2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: Re: PVA Gateway (p4p) is Missing some Status PVs
From: Michael Davidsaver via Core-talk <core-talk at aps.anl.gov>
To: "Murray, Doug" <drm at slac.stanford.edu>
Cc: EPICS CoreTalk <core-talk at aps.anl.gov>
Date: Fri, 25 Aug 2023 16:43:03 +0200
On 8/25/23 06:39, Murray, Doug wrote:
Hi Michael
The gethostbyname() is failing because it is being passed ‘[‘ as the hostname.
I should have included this trace; I haven’t had a chance to look much further.
Ah, well.  I see where the problem is:
https://github.com/mdavidsaver/p4p/blob/37747cf1c495e997a4c4bf67a8eba9a37c50a665/src/p4p/gw.py#L439
still assumes IPv4 addressing.  (sigh... more IPv6 fun)  This may not be so quick to fix.
The ACF logic needs to account for the ambiguity of IPv4 vs. IPv4 mapped into IPv6.
In the interim, disabling IPv6 on that host would avoid the issue.
sudo sysctl net.ipv6.conf.all.disable_ipv6=1
fyi. At the moment, PVXS detects runtime IPv6 support by attempting to bind to "::1".
I see now that I should add another, PVXS specific, way to do so.
2023-08-25 06:26:09,257 | p4p.server.thread: ERROR - Unexpected
Traceback (most recent call last):
   File "/afs/slac.stanford.edu/u/drm/work/p4p/bin/rhel6-x86_64/../../python3.6m/rhel6-x86_64/p4p/server/thread.py", line 19, in _on_queue
     M(*args)
   File "/afs/slac.stanford.edu/u/drm/work/p4p/bin/rhel6-x86_64/../../python3.6m/rhel6-x86_64/p4p/gw.py", line 35, in rpc
     ret = fn(self, op, **dict(op.value().query.items()))
   File "/afs/slac.stanford.edu/u/drm/work/p4p/bin/rhel6-x86_64/../../python3.6m/rhel6-x86_64/p4p/gw.py", line 445, in asTest
     peer = socket.gethostbyname(peer)
socket.gaierror: [Errno -2] Name or service not known
But I did add a print stmt in asTest which shows that op.peer is *[::ffff:134.79.216.6]:43960* explaining why ‘peer’ is “[“ after the split(‘:’)[0]
cheers
-doug
*From: *Michael Davidsaver <mdavidsaver at gmail.com>
*Date: *Thursday, August 24, 2023 at 10:42 PM
*To: *Murray, Doug <drm at slac.stanford.edu>
*Cc: *Heinz Junkes <junkes at fhi-berlin.mpg.de>, EPICS CoreTalk <core-talk at aps.anl.gov>
*Subject: *Re: PVA Gateway (p4p) is Missing some Status PVs
On 8/24/23 13:43, Murray, Doug wrote:
Thanks Heinz,
I just pulled the latest p4p (also version 4.1.10) and :cache is working fine for me now!
The ds:byhost:tx is doing something different,
failing on a call to gethostbyname() in gw.py,
Do you have a stack trace for this?
I like DNS names, but only when they arrive promptly.  Which may not be the
case with gethostbyname().  So as a general rule, I try to avoid lookups
after startup.
where the name is set to ‘[‘.  Why am I thinking this looks like IPv5? 😉 I’ll look into my network setup here…
drm@aird-b50-srv01 01:30 PM 1187>pvget PGW:LCLSPB:ds:byhost:tx
PGW:LCLSPUB:ds:byhost:tx 2023-08-24 13:31:01.656
Account                        Client "TX (B/s)"
      drm [::ffff:134.79.120.20]:52372    43.7333
      drm [::ffff:134.79.216.24]:35854    5.93333
      drm  [::ffff:134.79.216.6]:42150    5.93333
cheers
-doug
*Date: *Thursday, August 24, 2023 at 1:01 PM
*To: *Michael Davidsaver <mdavidsaver at gmail.com>
*Cc: *Murray, Doug <drm at slac.stanford.edu>, EPICS CoreTalk <core-talk at aps.anl.gov>
I can confirm that with p4p version: 4.1.10
(base) hactar:~ junkes$ pvget FHIFEL:PVA_GW:STS:cache
FHIFEL:PVA_GW:STS:cache <undefined>              []
Still an empty list there.
(base) hactar:~ junkes$ pvget FHIFEL:PVA_GW:STS:ds:byhost:tx
FHIFEL:PVA_GW:STS:ds:byhost:tx 2023-08-24 21:54:49.296
wieland 141.14.64.252:61925 1.20526e+06
But ds:byhost:tx is ok.
Heinz
     On 24. Aug 2023, at 11:43, Michael Davidsaver via Core-talk <core-talk at aps.anl.gov> wrote:
     On 8/23/23 09:56, Murray, Doug wrote:
         We’ve been setting up the latest version of the p4p PVA Gateway (R4.1.9) and have noticed that a couple status PVs are no longer providing expected results.
           * The *<statusprefix>cache* PV always returns an empty list, but previously provided “a list of channels to which the GW Client is connected”.
     This was an oversight when porting to PVXS.  I had a couple of TODO items
     which did not get marked as such.
    https://github.com/mdavidsaver/p4p/commit/2930d9fcc0370ef3f292f5d24a46d1b4ef98f314#diff-8061cbf72533fa48d08f5f9891a94f5ebeaaffbba7f9e5cdae7aa10d594d09deR945 <https://github.com/mdavidsaver/p4p/commit/2930d9fcc0370ef3f292f5d24a46d1b4ef98f314#diff-8061cbf72533fa48d08f5f9891a94f5ebeaaffbba7f9e5cdae7aa10d594d09deR945>
           * The *<statusprefix>ds:byhost:tx* PV always provides the same client host address as 255.255.255.255, regardless of the client’s true IP address.
     Can you provide some more detail?
     My usual testing is all on one host with different ports.  So I can see
     how I might not notice an issue like this.  However, I can check the port
     numbers with the output of `netstat -tpn`.  From what I see, I think the
     IP:port reported by in the ds: and us: tables are socket peer addresses.
         These were working well in previous versions.  Has anybody else encountered this?
         cheers
         -doug
         SLAC
Re: PVA Gateway (p4p) is Missing some Status PVs Michael Davidsaver via Core-talk
PVA Gateway (p4p) is Missing some Status PVs Murray, Doug via Core-talk
Re: PVA Gateway (p4p) is Missing some Status PVs Heinz Junkes via Core-talk
Re: PVA Gateway (p4p) is Missing some Status PVs Murray, Doug via Core-talk
Prev: Re: PVA Gateway (p4p) is Missing some Status PVs Murray, Doug via Core-talk
Next: Build failed: epics-base base-7.0-967 AppVeyor via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Next: Re: PVA Gateway (p4p) is Missing some Status PVs Michael Davidsaver via Core-talk
ANJ, 29 Aug 2023 · Home · News · About · Talk · Base · Modules · Extensions ·
