1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: msi again
To: Benjamin Franksen <[email protected]>
Cc: [email protected]
Date: Tue, 24 Aug 2010 18:44:44 -0500
Hi Ben,
I agree with you on the semantics, with a couple of comments:
On Tuesday 24 August 2010 07:27:06 Benjamin Franksen wrote:
> We have two kinds of lists here that may be empty. By natural
> generalization of the above definition
> * an empty list-of-substitution-lists ("file xyz {}") means: do not insert
>   anything.
So does: file xyz { pattern {} }
Note that the pattern-names list there doesn't have to be empty, we should use
the (absence of) pattern-definition braces to control whether we insert
anything or not.
> * an empty list of substitutions means insert content of file with only
>   the global substitutions in scope (if any), thus "file xyz { {} {} }"
>   would insert the contents of file xyz twice.
Equivalent: file xyz { pattern {} {} }
I struggled to understand when anyone would want to use the "insert nothing"
meaning, but since "file xyz {} {}" would not be legal to insert the same file
twice, the distinction you make is sensible as it allows that.
Ok, on to the EBNF.  I have to be able to convert this grammar into Yacc for
the dbLoadTemplate.y implementation, so I've rewriten some of your suggestions
slightly, although the overall meaning should be the same.
> > substitution-file ::= ( global-definitions* template-substitutions+ )+
> This looks unnecessarily restrictive to me. Why not simply
>   substitution-file ::= ( global-definitions | template-substitutions )*
Ok.  My version required the file to end with a template-substitution, but if
we're being liberal about it I guess that doesn't matter.
> > global-definitions ::= 'global' '{' variable-definitions '}'
> > variable-definitions ::= variable-definition ( ',' variable-definition )*
> The comma between definitions is not always required currently (in msi).
dbLoadTemplate also makes the comma optional at present and we do need to keep
that behaviour, so agreed.
> I also (see above) want empty definition-lists, so my (counter-)proposal
> here is:
>   variable-definitions ::= ( variable-definition ','? )*
I accept the ability to write {} for empty lists, but when converting the EBNF
into Yacc syntax it's much easier to define rules that are never empty, making
their use conditional in the parent, thus:
global-definitions ::= 'global' '{' variable-definitions? '}'
variable-definitions ::= ( variable-definition ','? )+
> > template-substitutions ::= 'file' file-name '{' substitutions? '}'
> I'd rather push down the empty case into the variable-substitutions part
> (because the latter have a natural empty case, whereas a pattern-definition
> must start with a pattern-names clause). Thus
>   template-substitutions ::= 'file' file-name '{' substitutions '}'
Giving Yacc a rule that can match nothing generates shift/reduce conflict
warnings, which I hate seeing.  I would rather have the EBNF more closely
match the Yacc input, it makes development easier.  I did introduce another
rule BTW which the Yacc code uses to extract the filename:
template-substitutions ::= template-filename '{' substitutions? '}'
template-filename ::= 'file' file-name
> > substitutions ::= variable-substitutions | pattern-substitutions
> > variable-substitutions ::= '{' variable-definitions '}'
> This should be
>   variable-substitutions ::= ( '{' variable-definitions '}' )*
Empty rule again, I have:
variable-substitutions ::= ( '{' variable-definitions? '}' )+
> > pattern-substitutions ::=
> >     'pattern' '{' pattern-names '}' pattern-definitions
I have a question about the above rule: In Yacc I can easily express the fact
that you can't provide substitution values with no names for them thusly:
pattern_substitutions: PATTERN O_BRACE C_BRACE
    | PATTERN O_BRACE pattern_names C_BRACE
    | PATTERN O_BRACE pattern_names C_BRACE pattern_definitions
The following EBNF doesn't convey the same meaning though, it allows patterns
that the Yacc would reject:
    'pattern' '{' pattern-names? '}' pattern-definitions?
