2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: Re: readline in base 7.0.7
From: Mark Rivers via Core-talk <core-talk at aps.anl.gov>
To: Michael Davidsaver <mdavidsaver at gmail.com>
Cc: "core-talk at aps.anl.gov" <core-talk at aps.anl.gov>
Date: Sat, 1 Oct 2022 12:48:20 +0000
Hi Michael,
distclean fixed the problem.  I didn't know I needed to clean since it was a .c file I changed.
readline is now used with no change to the configure/os files.
From: Michael Davidsaver <mdavidsaver at gmail.com>
Sent: Friday, September 30, 2022 6:00 PM
To: Mark Rivers <rivers at cars.uchicago.edu>
Cc: core-talk at aps.anl.gov <core-talk at aps.anl.gov>
On 9/30/22 15:43, Mark Rivers wrote:
> Michael,
> I had already tried eliminating the continuation lines, but that did not help.
> I just copied that new line from your PR and pasted it into toolchain.c.  It still fails.
Can you check if the generated files were actually re-created?
eg.
> cfg/TOOLCHAIN.linux-x86_64.linux-x86_64
> configure/O.linux-x86_64/TOOLCHAIN.linux-x86_64.linux-x86_64
A "make distclean" should remove them..
> This is make output on Centos 7.
fyi. The centos-7 CI build for this PR passes:
https://github.com/epics-base/epics-base/actions/runs/3055627011/jobs/4928888222
> corvette:epics-devel/base-7.0.7/configure>make
> make -C O.linux-x86_64 -f ../Makefile TOP=../.. \
>      T_A=linux-x86_64 install
> make[1]: Entering directory `/usr/local/epics-devel/base-7.0.7/configure/O.linux-x86_64'
> ../../cfg/TOOLCHAIN.linux-x86_64.linux-x86_64:13: *** missing separator.  Stop.
> make[1]: Leaving directory `/usr/local/epics-devel/base-7.0.7/configure/O.linux-x86_64'
> make: *** [install.linux-x86_64] Error 2
> I then tested on Ubuntu 22, and it worked in the same source directory.
> Thanks,
> Mark
> -----Original Message-----
> Sent: Friday, September 30, 2022 5:07 PM
> On 9/30/22 14:50, Mark Rivers wrote:
>  > Hi Michael,
>  > I just tried your patch, and it does not build.
> Andrew had me turn this into a PR.  What I have there now does build, and is different to what I posted previously.  So I must have hit the same error as you.  I guess I was getting the line continuations wrong somehow?  (then got frustrated and removed them)
> https://github.com/epics-base/epics-base/pull/296 <https://github.com/epics-base/epics-base/pull/296>
>  > corvette:local/epics-devel/base-7.0.7>patch -p1 < patch1
>  > patching file configure/toolchain.c
>  > corvette:local/epics-devel/base-7.0.7>git diff configure/toolchain.c
>  > diff --git a/configure/toolchain.c b/configure/toolchain.c
>  > index 2f76b47..bc37cad 100644
>  > --- a/configure/toolchain.c
>  > +++ b/configure/toolchain.c
>  > @@ -45,5 +45,7 @@ COMMANDLINE_LIBRARY ?= READLINE
>  > COMMANDLINE_LIBRARY ?= EPICS
>  > #  endif
>  > #else
>  > -COMMANDLINE_LIBRARY ?= EPICS
>  > +COMMANDLINE_LIBRARY ?= $(strip $(if $(wildcard \
>  > +    $(if $(GNU_DIR),$(GNU_DIR)/include/readline/readline.h) \
>  > +), READLINE, EPICS))
>  > #endif
>  > My diff looks just like your patch, so I think I did it correctly.
>  > However, it fails to build and I can't figure out the problem, since the parentheses do match.
>  > corvette:local/epics-devel/base-7.0.7>make
>  > make -C ./configure install
>  > make[1]: Entering directory `/usr/local/epics-devel/base-7.0.7/configure'
>  > make -C O.linux-x86_64 -f ../Makefile TOP=../.. \
>  >      T_A=linux-x86_64 install
>  > make[2]: Entering directory `/usr/local/epics-devel/base-7.0.7/configure/O.linux-x86_64'
>  > ../../cfg/TOOLCHAIN.linux-x86_64.linux-x86_64:13: *** missing separator.  Stop.
