The names are already decorated with epicsShareFunc and epicsShareAPI.
It exports the symbols OK for these cases:
windows-x64 architecture
windows-x64-static architecture if the Makefile contains SHARED_LIBRARIES=YES, whether I use LIBRARY_HOST or LOADABLE_LIBRARY_HOST.
Just be aware of and careful about the dynamic and static variants of Windows builds additionally setting other compiler flags differently. Mixing object code that has been produced with different flags may create unwanted bad side effects. I.e., you shouldn't put object code from a dynamic build into a static library and vice versa.
(Disclaimer: I did not follow the thread closely, so this specific use case may be doing things right.)
Cheers, ~Ralph
- RE: Problem building ezcaIDL on Windows Mark Rivers via Core-talk
- Problem building ezcaIDL on Windows Mark Rivers via Core-talk
- Re: Problem building ezcaIDL on Windows Michael Davidsaver via Core-talk
- Re: Problem building ezcaIDL on Windows Johnson, Andrew N. via Core-talk
Build failed in Jenkins: EPICS-3.14 #1062 Jenkins EPICS PSI via Core-talk
<2021>
2025
2026
<2021>
2025
2026
ANJ, 17 Jun 2021 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
