On 6/18/20 9:18 AM, Ralph Lange via Tech-talk wrote:
> On Thu, 18 Jun 2020 at 17:37, Michael Davidsaver <mdavidsaver at gmail.com <mailto:mdavidsaver at gmail.com>> wrote:
> Why not bake procServ into the IOC executable? It could still fork() off the a child process for the actual IOC, but without an execvp().
> (or at worst, to re-exec the same executable)
> Of course fork() from a multi-threaded process needs some care.
> As well as attention to FD_CLOEXEC.
> As you know, the traditional Linux approach is to break up applications with large complex functionality into small independent units that each serve a narrow scope of purpose and can be combined on the command line.
> procServ is following that approach.
Quite true. And imo this should continue to be an option.
I guess I'm just not such an orthodox UNIX head to see this
as a reason not to try a new idea.
> Looking at the list of command line options and features of procServ (that were all added on user request btw.) - do you want all this being part of the IOC?
Those that apply. Sure.
> Your idea sounds a lot like the CA Gateway's quirky server mode - that IMHO should be deprecated in favor of running it under procServ, to put an end to running two hardly distinguishable processes for each Gateway instance.
Ok, it was only a passing thought.
signature.asc
Description: OpenPGP digital signature
- How to run IOC in docker containers properly xiao zhang via Tech-talk
- Re: How to run IOC in docker containers properly Johnson, Andrew N. via Tech-talk
- Re: How to run IOC in docker containers properly Ben Franksen via Tech-talk
- Re: How to run IOC in docker containers properly J. Lewis Muir via Tech-talk
- Re: How to run IOC in docker containers properly Konrad, Martin via Tech-talk
- Re: How to run IOC in docker containers properly Michael Davidsaver via Tech-talk
- Re: How to run IOC in docker containers properly Ralph Lange via Tech-talk
Re: How to run IOC in docker containers properly Jeong Han Lee via Tech-talk
<2020>
Re: How to run IOC in docker containers properly Eric Norum via Tech-talk
<2020>
