2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: Re: PVA Gateway (p4p) is Missing some Status PVs
From: "Murray, Doug via Core-talk" <core-talk at aps.anl.gov>
To: Michael Davidsaver <mdavidsaver at gmail.com>
Cc: EPICS CoreTalk <core-talk at aps.anl.gov>
Date: Fri, 25 Aug 2023 13:39:18 +0000
Hi Michael
The gethostbyname() is failing because it is being passed ‘[‘ as the hostname.
I should have included this trace; I haven’t had a chance to look much further.
2023-08-25 06:26:09,257 | p4p.server.thread: ERROR - Unexpected
Traceback (most recent call last):
  File "/afs/slac.stanford.edu/u/drm/work/p4p/bin/rhel6-x86_64/../../python3.6m/rhel6-x86_64/p4p/server/thread.py", line 19, in _on_queue
    M(*args)
  File "/afs/slac.stanford.edu/u/drm/work/p4p/bin/rhel6-x86_64/../../python3.6m/rhel6-x86_64/p4p/gw.py", line 35, in rpc
    ret = fn(self, op, **dict(op.value().query.items()))
  File "/afs/slac.stanford.edu/u/drm/work/p4p/bin/rhel6-x86_64/../../python3.6m/rhel6-x86_64/p4p/gw.py", line 445, in asTest
    peer = socket.gethostbyname(peer)
socket.gaierror: [Errno -2] Name or service not known
But I did add a print stmt in asTest which shows that op.peer is [::ffff:134.79.216.6]:43960 explaining why ‘peer’ is “[“ after the split(‘:’)[0]
cheers
-doug
From: Michael Davidsaver <mdavidsaver at gmail.com>
Date: Thursday, August 24, 2023 at 10:42 PM
To: Murray, Doug <drm at slac.stanford.edu>
Cc: Heinz Junkes <junkes at fhi-berlin.mpg.de>, EPICS CoreTalk <core-talk at aps.anl.gov>
On 8/24/23 13:43, Murray, Doug wrote:
> Thanks Heinz,
> I just pulled the latest p4p (also version 4.1.10) and :cache is working fine for me now!
> The ds:byhost:tx is doing something different,
> failing on a call to gethostbyname() in gw.py,
Do you have a stack trace for this?
I like DNS names, but only when they arrive promptly.  Which may not be the
case with gethostbyname().  So as a general rule, I try to avoid lookups
after startup.
> where the name is set to ‘[‘.  Why am I thinking this looks like IPv5?
😉 I’ll look into my network setup here…
> drm@aird-b50-srv01 01:30 PM 1187>pvget PGW:LCLSPB:ds:byhost:tx
> PGW:LCLSPUB:ds:byhost:tx 2023-08-24 13:31:01.656
> Account                        Client "TX (B/s)"
>      drm [::ffff:134.79.120.20]:52372    43.7333
>      drm [::ffff:134.79.216.24]:35854    5.93333
>      drm  [::ffff:134.79.216.6]:42150    5.93333
> cheers
> -doug
> *From: *Heinz Junkes <junkes at fhi-berlin.mpg.de>
> *Date: *Thursday, August 24, 2023 at 1:01 PM
> *To: *Michael Davidsaver <mdavidsaver at gmail.com>
> *Cc: *Murray, Doug <drm at slac.stanford.edu>, EPICS CoreTalk <core-talk at aps.anl.gov>
> *Subject: *Re: PVA Gateway (p4p) is Missing some Status PVs
> I can confirm that with p4p version: 4.1.10
> (base) hactar:~ junkes$ pvget FHIFEL:PVA_GW:STS:cache
> FHIFEL:PVA_GW:STS:cache <undefined>              []
> Still an empty list there.
> (base) hactar:~ junkes$ pvget FHIFEL:PVA_GW:STS:ds:byhost:tx
> FHIFEL:PVA_GW:STS:ds:byhost:tx 2023-08-24 21:54:49.296
> wieland 141.14.64.252:61925 1.20526e+06
> But ds:byhost:tx is ok.
> Heinz
>     On 24. Aug 2023, at 11:43, Michael Davidsaver via Core-talk <core-talk at aps.anl.gov> wrote:
>     On 8/23/23 09:56, Murray, Doug wrote:
>         We’ve been setting up the latest version of the p4p PVA Gateway (R4.1.9) and have noticed that a couple status PVs are no longer providing expected results.
>           * The *<statusprefix>cache* PV always returns an empty list, but previously provided “a list of channels to which the GW Client is connected”.
>     This was an oversight when porting to PVXS.  I had a couple of TODO items
>     which did not get marked as such.
>     https://github.com/mdavidsaver/p4p/commit/2930d9fcc0370ef3f292f5d24a46d1b4ef98f314#diff-8061cbf72533fa48d08f5f9891a94f5ebeaaffbba7f9e5cdae7aa10d594d09deR945
>           * The *<statusprefix>ds:byhost:tx* PV always provides the same client host address as 255.255.255.255, regardless of the client’s true IP address.
>     Can you provide some more detail?
>     My usual testing is all on one host with different ports.  So I can see
>     how I might not notice an issue like this.  However, I can check the port
>     numbers with the output of `netstat -tpn`.  From what I see, I think the
>     IP:port reported by in the ds: and us: tables are socket peer addresses.
>         These were working well in previous versions.  Has anybody else encountered this?
>         cheers
>         -doug
>         SLAC
Re: PVA Gateway (p4p) is Missing some Status PVs Michael Davidsaver via Core-talk
PVA Gateway (p4p) is Missing some Status PVs Murray, Doug via Core-talk
Re: PVA Gateway (p4p) is Missing some Status PVs Heinz Junkes via Core-talk
Re: PVA Gateway (p4p) is Missing some Status PVs Murray, Doug via Core-talk
Prev: Re: PVA Gateway (p4p) is Missing some Status PVs Michael Davidsaver via Core-talk
Next: Re: PVA Gateway (p4p) is Missing some Status PVs Michael Davidsaver via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
ANJ, 25 Aug 2023 · Home · News · About · Talk · Base · Modules · Extensions ·
