2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: Re: PVA Gateway (p4p) is Missing some Status PVs
From: Michael Davidsaver via Core-talk <core-talk at aps.anl.gov>
To: "Murray, Doug" <drm at slac.stanford.edu>
Cc: EPICS CoreTalk <core-talk at aps.anl.gov>
Date: Tue, 29 Aug 2023 11:16:14 +0200
On 8/25/23 16:43, Michael Davidsaver wrote:
In the interim, disabling IPv6 on that host would avoid the issue.
sudo sysctl net.ipv6.conf.all.disable_ipv6=1
I have pushed a change which adds $PVXS_ENABLE_IPV6.  Setting
export PVXS_ENABLE_IPV6=NO
should prevent PVXS only from making use of IPv6.
https://github.com/mdavidsaver/pvxs/commit/058b3c914b59a3915dc57c416e28e4c54fd467fc
PVA Gateway (p4p) is Missing some Status PVs Murray, Doug via Core-talk
Re: PVA Gateway (p4p) is Missing some Status PVs Michael Davidsaver via Core-talk
Re: PVA Gateway (p4p) is Missing some Status PVs Heinz Junkes via Core-talk
Re: PVA Gateway (p4p) is Missing some Status PVs Murray, Doug via Core-talk
Prev: Build failed: EPICS Base 7 base-7.0-992 AppVeyor via Core-talk
Next: Build failed: epics-base base-integration-970 AppVeyor via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Prev: Re: PVA Gateway (p4p) is Missing some Status PVs Michael Davidsaver via Core-talk
Next: Build failed: epics-base base-7.0-967 AppVeyor via Core-talk
ANJ, 04 Sep 2023 · Home · News · About · Talk · Base · Modules · Extensions ·
