1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: base-7.0.6 long string$ bug? Re: Calc Module of SynApps: Issue with long string CALC$
From: "Kasemir, Kay via Tech-talk" <[email protected]>
To: Kuldeep Joshi <[email protected]>
Date: Sat, 7 Aug 2021 19:35:05 +0000
Hi:
> I subsequently tried out on EPICS base version 7.0.3.1 ..
> It works fine ..
> I am suspecting the bug may be due to newer version of EPICS.
Looks like you found a problem in R7.0.6.
Take this example record, executed by softIoc:
record(calc, "test_calc")
    field(SCAN, "1 second")
    field(CALC, "RNDM*100")
$ caget -S test_calc.CALC$
test_calc.CALC$ RNDM*100
$ caput -S test_calc.CALC$ "300"
Old : test_calc.CALC$ RNDM*100
CA.Client.Exception...............................................
    Warning: "Channel write request failed"
    Context: "op=1, channel=test_calc.CALC$, type=DBR_CHAR, count=4, ctx="test_calc""
    Source File: ../oldChannelNotify.cpp line 159
    Current Time: Sat Aug 07 2021 15:27:54.755166000
New : test_calc.CALC$ 3NDM*100
.. and the softIoc shows this error:
Illegal field value PV: test_calc calc: Illegal CALC field
test_calc.CALC: Syntax error, unknown operator/operand in expression "3NDM*100"
So the IOC didn't receive "300" as written, it only took "3" _and_ kept the rest of the previous CALC field value.
When instead using R7.0.4.1, all works fine.
In fact the test also succeeds with softIoc from R7.0.4.1 and caget/caput from base-7.0.6.
The issue starts when using the base-7.0.6 softIoc.
-Kay
Re: base-7.0.6 long string$ bug? Re: Calc Module of SynApps: Issue with long string CALC$ Pete Jemian via Tech-talk
Re: base-7.0.6 long string$ bug? Re: Calc Module of SynApps: Issue with long string CALC$ Michael Davidsaver via Tech-talk
Calc Module of SynApps: Issue with long string CALC$ Kuldeep Joshi via Tech-talk
Re: [EXTERNAL] Calc Module of SynApps: Issue with long string CALC$ Kasemir, Kay via Tech-talk
Re: [EXTERNAL] Calc Module of SynApps: Issue with long string CALC$ Kuldeep Joshi via Tech-talk
Re: Calc Module of SynApps: Issue with long string CALC$ Kuldeep Joshi via Tech-talk
Prev: Re: Calc Module of SynApps: Issue with long string CALC$ Kuldeep Joshi via Tech-talk
Next: Re: base-7.0.6 long string$ bug? Re: Calc Module of SynApps: Issue with long string CALC$ Pete Jemian via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
