1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: support for Moxa ioLogik modules
From: "Pearson, Matthew R. via Tech-talk" <[email protected]>
Date: Wed, 17 Nov 2021 16:54:20 +0000
I see there is a recent message about using the Modbus module to talk to Moxa ioLogik devices. This might be good time to announce that we've developed support for various Moxa ioLogik modules and put it on GitHub at:
https://github.com/ornl-epics/moxa
It includes support for:
E1210 - 16 DI
E1214 - 6 DI, 6 Relay
E1240 - 8 AI
E1241 - 4 AO
E1242 - 4 DI, 4DIO, 4 AI
It's light on documentation, but there is an example IOC showing how to use it, and it's simply:
file E1214.template
pattern {P, R, PORT, IP_PORT}
        {mkp:, E1214:, m1, m1ip}
And the st.cmd file would contain:
#E1214 Unit (6 DI and 6 Relay)
epicsEnvSet("IP_ADDR","192.168.200.177:502")
epicsEnvSet("IP_PORT","m1ip")
epicsEnvSet("PORT","m1")
< $(MOXA)/st_scripts/st_common.cmd
So the st_common.cmd script hides away the details of setting up the TCP port and the Asyn Modbus ports. A range of Modbus ports are created, each with different word sizes and read/write settings, and then the module specific database templates choose which ones they need to use for the module in question.
Also includes a set of CS-Studio BOY/DisplayBuilder screens (example attached).
Cheers,
Matt
STS Integrated Control System Lead Engineer
Spallation Neutron Source
Oak Ridge National Lab
Attachment: moxa_screenshot.JPG
Description: moxa_screenshot.JPG
Prev: Re: A problem with modbus reading floating point numbers Mark L Rivers via Tech-talk
Next: Re: Re: A problem with modbus reading floating point numbers 高振华 via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: Re: Re: Re: A problem with modbus reading floating point numbers 高振华 via Tech-talk
Next: CSS (Eclipse and Phoebus) super slow on a server with multiple users Jokinen Antti (F4E) via Tech-talk
