, the right place for install was
supposed to be lib/include I guess (?) that might be the reason that
it's not being found from your application as it's searching for it in
the include directory. I'll push a fix to install it in the include
directory, but in the current state, these files do get installed in
the prefix location somewhere. Could you please try the ./waf install
again and see if these files are getting installed somewhere in the
prefix?
Best regards,
Vijay
> Eventually the NFSv2 client will need to be in the legacy stack
> package. But until the port of the FreeBSD NFSv4 client is available
> in libbsd, the existing NFSv2 client has to be used for both stacks.
> I suppose this may end up being the one piece of lingering clean up.
> --joel
>> Heinz
>> > On 4. Mar 2021, at 14:52, Joel Sherrill <joel at rtems.org> wrote:
>> > Did you install the legacy package? If you installed it in the same place
>> > as the RTEMS 5 BSP, I would expect it to be there. This SHOULD be
>> > equivalent to prior split.
Re: Announcement: Legacy libnetworking will be removed from RTEMS and will be placed in a separate repository Vijay Kumar Banerjee via Core-talk
Re: Announcement: Legacy libnetworking will be removed from RTEMS and will be placed in a separate repository junkes via Core-talk
Re: Announcement: Legacy libnetworking will be removed from RTEMS and will be placed in a separate repository Joel Sherrill via Core-talk
Re: Announcement: Legacy libnetworking will be removed from RTEMS and will be placed in a separate repository Heinz Junkes via Core-talk
Prev: Re: Announcement: Legacy libnetworking will be removed from RTEMS and will be placed in a separate repository Joel Sherrill via Core-talk
Next: Re: Announcement: Legacy libnetworking will be removed from RTEMS and will be placed in a separate repository Vijay Kumar Banerjee via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026
ANJ, 04 Mar 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
