1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: OS X edm/medm openmotif woes
To: "J. Lewis Muir" <[email protected]>
Cc: Epics <[email protected]>
Date: Thu, 17 Nov 2016 12:18:00 +0000
Hi Lewis,
After checking, my medm is linked only to MacPorts libraries.
As you said, the key issue is the flat_namespace flag. Luckily Macports handles that automatically if the xorg-libXt is installed as a dependency to openmotif.
Best
Xiaoqiang
> On 16 Nov 2016, at 18:55, J. Lewis Muir <[email protected]> wrote:
> On 11/16, Wang Xiaoqiang (PSI) wrote:
>> Hi Lewis,
>> I just want to report my working setup of MEDM on macOS Sierra, with
>> XQuartz 2.7.11.
> Hi, Xiaoqiang!
> Thank you for your report!
>> I have installed openmotif from MacPorts
>> $ port installed | grep openmotif
>>  openmotif @2.3.4_3 (active)
>> The medm (3.1.9) extension is configured like this
>> $ cat configure/os/CONFIG_SITE.darwin-x86.darwin-x86
>> # DarwinPorts OpenMotif
>> X11_LIB=/opt/local/lib
>> X11_INC=/opt/local/include
>> MOTIF_LIB=/opt/local/lib
>> MOTIF_INC=/opt/local/include
>> I just tried a “make clean&&make”. That still works.
> I suspect that still works because your Motif library (libXm) is using
> the X Toolkit Intrinsics library (libXt) from MacPorts, not the one
> from XQuartz.  Can you run the following command on your medm binary to
> confirm?
> --- 8< ---
> $ otool -L ./medm
> ./medm:
> 	/opt/epics-3.14.12.5/lib/darwin-x86/libca.3.14.12.dylib (compatibility version 3.14.0, current version 3.14.12)
> 	/opt/epics-3.14.12.5/lib/darwin-x86/libCom.3.14.12.dylib (compatibility version 3.14.0, current version 3.14.12)
> 	/opt/pkg/lib/libXm.4.dylib (compatibility version 5.0.0, current version 5.4.0)
> 	/opt/X11/lib/libXt.6.dylib (compatibility version 7.0.0, current version 7.0.0)
> 	/opt/X11/lib/libXmu.6.dylib (compatibility version 9.0.0, current version 9.0.0)
> 	/opt/X11/lib/libX11.6.dylib (compatibility version 10.0.0, current version 10.0.0)
> 	/opt/X11/lib/libXext.6.dylib (compatibility version 11.0.0, current version 11.0.0)
> 	/usr/lib/libc++.1.dylib (compatibility version 1.0.0, current version 307.4.0)
> 	/usr/lib/libSystem.B.dylib (compatibility version 1.0.0, current version 1238.0.0)
> --- >8 ---
> As you can see, my medm is linked against /opt/X11/lib/libXt.6.dylib
> which is provided by XQuartz.  I suspect yours will not be linked
> against that one but rather against one from MacPorts.
> Looking at the MacPorts Portfile for x11/openmotif, it contains a
> depends_lib entry for port:xorg-libXt which means it depends on the
> x11/xorg-libXt port.  It also contains this line:
>  require_active_variants xorg-libXt flat_namespace
> I think that means you would have to specify the flat_namespace
> variant for the x11/xorg-libXt port.  And if you've specified
> that variant for the x11/xorg-libXt port, then it links with
> the flags "-Wl,-flat_namespace" which is probably how XQuartz's
> /opt/X11/lib/flat_namespace/libXt.6.dylib was built.
> So, I suspect if you did a fresh build of your MacPorts ports and did
> not specify the flat_namespace variant for the x11/xorg-libXt port,
> it would probably fail to build the x11/openmotif port.  Then if you
> added the variant, it would probably succeed.  But libXt would not be
> built as a two-level-namespace shared library; it would be built as a
> flat-namespace shared library.  You can confirm this by looking for the
> TWOLEVEL flag with otool:
> --- 8< ---
> $ otool -hv /opt/X11/lib/libXt.6.dylib
> Mach header
>      magic cputype cpusubtype  caps    filetype ncmds sizeofcmds      flags
> MH_MAGIC_64  X86_64        ALL  0x00       DYLIB    19       2024   NOUNDEFS DYLDLINK TWOLEVEL NO_REEXPORTED_DYLIBS APP_EXTENSION_SAFE
> $ otool -hv /opt/X11/lib/flat_namespace/libXt.6.dylib
> Mach header
> MH_MAGIC_64  X86_64        ALL  0x00       DYLIB    19       2024 DYLDLINK NO_REEXPORTED_DYLIBS APP_EXTENSION_SAFE
> --- >8 ---
> So, the flat-namespace shared library does not have the TWOLEVEL flag,
> whereas the two-level-namespace shared library does.  I think your
> MacPorts libXt will not have the TWOLEVEL flag; this means it is a
> flat-namespace shared library.  And that should work, but it's similar
> to my other workaround of moving the two-level-namespace libXt from
> XQuartz out of the way and replacing it with XQuartz's flat-namespace
> version.
> Regards,
> Lewis
Re: OS X edm/medm openmotif woes J. Lewis Muir
OS X edm/medm openmotif woes Eric Norum
Re: OS X edm/medm openmotif woes Jiro Fujita
Re: OS X edm/medm openmotif woes Eric Norum
Re: OS X edm/medm openmotif woes Wang Xiaoqiang (PSI)
Prev: RE: how to unsubscribe michael.abbott
Next: RE: ERROR -111 in Keithley6485 Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: OS X edm/medm openmotif woes J. Lewis Muir
Next: Re: OS X edm/medm openmotif woes J. Lewis Muir
ANJ, 17 Nov 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
