Subject: Re: Proposed change in asyn - request for comments
Cc: [email protected]
Date: Thu, 31 May 2012 10:20:50 -0700
On May 31, 2012, at 9:17 AM, Andrew Johnson wrote:
> You wrote "device support interrupt callback or read method", which I
> originally read as the ISR, but it would be just as bad to set the TIME field
> in the port thread or a callback routine without first locking the lockset.
> If you meant that TIME gets set by the dset->read_xxx() routine then that's
> fine, because it gets called by the record's process routine with the lockset
> locked.  I wasn't really thinking about the limitations of interrupt context,
> it's that accessing a record's fields from any thread that has not first
> locked the record's lockset is not safe.
Right -- the actual setting of the .TIME field is done by the various devEpics  dset->read_xxx() routines.
Sorry to have implied anything different.
Proposed change in asyn - request for comments Mark Rivers
Re: Proposed change in asyn - request for comments Andrew Johnson
Re: Proposed change in asyn - request for comments Eric Norum
Prev: Re: Proposed change in asyn - request for comments Andrew Johnson
Next: waveform of STRING memory structure Pavel Masloff
Next: Re: Proposed change in asyn - request for comments Bruce Hill
