Subject: Re: CA output links not working with PINI=YES?
From: "Mooney, Tim M. via Tech-talk" <[email protected]>
To: "Johnson, Andrew N. via Tech-talk" <[email protected]>, "Benjamin Franksen" <[email protected]>
Date: Thu, 5 Mar 2020 19:28:25 +0000
I had a similar problem, and solved it by using a scan task to trigger processing of the record whose operation could not work until channel access was up.  (EPICS starts scan tasks after channel access.)  Here's a code fragment from the table_soft.vdb database in the synApps optics module:
initLastMotor processes once, after channel access is up, and then sets its SCAN field to "Passive"
---snip---
# Strategy: We need to find out when all motors have finished executing a move
# that we started.  To do this without a race condition, we set a gate PV to
# "open", write to motors, and then have the last motor written to set the gate
# PV to "closed" when it finishes.  But we don't know which motor will be the
# last motor written to, because the table record can work with fewer than six
# motors, and we don't know which motors don't actually exist.
# $(P)$(Q):lastMotor figures this out at init time.
# Evidently, $(P)$(Q):lastMotor's PINI==RUNNING field isn't getting
# $(P)$(Q):closeGate.INPA initialized.  This seems bulletproof.
record(scalcout, "$(P)$(Q):initLastMotor") {
#field(TPRO, "1")
field(SCAN, "10 second")
# Note that this must be a CA link so it can read a link field
field(INAA, "$(P)$(Q):closeGate.INPA CA")
field(CALC, "aa==''")
field(OOPT, "When Zero")
field(DOPT, "Use OCAL")
field(OCAL, "'Passive'")
field(OUT, "$(P)$(Q):initLastMotor.SCAN CA")
field(FLNK, "$(P)$(Q):lastMotor")
# Find the last motor that will be written to.  (Ignore motors that
# don't actually exist.)  Write that motor's .DMOV PV
record(scalcout, "$(P)$(Q):lastMotor") {
  field(CALC, "(f?ff:e?ee:d?dd:c?cc:b?bb:aa)[0,' ']+' CP'")
  field(INPA, "$(P)$(Q):dmov.INAV CA")
  field(INPB, "$(P)$(Q):dmov.INBV CA")
  field(INPC, "$(P)$(Q):dmov.INCV CA")
  field(INPD, "$(P)$(Q):dmov.INDV CA")
  field(INPE, "$(P)$(Q):dmov.INEV CA")
  field(INPF, "$(P)$(Q):dmov.INFV CA")
  field(INAA, "$(P)$(Q):dmov.INPA CA")
  field(INBB, "$(P)$(Q):dmov.INPB CA")
  field(INCC, "$(P)$(Q):dmov.INPC CA")
  field(INDD, "$(P)$(Q):dmov.INPD CA")
  field(INEE, "$(P)$(Q):dmov.INPE CA")
  field(INFF, "$(P)$(Q):dmov.INPF CA")
  field(PINI, "RUNNING")
  field(OUT, "$(P)$(Q):closeGate.INPA CA")
---snip---
Tim Mooney ([email protected]) (630)252-5417
Beamline Controls Group (www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
From: Tech-talk <[email protected]> on behalf of Johnson, Andrew N. via Tech-talk <[email protected]>
Sent: Thursday, March 5, 2020 12:58 PM
To: Benjamin Franksen <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Hi Ben,
On Mar 5, 2020, at 12:16 PM, Benjamin Franksen via Tech-talk <[email protected]> wrote:
What we want to do here is write a string to an input link field once at
init time. Link fields can be written to only via CA, which is why we
have to use a CA link.
Do you have to wait until after iocInit to set the value of that input link field? If you could do it beforehand you could load a separate .db file that just sets the link field of that record. You can also use the IOC’s ‘dbpf’ command to write to a link field in your startup script, and the length of that string isn’t limited to 40 characters any more.
Christoph’s original example doesn’t show him writing to a link field, and I’m still a little confused exactly what you’re trying to do. Given the actual complexity of what you’re trying to do (as against the apparent simplicity that you’re wanting) I suspect using a sequence program might be simpler, but more detail of the actual problem might allow us to find a simpler solution.
- Andrew
Complexity comes for free, Simplicity you have to work for.
CA output links not working with PINI=YES? Christoph Schroeder via Tech-talk
Re: CA output links not working with PINI=YES? J. Lewis Muir via Tech-talk
Re: CA output links not working with PINI=YES? Christoph Schroeder via Tech-talk
Re: CA output links not working with PINI=YES? Ralph Lange via Tech-talk
Re: CA output links not working with PINI=YES? Benjamin Franksen via Tech-talk
Re: CA output links not working with PINI=YES? Johnson, Andrew N. via Tech-talk
Prev: Re: CA output links not working with PINI=YES? Johnson, Andrew N. via Tech-talk
Next: Re: Real-time IOC and systemd Benjamin Franksen via Tech-talk
Next: Re: CA output links not working with PINI=YES? Benjamin Franksen via Tech-talk
