1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024
Subject: Re: caget randomly returns Channel connect timed out
To: [email protected]
Cc: Talk EPICS Tech <[email protected]>
Date: Wed, 18 Jul 2018 08:38:56 -1000
The switches at both of our telescope in Hawaii and Chile use the Cisco Catalyst 2650S.
We're still organizing someone to capture packets with wireshark.
-Matt
On Wed, Jul 18, 2018 at 2:11 AM Dirk Zimoch <[email protected]> wrote:
>> For the record, can you find out if that Cisco solution is specific to a
>> particular model or family of switches, or if they made it generic?
> I will try to find out.
For the records: Our switches are Cisco Catalyst 3850.
Dirk
caget randomly returns Channel connect timed out Matt Rippa
Re: caget randomly returns Channel connect timed out Andrew Johnson
Re: caget randomly returns Channel connect timed out Michael Davidsaver
Re: caget randomly returns Channel connect timed out Matt Rippa
Re: caget randomly returns Channel connect timed out Dirk Zimoch via Tech-talk
RE: caget randomly returns Channel connect timed out Mark Rivers
Prev: Re: Rotating Image in NDPluginPva plugin Michael Davidsaver
Next: Re: Delta Tau Power Brick LV-IMS driver [email protected]
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024
Prev: Re: caget randomly returns Channel connect timed out Dirk Zimoch
Next: Mettler Toledo New Classic ML Pearson, Matthew R.
ANJ, 19 Jul 2018 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
