Subject: Re: Strange problem with areaDetector driver
To: Jörn Dreyer <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Wed, 27 May 2020 12:46:09 +0000
Hi Jörn,
> I ran into a severe problem in the image readout handler.
> When calling doCallbackGenericPointer() the IOC creates every time a couple of  new threads and consumes lot of CPU power ( 300% on a quad core).
First a few questions:
Is this Linux or Windows?
What frame rate are you using?
What plugins are running?
Is the CS-Studio GUI on the same machine as the IOC or a different machine?
The first thing to establish is whether the problem is the areaDetector IOC or the CS-Studio client.  I suggest you do the following:
-  Disable all plugins except NDPluginStdArrays for testing.
- Exit CS-Studio so there is no display client running.  What is the CPU load under those conditions?
- Try the ImageJ viewer instead of CS-Studio for testing.  Does that also have the problem?
From: Tech-talk <[email protected]> on behalf of Jörn Dreyer via Tech-talk <[email protected]>
Sent: Wednesday, May 27, 2020 7:03 AM
To: [email protected]
Subject: Strange problem with areaDetector driver
Hello,
currently I have a very strange problem in a code I'm developing to read out
cameras from ZWO. I ran into a severe problem in the image readout handler.
new threads and consumes lot of CPU power ( 300% on a quad core). So after a
very short time the system becomes unresponsive and has to be switched off.
The image is 3520*4656 bytes in size and is in monochrome mode, so UInt8 as
data type.
In a GUI (CS-Studio) that is displaying the image data as Intensity graph I
observe a "disconnect" state for every cycle of the image, once the NDStdArray
has been enabled. In between it shows "No data".
Has anybody seen such behavior before? Any ideas welcome how to search for the
reason of this.
Jörn Dreyer
Re: Strange problem with areaDetector driver Jörn Dreyer via Tech-talk
Prev: Strange problem with areaDetector driver Jörn Dreyer via Tech-talk
Next: Re: Strange problem with areaDetector driver Jörn Dreyer via Tech-talk