>  > make[2]: Leaving directory `/usr/local/epics-devel/base-7.0.7/configure/O.linux-x86_64'
>  > make[1]: *** [install.linux-x86_64] Error 2
>  > make[1]: Leaving directory `/usr/local/epics-devel/base-7.0.7/configure'
>  > make: *** [configure.install] Error 2
>  > Thanks,
>  > Mark
>  > -----Original Message-----
>  > From: Michael Davidsaver <mdavidsaver at gmail.com <mailto:mdavidsaver at gmail.com>>
>  > Sent: Friday, September 9, 2022 6:28 PM
>  > To: Mark Rivers <rivers at cars.uchicago.edu <mailto:rivers at cars.uchicago.edu>>
>  > Cc: core-talk at aps.anl.gov <mailto:core-talk at aps.anl.gov>
>  > Subject: Re: readline in base 7.0.7
>  > On 9/8/22 11:44, Mark Rivers wrote:
>  >  >  > You will need to manually specify COMMANDLINE_LIBRARY for the
>  > time being.  (and hopefully put an OS upgrade on your roadmap)
>  >  > This is unfortunate, since the automatic detection worked fine in base 7.0.6.1.
>  > fyi. https://github.com/epics-base/epics-base/pull/254 <https://github.com/epics-base/epics-base/pull/254>
>  > <https://github.com/epics-base/epics-base/pull/254 <https://github.com/epics-base/epics-base/pull/254>>
>  > As always, I would encourage those interested to follow PRs.
>  > Compatibility doesn't just happen by itself.
>  > The following lightly tested patch should restore the previous
>  > $(GNU_DIR) automatic detection for older compilers.  (not just
>  > linux)
>  >  > diff --git a/configure/toolchain.c b/configure/toolchain.c
>  >  > index 2f76b475b..bc37cad64 100644
>  >  > --- a/configure/toolchain.c
>  >  > +++ b/configure/toolchain.c
>  >  > @@ -45,5 +45,7 @@ COMMANDLINE_LIBRARY ?= READLINE
>  >  >  COMMANDLINE_LIBRARY ?= EPICS
>  >  >  #  endif
>  >  >  #else
>  >  > -COMMANDLINE_LIBRARY ?= EPICS
>  >  > +COMMANDLINE_LIBRARY ?= $(strip $(if $(wildcard \
>  >  > +    $(if $(GNU_DIR),$(GNU_DIR)/include/readline/readline.h) \
>  >  > +), READLINE, EPICS))
>  >  >  #endif
>  >  > The release notes really should say that manual editing is now required for older compilers, while it previously was not.
>  > Specific suggestions on wording are welcomed.  I find it
>  > difficult to write succinct documentation which speaks
>  > to every user.
>  >  >  They should also say which version of gcc is required to have the automatic detection work.
>  > GCC >=5.0
>  > https://gcc.gnu.org/projects/cxx-status.html#cxx17 <https://gcc.gnu.org/projects/cxx-status.html#cxx17>
>  > <https://gcc.gnu.org/projects/cxx-status.html#cxx17 <https://gcc.gnu.org/projects/cxx-status.html#cxx17>>
>  > I don't know when clang or msvc added support.
>  >  >  I now need to spend a few hours rebuilding base and synApps for a bunch of architectures.
>  > I'm sorry to have wasted your time.
>  >  >  > and hopefully put an OS upgrade on your roadmap)
>  >  > We have a number of machines where vendor support for kernel drivers limits such upgrades.  RHEL 7 has 2 more years before EOL, and is still used on many APS beamlines.
