2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026
Subject: Re: Announcement: Legacy libnetworking will be removed from RTEMS and will be placed in a separate repository
From: "Johnson, Andrew N. via Core-talk" <core-talk at aps.anl.gov>
To: Chris Johns <chrisj at rtems.org>
Cc: Core talk <core-talk at aps.anl.gov>, Joel Sherrill <joel at rtems.org>, "rtems-devel at rtems.org" <devel at rtems.org>
Date: Thu, 4 Mar 2021 17:42:53 +0000
On Mar 3, 2021, at 6:45 PM, Chris Johns via Core-talk <core-talk at aps.anl.gov> wrote:
We should encourage users to add BSP build stacks to the RSB. I remember Andrew
Johnson posted on for a Coldfire. We should merge that one.
That file was trivial to create, it ought to be easy to automate generating it.
However one drawback is that it always builds the compiler and toolchain as well as the BSP, so anyone working on more than one BSP will be wasting cycles if they use that. I don’t know if RSB could be taught to not do toolchain builds unnecessarily, or if you could provide a different set of recipes that don’t have them as a component to be built?
Michael Davidsaver taught me to run commands like this instead to avoid wasting cycles when I had already built the toolchain:
../source-builder/sb-set-builder \
    --host=powerpc-rtems5 --target=powerpc-rtems5 \
    --prefix=/home/anj/RTEMS-5.1/rtems-5.1 \
    --with-rtems-bsp=mvme3100 \
    5/rtems-kernel 5/rtems-libbsd
BTW why do both the --host= and --target= options there (equivalent to %defines in the .bset file) specify the RTEMS target? That seems weird to me.
- Andrew
Complexity comes for free, simplicity you have to work for.
Re: Announcement: Legacy libnetworking will be removed from RTEMS and will be placed in a separate repository Chris Johns via Core-talk
Re: Announcement: Legacy libnetworking will be removed from RTEMS and will be placed in a separate repository junkes via Core-talk
Re: Announcement: Legacy libnetworking will be removed from RTEMS and will be placed in a separate repository Joel Sherrill via Core-talk
Re: Announcement: Legacy libnetworking will be removed from RTEMS and will be placed in a separate repository Vijay Kumar Banerjee via Core-talk
Re: Announcement: Legacy libnetworking will be removed from RTEMS and will be placed in a separate repository Heinz Junkes via Core-talk
Prev: Re: Announcement: Legacy libnetworking will be removed from RTEMS and will be placed in a separate repository Vijay Kumar Banerjee via Core-talk
Next: Re: Announcement: Legacy libnetworking will be removed from RTEMS and will be placed in a separate repository Chris Johns via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026
ANJ, 04 Mar 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
