1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: OS X edm/medm openmotif woes
To: "Wang Xiaoqiang (PSI)" <[email protected]>
Cc: Eric Norum <[email protected]>, Epics <[email protected]>
Date: Wed, 16 Nov 2016 11:55:20 -0600
On 11/16, Wang Xiaoqiang (PSI) wrote:
> Hi Lewis,
> I just want to report my working setup of MEDM on macOS Sierra, with
> XQuartz 2.7.11.
Hi, Xiaoqiang!
Thank you for your report!
> I have installed openmotif from MacPorts
> $ port installed | grep openmotif
>   openmotif @2.3.4_3 (active)
> The medm (3.1.9) extension is configured like this
> $ cat configure/os/CONFIG_SITE.darwin-x86.darwin-x86
> # DarwinPorts OpenMotif
> X11_LIB=/opt/local/lib
> X11_INC=/opt/local/include
> MOTIF_LIB=/opt/local/lib
> MOTIF_INC=/opt/local/include
> I just tried a “make clean&&make”. That still works.
I suspect that still works because your Motif library (libXm) is using
the X Toolkit Intrinsics library (libXt) from MacPorts, not the one
from XQuartz.  Can you run the following command on your medm binary to
confirm?
--- 8< ---
$ otool -L ./medm
./medm:
	/opt/epics-3.14.12.5/lib/darwin-x86/libca.3.14.12.dylib (compatibility version 3.14.0, current version 3.14.12)
	/opt/epics-3.14.12.5/lib/darwin-x86/libCom.3.14.12.dylib (compatibility version 3.14.0, current version 3.14.12)
	/opt/pkg/lib/libXm.4.dylib (compatibility version 5.0.0, current version 5.4.0)
	/opt/X11/lib/libXt.6.dylib (compatibility version 7.0.0, current version 7.0.0)
	/opt/X11/lib/libXmu.6.dylib (compatibility version 9.0.0, current version 9.0.0)
	/opt/X11/lib/libX11.6.dylib (compatibility version 10.0.0, current version 10.0.0)
	/opt/X11/lib/libXext.6.dylib (compatibility version 11.0.0, current version 11.0.0)
	/usr/lib/libc++.1.dylib (compatibility version 1.0.0, current version 307.4.0)
	/usr/lib/libSystem.B.dylib (compatibility version 1.0.0, current version 1238.0.0)
--- >8 ---
As you can see, my medm is linked against /opt/X11/lib/libXt.6.dylib
which is provided by XQuartz.  I suspect yours will not be linked
against that one but rather against one from MacPorts.
Looking at the MacPorts Portfile for x11/openmotif, it contains a
depends_lib entry for port:xorg-libXt which means it depends on the
x11/xorg-libXt port.  It also contains this line:
  require_active_variants xorg-libXt flat_namespace
I think that means you would have to specify the flat_namespace
variant for the x11/xorg-libXt port.  And if you've specified
that variant for the x11/xorg-libXt port, then it links with
the flags "-Wl,-flat_namespace" which is probably how XQuartz's
/opt/X11/lib/flat_namespace/libXt.6.dylib was built.
So, I suspect if you did a fresh build of your MacPorts ports and did
not specify the flat_namespace variant for the x11/xorg-libXt port,
it would probably fail to build the x11/openmotif port.  Then if you
added the variant, it would probably succeed.  But libXt would not be
built as a two-level-namespace shared library; it would be built as a
flat-namespace shared library.  You can confirm this by looking for the
TWOLEVEL flag with otool:
--- 8< ---
$ otool -hv /opt/X11/lib/libXt.6.dylib
Mach header
      magic cputype cpusubtype  caps    filetype ncmds sizeofcmds      flags
MH_MAGIC_64  X86_64        ALL  0x00       DYLIB    19       2024   NOUNDEFS DYLDLINK TWOLEVEL NO_REEXPORTED_DYLIBS APP_EXTENSION_SAFE
$ otool -hv /opt/X11/lib/flat_namespace/libXt.6.dylib
Mach header
MH_MAGIC_64  X86_64        ALL  0x00       DYLIB    19       2024 DYLDLINK NO_REEXPORTED_DYLIBS APP_EXTENSION_SAFE
--- >8 ---
So, the flat-namespace shared library does not have the TWOLEVEL flag,
whereas the two-level-namespace shared library does.  I think your
MacPorts libXt will not have the TWOLEVEL flag; this means it is a
flat-namespace shared library.  And that should work, but it's similar
to my other workaround of moving the two-level-namespace libXt from
XQuartz out of the way and replacing it with XQuartz's flat-namespace
version.
Lewis
Re: OS X edm/medm openmotif woes Wang Xiaoqiang (PSI)
OS X edm/medm openmotif woes Eric Norum
Re: OS X edm/medm openmotif woes Jiro Fujita
Re: OS X edm/medm openmotif woes Eric Norum
Re: OS X edm/medm openmotif woes J. Lewis Muir
Prev: RE: OS X edm/medm openmotif woes Jemian, Pete R.
Next: Re: OS X edm/medm openmotif woes Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: OS X edm/medm openmotif woes Wang Xiaoqiang (PSI)
Next: Re: OS X edm/medm openmotif woes Wang Xiaoqiang (PSI)
ANJ, 17 Nov 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
