Jalal, I looked in my 3.14.12.5 IOC's database and I write DOUBLE from LabVIEW using the NI-supplied software. Here is my record;
grecord(waveform,"tc_nbBoard1_WF") { field(DESC,"Temperatures array") field(ASG,"OPEN") field(PINI,"YES") field(DTYP,"Soft Channel") field(NELM,"80") field(FTVL,"DOUBLE") }
This worked with labview 2014 and 2016. Haven't tried newer versions.
-ps
Jalal, I was able to r/w using U32 data to a waveform record. I'd have to dig a little to resurrect the details, perhaps later.
-ps
Writing double scalar values to a ai record works great.
I tried both aai and waveform to write array values of doubles but no success.
I am using LabView 2018 SP1. Do you have a list of what's working and what's not?
Best,
Jalal
Jalal,
Can your labview write scalar values (e.g. to a longin record ) to your softioc?
Have you tried writing your labview array to a waveform record on the softioc?
Using earlier versions of the NI EPICS software, I seem to recall there were some data types that wouldn't work (I think double was OK). I haven't tried the 2020 version but glad to see it has been updated.
-ps
Hi All!
I am trying to write an array of doubles from a LabView EPICS Client using
EPICS Client I/O Server to a softIoc instance with the corresponding record:
record(aai, "dummy:array")
field(NELM, "10")
field(FTVL, "DOUBLE")
I can see the LabVIEW being connected to this record but no written values to
softIoc instance. The issue is only happening on LabView but not when using other clients like caput for instance.
What is the correct way to write array values from LabView to softIoc records?
Best,
Jalal
- Re: SoftIOC and Labview Mostafa, Jalal (IPE) via Tech-talk
- SoftIOC and Labview Mostafa, Jalal (IPE) via Tech-talk
- Re: SoftIOC and Labview Paul Sichta via Tech-talk
RE: Strange problem with areaDetector driver Mark Rivers via Tech-talk
Re: Unpredictable behaviour with PyEpics Matt Newville via Tech-talk
<2020>
RE: SoftIOC and Labview Kathryn Baker - UKRI STFC via Tech-talk
<2020>
ANJ, 31 May 2020 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
