Subject: Re: Strange problem with areaDetector driver
From: Jörn Dreyer via Tech-talk <[email protected]>
To: [email protected]
Date: Wed, 27 May 2020 15:55:39 +0200
Am Mittwoch, 27. Mai 2020, 14:46:09 CEST schrieb Mark Rivers:
> Hi Jörn,
> > I ran into a severe problem in the image readout handler.
> > When calling doCallbackGenericPointer() the IOC creates every time a
> > couple of  new threads and consumes lot of CPU power ( 300% on a quad
> > core).
> First a few questions:
> Is this Linux or Windows?
Linux
> What frame rate are you using?
0.5 Hz
> What plugins are running?
Only NDStdArray.
> Is the CS-Studio GUI on the same machine as the IOC or a different machine?
On the same machine
> The first thing to establish is whether the problem is the areaDetector IOC
> or the CS-Studio client.  I suggest you do the following:
> -  Disable all plugins except NDPluginStdArrays for testing.
Done,
> - Exit CS-Studio so there is no display client running.  What is the CPU
> load under those conditions?
Closed the OPI screen that shows the image. Now the number of threads is
constant. System load is at normal level.
> - Try the ImageJ viewer instead of CS-Studio for testing.  Does that also
> have the problem?
Will need some time to gat that going. Java on my system seems to have problem
with the code.
Jörn
> Mark
> ________________________________
> From: Tech-talk <[email protected]> on behalf of Jörn Dreyer via
> Tech-talk <[email protected]> Sent: Wednesday, May 27, 2020 7:03 AM
> Subject: Strange problem with areaDetector driver
> Hello,
> currently I have a very strange problem in a code I'm developing to read out
> cameras from ZWO. I ran into a severe problem in the image readout handler.
> When calling doCallbackGenericPointer() the IOC creates every time a couple
> of new threads and consumes lot of CPU power ( 300% on a quad core). So
> after a very short time the system becomes unresponsive and has to be
> switched off. The image is 3520*4656 bytes in size and is in monochrome
> mode, so UInt8 as data type.
> In a GUI (CS-Studio) that is displaying the image data as Intensity graph I
> observe a "disconnect" state for every cycle of the image, once the
> NDStdArray has been enabled. In between it shows "No data".
> Has anybody seen such behavior before? Any ideas welcome how to search for
> the reason of this.
> Regards,
> Jörn Dreyer
RE: Strange problem with areaDetector driver Mark Rivers via Tech-talk
Strange problem with areaDetector driver Jörn Dreyer via Tech-talk
Re: Strange problem with areaDetector driver Mark Rivers via Tech-talk
Prev: Re: Strange problem with areaDetector driver Mark Rivers via Tech-talk
Next: RE: Strange problem with areaDetector driver Mark Rivers via Tech-talk
