Ø
3) But after you said that edit the PATH , I did this. "export PATH=/opt/epics/base/bin/linux-x86_64"
Linux has a file that it executes every time you log in. Which file depends on which shell you are running. For the bash shell the file is .bash_profile in your home directory. You need to put your “export PATH” command in that file
like Pete Jemian described. You can load that file into any terminal without logging out by doing
source ~/.bash_profile
The next time you log in the PATH will be correct.
Sent: Friday, July 22, 2016 5:02 PM
To: Mark Rivers; Eric Norum; [email protected]
Subject: Re: How to configurate MCA for Octave
Thank you so much.. It works fine. But there is something that occurs when I change it.
According to the quick example that is Eric Norum's under this talk,
1) I make an IOC example with
"../../../makeBaseApp -t example example"
"../../../makeBaseApp -i -t example example"
I've got the same result as the same with Eric Norum's.
2) I run it. Again,I've got the same result. I mean that works fine.
And camonitor does not work in other terminal. If I edit it again on the current terminal, it works fine.
But under that terminal , when I try to do 4th step, which is runnig the Octave, there is an error that's saying it's a different path with Octave.
I am wondering, did I make a wrong building for Epics_Base at the beginning by setting the environment variables. Or is there another way to do it permanently for just Epics_Base path, for not the others (since I've got path error on the
same terminal while I have to run different apps.).When I edit it, the others (such as Octave) are changing in terms of PATH.
Thanks in advance.. Best Regards..
2016-07-23 0:38 GMT+03:00 Mark Rivers <[email protected]>:
That is your problem. You need to edit your login script to add /epics/base/bin/linux-x86_64 to your PATH environment variable. Then it will find camonitor when you type that
command.
Sent: Friday, July 22, 2016 4:36 PM
To: Mark Rivers; [email protected]
/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin
2016-07-23 0:29 GMT+03:00 Mark Rivers <[email protected]>:
I suspect the files are in base, but base is not in your path. Please send the output of
echo $PATH
What version of EPICS are you using? What does
ls -l /epics/base/bin/linux-x86_64
I was under the impression that caget/caput/camonitor and such had versions in base for quite some time.
It's on that path (/epics/base/bin/linux-x86_64). But when I type "which camonitor" , there is no response like
yours,sir.
- How to configurate MCA for Octave Hulusi Öz
- Re: How to configurate MCA for Octave Eric Norum
- Re: How to configurate MCA for Octave Hulusi Öz
- RE: How to configurate MCA for Octave Mark Rivers
Re: How to configurate MCA for Octave Pete Jemian
<2016>
<2016>
ANJ, 23 Jul 2016 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
