1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025
Subject: RE: Strange problem with areaDetector driver
From: Mark Rivers via Tech-talk <tech-talk at aps.anl.gov>
To: 'Jörn Dreyer' <j.dreyer at hzdr.de>
Cc: tech-talk <tech-talk at aps.anl.gov>
Date: Wed, 27 May 2020 14:10:26 +0000
> Closed the OPI screen that shows the image. Now the number of threads is constant. System load is at normal level.
When you saw the threads and high system load did you use top -H to see whether the threads with high CPU load were CSS threads or IOC threads? I suspect they are CSS threads.
> Will need some time to gat that going. Java on my system seems to have problem with the code.
ImageJ on both Linux and Windows comes with its own version of Java in the ImageJ/jre directory, so it should be completely independent of your system version of Java.  Get the latest version of the ImageJ zip file and install it in your own directory so you don't need to worry about system permissions, etc.
-----Original Message-----
From: Tech-talk <tech-talk-bounces at aps.anl.gov> On Behalf Of Jörn Dreyer via Tech-talk
Sent: Wednesday, May 27, 2020 8:56 AM
To: tech-talk at aps.anl.gov
Subject: Re: Strange problem with areaDetector driver
Am Mittwoch, 27. Mai 2020, 14:46:09 CEST schrieb Mark Rivers:
> Hi Jörn,
> > I ran into a severe problem in the image readout handler.
> > When calling doCallbackGenericPointer() the IOC creates every time a
> > couple of  new threads and consumes lot of CPU power ( 300% on a
> > quad core).
> First a few questions:
> Is this Linux or Windows?
Linux
> What frame rate are you using?
0.5 Hz
> What plugins are running?
Only NDStdArray.
> Is the CS-Studio GUI on the same machine as the IOC or a different machine?
On the same machine
> The first thing to establish is whether the problem is the
> areaDetector IOC or the CS-Studio client.  I suggest you do the following:
> -  Disable all plugins except NDPluginStdArrays for testing.
Done,
> - Exit CS-Studio so there is no display client running.  What is the
> CPU load under those conditions?
> - Try the ImageJ viewer instead of CS-Studio for testing.  Does that
> also have the problem?
Jörn
> Mark
> ________________________________
> From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Jörn
> Dreyer via Tech-talk <tech-talk at aps.anl.gov> Sent: Wednesday, May 27,
> 2020 7:03 AM
> Subject: Strange problem with areaDetector driver
> Hello,
> currently I have a very strange problem in a code I'm developing to
> read out cameras from ZWO. I ran into a severe problem in the image readout handler.
> couple of new threads and consumes lot of CPU power ( 300% on a quad
> core). So after a very short time the system becomes unresponsive and
> has to be switched off. The image is 3520*4656 bytes in size and is in
> monochrome mode, so UInt8 as data type.
> In a GUI (CS-Studio) that is displaying the image data as Intensity
> graph I observe a "disconnect" state for every cycle of the image,
> once the NDStdArray has been enabled. In between it shows "No data".
> Has anybody seen such behavior before? Any ideas welcome how to search
> for the reason of this.
> Regards,
> Jörn Dreyer
Re: Strange problem with areaDetector driver Jörn Dreyer via Tech-talk
Re: Strange problem with areaDetector driver Mark Rivers via Tech-talk
Prev: Re: Strange problem with areaDetector driver Jörn Dreyer via Tech-talk
Next: Re: SoftIOC and Labview Paul Sichta via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025
Next: Re: Strange problem with areaDetector driver Jörn Dreyer via Tech-talk
ANJ, 28 May 2020 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
