2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026
Subject: Re: Announcement: Legacy libnetworking will be removed from RTEMS and will be placed in a separate repository
From: Joel Sherrill via Core-talk <core-talk at aps.anl.gov>
To: Heinz Junkes <junkes at fhi-berlin.mpg.de>
Cc: Core talk <core-talk at aps.anl.gov>, "rtems-devel at rtems.org" <devel at rtems.org>
Date: Thu, 4 Mar 2021 08:26:37 -0600
On Thu, Mar 4, 2021 at 8:22 AM Heinz Junkes <junkes at fhi-berlin.mpg.de> wrote:
I have installed the legacy package but the files are not there.
I guess they were just forgotten in the legacy package.
I'd guess Vijay forgot to install them. Certainly easy enough to do.
Eventually the NFSv2 client will need to be in the legacy stack
package. But until the port of the FreeBSD NFSv4 client is available
in libbsd, the existing NFSv2 client has to be used for both stacks.
I suppose this may end up being the one piece of lingering clean up.
--joel
Heinz
> On 4. Mar 2021, at 14:52, Joel Sherrill <joel at rtems.org> wrote:
> Did you install the legacy package? If you installed it in the same place
> as the RTEMS 5 BSP, I would expect it to be there. This SHOULD be
> equivalent to prior split.
Re: Announcement: Legacy libnetworking will be removed from RTEMS and will be placed in a separate repository Vijay Kumar Banerjee via Core-talk
Re: Announcement: Legacy libnetworking will be removed from RTEMS and will be placed in a separate repository Chris Johns via Core-talk
Re: Announcement: Legacy libnetworking will be removed from RTEMS and will be placed in a separate repository junkes via Core-talk
Re: Announcement: Legacy libnetworking will be removed from RTEMS and will be placed in a separate repository Joel Sherrill via Core-talk
Re: Announcement: Legacy libnetworking will be removed from RTEMS and will be placed in a separate repository Heinz Junkes via Core-talk
Prev: Re: Announcement: Legacy libnetworking will be removed from RTEMS and will be placed in a separate repository Heinz Junkes via Core-talk
Next: Re: Announcement: Legacy libnetworking will be removed from RTEMS and will be placed in a separate repository Vijay Kumar Banerjee via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026
ANJ, 04 Mar 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
