Am Mittwoch, 27. Mai 2020, 16:10:26 CEST schrieb Mark Rivers via Tech-talk: > > Closed the OPI screen that shows the image. Now the number of threads is > > constant. System load is at normal level. > When you saw the threads and high system load did you use top -H to see > whether the threads with high CPU load were CSS threads or IOC threads? I > suspect they are CSS threads. No they are all started from the IOC. After 300 threads spawned I decided to stop the IOC. I used
ps -eLF | grep st.cmd | wc
> > Will need some time to gat that going. Java on my system seems to have > > problem with the code. > ImageJ on both Linux and Windows comes with its own version of Java in the > ImageJ/jre directory, so it should be completely independent of your system > version of Java. Get the latest version of the ImageJ zip file and install > it in your own directory so you don't need to worry about system > permissions, etc. I got it working, but there seems to be a problem that only half of the image is intrerpreted correctly. The ArrayType is UInt16 instead of UInt8. Will need to find out teh reason for that.
J�/p>
> > Mark > > > > -----Original Message----- > From: Tech-talk <tech-talk-bounces at aps.anl.gov> On Behalf Of J�Dreyer via > Tech-talk Sent: Wednesday, May 27, 2020 8:56 AM > To: tech-talk at aps.anl.gov > Subject: Re: Strange problem with areaDetector driver > > Am Mittwoch, 27. Mai 2020, 14:46:09 CEST schrieb Mark Rivers: > > Hi J� > > > > > I ran into a severe problem in the image readout handler. > > > > > > When calling doCallbackGenericPointer() the IOC creates every time a > > > couple of new threads and consumes lot of CPU power ( 300% on a > > > quad core). > > > > First a few questions: > > > > > > Is this Linux or Windows? > > Linux > > > What frame rate are you using? > > 0.5 Hz > > > What plugins are running? > > Only NDStdArray. > > > Is the CS-Studio GUI on the same machine as the IOC or a different > > machine? > > On the same machine > > > The first thing to establish is whether the problem is the > > areaDetector IOC or the CS-Studio client. I suggest you do the following: > > > > > > - Disable all plugins except NDPluginStdArrays for testing. > > Done, > > > - Exit CS-Studio so there is no display client running. What is the > > CPU load under those conditions? > > Closed the OPI screen that shows the image. Now the number of threads is > constant. System load is at normal level. > > - Try the ImageJ viewer instead of CS-Studio for testing. Does that > > also have the problem? > > Will need some time to gat that going. Java on my system seems to have > problem with the code. > > Regards, > > J�/p> > > > Mark > > > > > > > > > > > > ________________________________ > > From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of J�/p> > > Dreyer via Tech-talk <tech-talk at aps.anl.gov> Sent: Wednesday, May 27, > > 2020 7:03 AM > > To: tech-talk at aps.anl.gov > > Subject: Strange problem with areaDetector driver > > > > Hello, > > > > currently I have a very strange problem in a code I'm developing to > > read out cameras from ZWO. I ran into a severe problem in the image > > readout handler. When calling doCallbackGenericPointer() the IOC creates > > every time a couple of new threads and consumes lot of CPU power ( 300% > > on a quad core). So after a very short time the system becomes > > unresponsive and has to be switched off. The image is 3520*4656 bytes in > > size and is in monochrome mode, so UInt8 as data type. > > > > In a GUI (CS-Studio) that is displaying the image data as Intensity > > graph I observe a "disconnect" state for every cycle of the image, > > once the NDStdArray has been enabled. In between it shows "No data". > > > > Has anybody seen such behavior before? Any ideas welcome how to search > > for the reason of this. > > > > Regards, > > > > J�Dreyer
ANJ, 28 May 2020 |
![]() · Download · Search · IRMIS · Talk · Documents · Links · Licensing · |