>  >  > Mark
>  >  > -----Original Message-----
>  >  > From: Michael Davidsaver <mdavidsaver at gmail.com
>  > <mailto:mdavidsaver at gmail.com <mailto:mdavidsaver at gmail.com>>>
>  >  > Sent: Thursday, September 8, 2022 1:29 PM
>  >  > To: Mark Rivers <rivers at cars.uchicago.edu
>  > <mailto:rivers at cars.uchicago.edu <mailto:rivers at cars.uchicago.edu>>>
>  >  > Cc: core-talk at aps.anl.gov <mailto:core-talk at aps.anl.gov> <mailto:core-talk at aps.anl.gov <mailto:core-talk at aps.anl.gov>>
>  >  > Subject: Re: readline in base 7.0.7
>  >  > On 9/8/22 10:40, Mark Rivers via Core-talk wrote:
>  >  >  > I just built base 7.0.7 on Centos 7 with no changes to the files in configure/os.
>  >  > Right, I wasn't paying attention.  Automatic detection now depends on GCC version.  As I recall, centos7 has GCC 4.8, which is too old.
>  >  > You will need to manually specify COMMANDLINE_LIBRARY for the time
>  > being.  (and hopefully put an OS upgrade on your roadmap)
>  >  >  > My IOCs now are not built with libreadline, while in base 7.0.6.1 they were, again with no changes to the configure/os files.
>  >  >  > I see this change between base 7.0.6.1 and base 7.0.7
>  >  >  > corvette:base-7.0.7/configure/os>git diff R7.0.6.1 R7.0.7
>  >  >  > CONFIG_SITE.Common.linux-x
>  >  >  > CONFIG_SITE.Common.linux-x86
>  > CONFIG_SITE.Common.linux-x86_64
>  >  >  > CONFIG_SITE.Common.linux-xscale_be
>  >  >  > CONFIG_SITE.Common.linux-x86_64
>  >  >  > diff --git a/configure/os/CONFIG_SITE.Common.linux-x86_64
>  >  >  > b/configure/os/CONFIG_SITE.Common.linux-x86_64
>  >  >  > index e098b76..b98385f 100644
>  >  >  > --- a/configure/os/CONFIG_SITE.Common.linux-x86_64
>  >  >  > +++ b/configure/os/CONFIG_SITE.Common.linux-x86_64
>  >  >  > @@ -15,10 +15,6 @@
>  >  >  > #    to inform the system of the shared library location.
>  >  >  > -# Use GNU Readline if the header file is installed
>  >  >  > -COMMANDLINE_LIBRARY = $(strip $(if $(wildcard \
>  >  >  > -    $(GNU_DIR)/include/readline/readline.h), READLINE, EPICS))
>  >  >  > # If libreadline needs additional libraries to be linked with
>  > it, try
>  >  >  > # uncommenting each of the lines below in turn, starting with
>  > the top
>  >  >  > # one and working downwards, until the build succeeds. Do a 'make rebuild'
>  >  >  > The release notes say:
>  >  >  > *Automatic COMMANDLINE_LIBRARY w/ newer compilers*
>  >  >  > When built with a compiler supporting __has_include<>, the presence of the <readline/readline.h> will be used to automatically determine a default value for COMMANDLINE_LIBRARY.
>  >  >  > Mingw builds with readline support now link -ltermcap instead of -lcurses.
>  >  >  > This should not effect sites which set explicitly set COMMANDLINE_LIBRARY as the only definition in Base now has the form COMMANDLINE_LIBRARY ?= ....
>  >  >  > I interpret the first sentence here to mean that the test for
>  >  >  > COMMANDLINE_LIBRARY is done in the compiler if possible, but it
>  > does
>  >  >  > not say that the previous way of doing it in the CONFIG_SITE
>  > file (for
>  >  >  > older compilers) has been removed
>  >  >  > Does this mean that I now need to edit CONFIG_SITE.Common.linux-x86_64 to manually set COMMANDLINE_LIBRARY?
>  >  >  > Thanks,
>  >  >  > Mark
Re: readline in base 7.0.7 Michael Davidsaver via Core-talk
readline in base 7.0.7 Mark Rivers via Core-talk
RE: readline in base 7.0.7 Mark Rivers via Core-talk
Prev: Build failed: EPICS Base 7 base-7.0-694 AppVeyor via Core-talk
Next: Re: readline in base 7.0.7 Michael Davidsaver via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Prev: Re: readline in base 7.0.7 Michael Davidsaver via Core-talk
ANJ, 01 Oct 2022 · Home · News · About · Talk · Base · Modules · Extensions ·