The closest I can come up with is this, but it doesn't map onto the Yacc code
terribly well since it takes 2 rules to Yacc's one:
pattern-substitutions ::= 'pattern' ( '{' '}' | pattern-block )
pattern-block ::= '{' pattern-names '}' pattern-definitions?
Do you have any better ideas?
>   pattern-names ::= ( variable-name ','? )*
Empty rule:
pattern-names ::= ( variable-name ','? )+
>   pattern-definitions ::= ( '{' pattern-values '}' )*
pattern-definitions ::= ( '{' pattern-values? '}' )+
>   pattern-values ::= ( value ','? )*
pattern-values ::= ( value ','? )+
> I'd like to agree with this proposal, as we already broke compatibility
> when introducing scopes, and I never understood the reason for being so
> liberal with variable names.
I have an explanation for that; it reduces the amount of code you have to
write in the lexer if you only have one definition for what Perl calls a
Bareword, i.e. something that you're really capturing as a string but you
don't want users to have to put quotes round.  dbLoadTemplate_lex.l has a
single token WORD it uses for all Bareword elements, and actually I'm not
quite sure how to tell it to look for a different kind of Bareword; normally
information flows from Lex to Yacc but not backwards (it probably involves
writing start states, which I haven't used before myself).
> In fact, I would further limit them to
>   variable-name ::= variable-name-start-char variable-name-char*
>   variable-name-start-char ::= [a-zA-Z]
>   variable-name-char ::= [a-zA-Z0-9_]
I would want to add _ to variable-name-start-char, but otherwise I agree with
those.  However...
> like in most programming languages (LISP being the only exception I am
> aware of). On the other hand, adapting substitution files to the new
> scoping rules is trivial (if tedious, just add the missing definitions),
> but adapting variable names could be quite disruptive; we might want to be
> careful here.
I think we have to leave the original name definitions in until 3.15 at least.
> For reference, I have attached the complete grammar with the changes I
> proposed.
Returning mine, which I have working in dbLoadTemplate.y.  The following a
working replacement for the regular makeBaseApp example template BTW:
# Example substitutions file
global { user = anjHost }
file "db/dbExample1.db" { {} }
global {
    scan = "$(no) second"
file db/dbExample2.db {
    pattern { no, scan }
        { 1 }
        { 2 }
        { 3, "5 second" }
- Andrew
The best FOSS code is written to be read by other humans -- Harald Welte
EBNF grammar for the template substitutions file format, to be understood
by msi and dbLoadTemplate.  These rules have been written to be easily
converted into a Yacc grammer, so they don't usually match nothing.
substitutions ::= pattern-substitutions | variable-substitutions
variable-definition ::= variable-name '=' value
These definitions are use by the lexer:
file-name ::= file-name-char+ | double-quoted-string | single-quoted-string
value ::= value-char+ | double-quoted-string | single-quoted-string
double-quoted-string ::= '"' (double-quoted-char | escaped-char)* '"'
single-quoted-string ::= "'" (single-quoted-char | escaped-char)* "'"
double-quoted-char ::= [^"\]
single-quoted-char ::= [^'\]
escaped-char ::= '\' .
In R3.15 we'd like to restrict the bareword characters to these:
variable-name-start-char ::= [a-zA-Z_]
file-name-char ::= [a-zA-Z0-9_+:./\] | '-'
value-char ::= [a-zA-Z0-9_+:./\<>;[] | '-' | ']'
but for R3.14.12 we'll stay with this for all of those:
*-char ::= [a-zA-Z0-9_+:./\<>;[] | '-' | ']'
Re: msi again Benjamin Franksen
Re: msi again Tim Mooney
Re: msi again Andrew Johnson
Prev: Re: Asyn and I/O intr scanning Hinko Kocevar
Next: ASYN 4-14 & AsynPortDriver class changes Euan.Troup
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: msi again Benjamin Franksen
Next: Re: msi again Benjamin Franksen
