Subject: Re: Stream device - general concept how to use
From: Christian Pauly via Tech-talk <[email protected]>
To: "Arnold, Ned D." <[email protected]>, "Rivers, Mark L." <[email protected]>
Date: Thu, 16 Jul 2020 17:55:53 +0200
Thanks for the advice
Linking the set-records to the corresponding get-status records is indeed a very good idea.
Connecting all the get-records together via forward-links sounds a bit unpractical for maintenance. Maybe then its better to use a single (or nested if one is not enough) Fanout records for regular scanning of all status-records ?
I am still wondering why there is nothing foreseen to get prompt execution of a record (and its protocol) once its read via caget (prior to returning the result). This would be similar to the PP ProcessPassive flag mechanism when using input links.
Re: Stream device - general concept how to use Ralph Lange via Tech-talk
Stream device - general concept how to use Christian Pauly via Tech-talk
Re: Stream device - general concept how to use Mark Rivers via Tech-talk
Re: Stream device - general concept how to use Arnold, Ned D. via Tech-talk
Prev: Re: Modbus alarms question John Dobbins via Tech-talk
Next: Re: Stream device - general concept how to use Konrad, Martin via Tech-talk
Prev: Re: Stream device - general concept how to use Ralph Lange via Tech-talk
Next: Re: Stream device - general concept how to use Ralph Lange via Tech-talk
