2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Base R3.16.0.1 ?
To: Michael Davidsaver <[email protected]>
Date: Thu, 3 Mar 2016 12:58:17 -0600
On 03/02/2016 06:15 PM, Andrew Johnson wrote:
> Ok, it's called 3 times by rsrv_build_addr_lists() at iocInit, and it's
> the middle time (beaconAddrList) that squawks:
The call to osiSockDiscoverBroadcastAddresses() is adding the address to
its output list twice. Cygwin uses the
libCom/osi/os/default/osdNetIntf.c implementation, so I rebuilt that
file with DEBUG to enable messages:
> Starting iocInit
> ## EPICS R3.15.3-DEV $$Date$$
> ## EPICS Base built Mar  2 2016
> ifreqNext() pifreq 0x600104c30, size 0x50, ifr 0x0x600104c80
> osiSockDiscoverBroadcastAddresses(): found IFACE: {6D740D7B-7CB5-4E95-8082-3858A0463BF0} len: 0x2c current_ifreqsize: 0x50
> found broadcast addr = a43616ff
> osiSockDiscoverBroadcastAddresses(): net intf "{6D740D7B-7CB5-4E95-8082-3858A0463BF0}" found
> ifreqNext() pifreq 0x600104c80, size 0x50, ifr 0x0x600104cd0
> osiSockDiscoverBroadcastAddresses(): found IFACE: {2BC35C5D-5E9B-44D1-844B-3E58710347AC} len: 0x2c current_ifreqsize: 0x50
> osiSockDiscoverBroadcastAddresses(): net intf "{2BC35C5D-5E9B-44D1-844B-3E58710347AC}" found
> ifreqNext() pifreq 0x600104cd0, size 0x50, ifr 0x0x600104d20
> osiSockDiscoverBroadcastAddresses(): found IFACE: {846EE342-7039-11DE-9D20-806E6F6E6963} len: 0x2c current_ifreqsize: 0x50
> osiSockDiscoverBroadcastAddresses(): net intf "{846EE342-7039-11DE-9D20-806E6F6E6963}": not point to point or bcast?
> Warning: Duplicate EPICS CA Address list entry "164.54.22.255:5065" discarded
> iocRun: All initialization complete
With display of the IFFLAGS parameter added there is a difference in the
flags:
> osiSockDiscoverBroadcastAddresses(): net intf "{6D740D7B-7CB5-4E95-8082-3858A0463BF0}" flags: 11043
> osiSockDiscoverBroadcastAddresses(): net intf "{2BC35C5D-5E9B-44D1-844B-3E58710347AC}" flags: 11003
> osiSockDiscoverBroadcastAddresses(): net intf "{846EE342-7039-11DE-9D20-806E6F6E6963}" flags: 11049
- Andrew
There are only two hard problems in distributed systems:
  2. Exactly-once delivery
  1. Guaranteed order of messages
 -- Mathias Verraes
Base R3.16.0.1 ? Andrew Johnson
Re: Base R3.16.0.1 ? Michael Davidsaver
Re: Base R3.16.0.1 ? Johnson, Andrew N.
Re: Base R3.16.0.1 ? Andrew Johnson
Prev: Re: Base R3.16.0.1 ? Andrew Johnson
Next: Build failed in Jenkins: epics-base-3.16-linux32-test #29 APS Jenkins
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Build failed in Jenkins: epics-base-3.15-win32-test #33 APS Jenkins
ANJ, 03 Mar 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
