Hi Jong Woo,
You have not told us what version of ADEiger, ADCore, EPICS base, etc. you are using.
Ø
a) It keeps failing to open 'sseq_setting.req' file (Purple in the following message)
Did you uncomment this line from ADCore/iocBoot/EXAMPLE_commonPlugin_settings.req?
#file "sseqRecord_settings.req", P=$(P), S=AcquireSequence
If so you also need to uncomment this line from ADCore/iocBoot/EXAMPLE_commonPlugins.cmd
#set_requestfile_path("$(CALC)/calcApp/Db")
Ø
b) It keeps failing to writing 'auto_settings.sav' file (Blue in the following message)
Ø
../save_restore.c(1774): [0xd]=write_it:Permission denied
That error seems pretty simple. It is a file permission problem. The files in that directory, or the directory itself, must not have write permission for the account that is running ADEiger application. Fix the file permissions.
Ø
c) When the data acquisition is done on eigerDetector, it crashes EPICS IOC
(Red in the following message)
Ø
Actually data hasn't been collected
Segmentation fault (core dumped)
You have a core dump file. You need to run gdb on that to find where it crashed.
Run this:
gdb /path/to/ADEiger_executable core.xxx
where core.xxx is the name of your core dump file. Once you get the gdb> prompt type this command
backtrace
When the data collection is done on 'eigerDetector.adl', EPICS IOC is crashed and actually data hasn't been collected.
In addition, whatever parameters I changed on 'eigerDetector' are not applied in autosave. These are the summary followed by the message.
I made sure that this file has contents and it is in a right folder
support/calc-R3-7-3/calcApp/Db/sseq_settings.req
support/calc-R3-7-3/db/sseq_settings.req
It keeps trying to save settings every 30 second as it is set on the first purple line. But it can't.
--------------------------------------------------- Message on monitor--------------------------------------------------------------
## EPICS R3.15.6
## EPICS Base built Dec 2 2019
reboot_restore: entry for file 'auto_settings.sav'
reboot_restore: Found filename 'auto_settings.sav' in restoreFileList.
*** restoring from './autosave/auto_settings.sav' at initHookState 6 (before record/device init) ***
save_restore:myFileCopy: Can't open file './autosave/auto_settings.sav_200127-151325'
save_restore: Can't write backup file.
2020/01/27 15:13:25.455 asynPortDriver:drvUserCreate: addr=0, cannot find parameter CLEAR
EIG1:cam1:FWClear devAsynInt32::initCommon drvUserCreate
Bad init_rec return value PV: EIG1:cam1:FWClear ao: init_record
*** restoring from './autosave/auto_settings.sav' at initHookState 7 (after record/device init) ***
reboot_restore: done with file 'auto_settings.sav'
# Avoid deluge of messages when debugging
#dbpf $(PREFIX)cam1:PoolUsedMem.SCAN Passive
# save things every thirty seconds
create_monitor_set("auto_settings.req", 30, "P= EIG1:")
save_restore:readReqFile: unable to open file sseq_settings.req. Exiting.
epics> save_restore: Can't connect to all status PV(s)
auto_settings.sav: 1330 of 1330 PV's connected
save_restore: Can't connect to status PV(s) for list 'auto_settings.sav'
save_restore:write_it - unable to open file './autosave/auto_settings.sav' [200127-151357]
save_restore:write_save_file: Can't write save file. [200127-151357]
save_restore:write_it - unable to open file './autosave/auto_settings.sav' [200127-151427]
save_restore:write_save_file: Can't write save file. [200127-151427]
[iocEiger]$
