2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026
Subject: Re: Announcement: Legacy libnetworking will be removed from RTEMS and will be placed in a separate repository
From: Chris Johns via Core-talk <core-talk at aps.anl.gov>
To: joel at rtems.org, Heinz Junkes <junkes at fhi-berlin.mpg.de>
Cc: Core talk <core-talk at aps.anl.gov>, "rtems-devel at rtems.org" <devel at rtems.org>
Date: Fri, 5 Mar 2021 10:09:17 +1100
On 5/3/21 1:26 am, Joel Sherrill wrote:
> Eventually the NFSv2 client will need to be in the legacy stack
> package. But until the port of the FreeBSD NFSv4 client is available
> in libbsd, the existing NFSv2 client has to be used for both stacks.
The NFSv2 (and RPC?) code can be moved from rtems.git to the net-legacy repo.
The libbsd stack contains a separate copy that is built when libbsd is built.
I found the NFSv4 port for libbsd cannot coexist in the same build of libbsd as
the NFSv2 code. The NFSv4 code is kernel based and has a kernel RPC stack and
the NFSv2 code has a user land RPC stack. The FreeBSD user and kernel RPC stacks
clashed when I last tried. I will check this again once I have wrapped up the
NFSv4 port to see if include magic can help but it is a low priority given NFSv4
has options to specify the NFS version to be used.
Chris
Re: Announcement: Legacy libnetworking will be removed from RTEMS and will be placed in a separate repository junkes via Core-talk
Re: Announcement: Legacy libnetworking will be removed from RTEMS and will be placed in a separate repository Joel Sherrill via Core-talk
Re: Announcement: Legacy libnetworking will be removed from RTEMS and will be placed in a separate repository Vijay Kumar Banerjee via Core-talk
Re: Announcement: Legacy libnetworking will be removed from RTEMS and will be placed in a separate repository Heinz Junkes via Core-talk
Prev: Re: Announcement: Legacy libnetworking will be removed from RTEMS and will be placed in a separate repository Johnson, Andrew N. via Core-talk
Next: Re: Announcement: Legacy libnetworking will be removed from RTEMS and will be placed in a separate repository Chris Johns via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026
Prev: Re: Announcement: Legacy libnetworking will be removed from RTEMS and will be placed in a separate repository Vijay Kumar Banerjee via Core-talk
Next: Re: Announcement: Legacy libnetworking will be removed from RTEMS and will be placed in a separate repository Heinz Junkes via Core-talk
ANJ, 04 Mar 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
