Subject: Re: Stream device - general concept how to use
From: Ralph Lange via Tech-talk <[email protected]>
To: EPICS Tech Talk <[email protected]>
Date: Thu, 16 Jul 2020 16:09:20 +0200
On Thu, 16 Jul 2020 at 15:12, Arnold, Ned D. via Tech-talk <[email protected]> wrote:
I think you could do both of Mark's suggestion at the same time yielding periodically scanned status records that also get scanned immediately when an associated "set" record is written to.
Yep.
Manual on-demand scanning could be implemented with an OPI button that writes to the record's PROC field.
Sometimes I have seen different scan rates being applied based (using a seq record) on device status: poll fast when things are "moving", poll slow when things are not.
BTW. This issue is not particular to StreamDevice at all.
Any readback from a device that has to be actively polled will act the same way.
Cheers,
~Ralph
Stream device - general concept how to use Christian Pauly via Tech-talk
Re: Stream device - general concept how to use Mark Rivers via Tech-talk
Re: Stream device - general concept how to use Arnold, Ned D. via Tech-talk
Prev: PowerMaster II device support? DiMonte, Nicholas via Tech-talk
Next: RE: Modbus alarms question Mark Rivers via Tech-talk
Prev: Re: Stream device - general concept how to use Arnold, Ned D. via Tech-talk
Next: Re: Stream device - general concept how to use Christian Pauly via Tech-talk
