2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: RE: Problem building ezcaIDL on Windows
From: Mark Rivers via Core-talk <core-talk at aps.anl.gov>
To: 'Ralph Lange' <ralph.lange at gmx.de>
Cc: EPICS core-talk <core-talk at aps.anl.gov>
Date: Thu, 17 Jun 2021 22:45:24 +0000
Ø  Just be aware of and careful about the dynamic and static variants of Windows builds additionally setting other compiler flags differently. Mixing object code that has been produced with different flags may create unwanted bad side effects. I.e., you shouldn't put object code from a dynamic build into a static library and vice versa.
That is an interesting point.  It is actually how that DLL has been built for many years.  It is convenient, because Com, ca, ezca, and EzcaScan are statically built into ezcaIDL.dll.  That DLL thus stands alone, and one does not need all the other DLLs.  Depending on other DLLs can lead to a real mess with PATH.  With applications (.exe files) I believe that Windows will look first for DLLs in the same folder as the .exe.  But for a run-time loadable DLL like ezcIDL.dll that does not seem to be the case.
The mixed-mode has worked fine for many years.  What are the types of problems people have seen when doing that?
From: Core-talk <core-talk-bounces at aps.anl.gov> On Behalf Of Ralph Lange via Core-talk
Sent: Saturday, June 12, 2021 2:55 AM
To: EPICS Core Talk <core-talk at aps.anl.gov>
Subject: Re: Problem building ezcaIDL on Windows
On Fri, 11 Jun 2021 at 22:03, Mark Rivers via Core-talk <core-talk at aps.anl.gov> wrote:
The names are already decorated with epicsShareFunc and epicsShareAPI.
It exports the symbols OK for these cases:
-          windows-x64 architecture
-          windows-x64-static architecture if the Makefile contains SHARED_LIBRARIES=YES, whether I use LIBRARY_HOST or LOADABLE_LIBRARY_HOST.
(Disclaimer: I did not follow the thread closely, so this specific use case may be doing things right.)
Cheers,
~Ralph
Re: Problem building ezcaIDL on Windows Ralph Lange via Core-talk
Problem building ezcaIDL on Windows Mark Rivers via Core-talk
RE: Problem building ezcaIDL on Windows Mark Rivers via Core-talk
Re: Problem building ezcaIDL on Windows Michael Davidsaver via Core-talk
Re: Problem building ezcaIDL on Windows Johnson, Andrew N. via Core-talk
Prev: [Bug 1932118] Re: Bug in vxWorks epicsAtomicCmpAndSwapIntT Andrew Johnson via Core-talk
Next: Build completed: EPICS Base 7 base-7.0-341 AppVeyor via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: Problem building ezcaIDL on Windows Ralph Lange via Core-talk
Next: Re: Problem building ezcaIDL on Windows Ralph Lange via Core-talk
ANJ, 18 Jun 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
