1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: RE: Multiple IOCs on one host Issue
From: "Manoussakis, Adamandios via Tech-talk" <[email protected]>
To: Ralph Lange <[email protected]>, 'Ralph Lange' <[email protected]>
Date: Fri, 19 Mar 2021 18:24:59 +0000
Thanks Heinz,
I seem to be still getting the return error from Ralph’s script even with the changes below that you mentioned. I did have to add the closing quotations on the last grep commands for addr/bcast, I was getting unterminated string error.
line=`ip addr show $IFACE`
addr=`echo $line | grep -Po 'inet\s+[^\s]+\s+' | grep -Po '\d+.*’ '`
bcast=`echo $line | grep -Po 'brd\s+[^\s]+\s+' | grep -Po '\d+.*’ '`
[ -z "$addr" -o -z "$bcast" ] && return 1
@Ralph
Here is what the script is going through, seems like the grep is still failing
jetson@ubuntu:/etc/network/if-up.d$ sudo sh -x ioc.sh
+ PORT=5064
+ [  != none ]s
+ [  != lo ]
+ ip addr show
+ line=1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
    inet 127.0.0.1/8 scope host lo
       valid_lft forever preferred_lft forever
    inet6 ::1/128 scope host
2: ens33: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
    link/ether 00:0c:29:c6:6f:a0 brd ff:ff:ff:ff:ff:ff
    inet 192.168.252.132/24 brd 192.168.252.255 scope global ens33
    inet6 fe80::20c:29ff:fec6:6fa0/64 scope link
3: docker0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN group default
    link/ether 02:42:6a:5e:1a:03 brd ff:ff:ff:ff:ff:ff
    inet 172.17.0.1/16 brd 172.17.255.255 scope global docker0
+ echo 1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000 link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00 inet 127.0.0.1/8 scope host lo valid_lft forever preferred_lft forever inet6 ::1/128 scope host valid_lft forever preferred_lft forever 2: ens33: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000 link/ether 00:0c:29:c6:6f:a0 brd ff:ff:ff:ff:ff:ff inet 192.168.252.132/24 brd 192.168.252.255 scope global ens33 valid_lft forever preferred_lft forever inet6 fe80::20c:29ff:fec6:6fa0/64 scope link valid_lft forever preferred_lft forever 3: docker0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN group default link/ether 02:42:6a:5e:1a:03 brd ff:ff:ff:ff:ff:ff inet 172.17.0.1/16 brd 172.17.255.255 scope global docker0 valid_lft forever preferred_lft forever
+ grep -Po inet\s+[^\s]+\s+
+ grep -Po \d+.*’
+ addr=
+ grep -Po \d+.*’
+ grep -Po brd\s+[^\s]+\s+
+ bcast=
+ [ -z  -o -z  ]
+ return 1
From: Tech-talk [email protected] On Behalf Of Ralph Lange via Tech-talk
Sent: Friday, March 19, 2021 9:35 AM
To: EPICS Tech Talk <[email protected]>
Subject: Re: Multiple IOCs on one host Issue
On Fri, 19 Mar 2021 at 10:59, Heinz Junkes <[email protected]> wrote:
The right expressions might be these ones:
addr=`echo $line | grep -Po 'inet\s+[^\s]+\s+' | grep -Po '\d+.*’`
bcast=`echo $line | grep -Po 'brd\s+[^\s]+\s+' | grep -Po '\d+.*’`
Impressive.
Do these work with older systems - where the other expressions worked?
Cheers,
~Ralph
RE: Multiple IOCs on one host Issue Manoussakis, Adamandios via Tech-talk
Re: Multiple IOCs on one host Issue Jeong Han Lee via Tech-talk
Re: Multiple IOCs on one host Issue Mark Rivers via Tech-talk
Re: Multiple IOCs on one host Issue Ralph Lange via Tech-talk
RE: Multiple IOCs on one host Issue Mark Rivers via Tech-talk
Re: Multiple IOCs on one host Issue J. Lewis Muir via Tech-talk
Re: Multiple IOCs on one host Issue Hu, Yong via Tech-talk
Re: Multiple IOCs on one host Issue Heinz Junkes via Tech-talk
Prev: Re: vscode extension for EPICS Victor Nadot via Tech-talk
Next: RE: Multiple IOCs on one host Issue Manoussakis, Adamandios via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: Multiple IOCs on one host Issue Ralph Lange via Tech-talk
