Hello chengsn,
did you build RTEMS with Posix support?
Here is an example for RTEMS5 the old way (Target == beatnik):
wget https://ftp.rtems.org/pub/rtems/releases/5/5.1/sources/rtems-5.1.tar.xz
tar Jxf rtems-5.1.tar.xz
mv rtems-5.1 kernel
cd kernel
./bootstrap -c && ./rtems-bootstrap
cd ..
mkdir -p build/b-beatnik
cd build/b-beatnik
../../kernel/configure --prefix=/home/rtems/MVME6100/rtems/5.1 --target=powerpc-rtems5 --enable-rtemsbsp=beatnik --enable-posix --enable-c++ --enable-networking --enable-tests
make all
make install
Example for master (RTEMS6, Target==beatnik) with waf:
# building kernel
git clone git://git.rtems.org/rtems.git kernel
cd kernel
./waf bsp_defaults --rtems-bsps=powerpc/beatnik > config.ini
sed -i ‘ ‘ \
-e "s|RTEMS_POSIX_API = False|RTEMS_POSIX_API = True|" \
-e "s|BUILD_TESTS = False|BUILD_TESTS = True|" \
config.ini
./waf configure --prefix=${RTEMS_ROOT}
./waf
./waf install
Then "EPICS-make" selects libcom/RTEMS/posix and there is no need to touch /libcom/RTEMS/score/rtems_config.c.
Gruss Heinz
> On 21. Jun 2022, at 03:14, chengsn at ihep.ac.cn wrote:
>> -----Original Messages-----
>> From: "Heinz Junkes" <junkes at fhi-berlin.mpg.de>
>> Sent Time: 2022-06-20 22:33:32 (Monday)
>> To: chengsn at ihep.ac.cn
>> Cc: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
>> Subject: Re: Some Questions With RTEMS 5 in MVME2502
>> I am wondering myself…
>> Did you build RTEMS with legacy stack or with rtems-libbsd?
> I build RTEMS with rtems-libbsd.
>> To get the shell input to work, you could replace in
>> modules/libcom/RTEMS/posix/rtems_config.c
>> #define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
>> with
>> #define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
> I replaced the #define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER with #define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER in modules/libcom/RTEMS/posix/rtems_config.c and modules/libcom/RTEMS/score/rtems_config.c. Both files need to be modified.
>> Viele Grüße
>> Heinz
> Maybe there is something I'm not configuring correctly.
> Thanks for your help.
> chengsn
>>> On 20. Jun 2022, at 11:26, chengsn at ihep.ac.cn wrote:
>>> Compile after uncommenting, I get this error:
>>> /home/chengsn/RTEMS/MVME2500/RTEMS/rtems-5/lib/gcc/powerpc-rtems5/7.5.0/../../../../powerpc-rtems5/bin/ld: /home/chengsn/RTEMS/MVME2500/EPICS/base-7.0.6.1/lib/RTEMS-qoriq_e500/librtemsCom.a(rtems_init.o): in function `POSIX_Init':
>>> /home/chengsn/RTEMS/MVME2500/EPICS/base-7.0.6.1/modules/libcom/RTEMS/O.RTEMS-qoriq_e500/../posix/rtems_init.c:1115: undefined reference to `rtems_telnetd_initialize'
>>> collect2: error: ld returned 1 exit status
>>> ../../../../../configure/RULES_BUILD:230: recipe for target 'softIoc' failed
>>> Maybe I should ld the libtelnetd.a. What should I do?
>>>> Sent Time: 2022-06-20 16:57:49 (Monday)
>>>> You're right, that needs to be commented out. Unfortunately, I had overlooked it.
>>>> Viele Grüße
>>>> Heinz
>>>>> On 20. Jun 2022, at 10:51, chengsn at ihep.ac.cn wrote:
>>>>> Thanks for your help!
>>>>> When I try to connect to 10.1.201.13, I get "telnet: connect to address 10.1.201.13: Connection refused error". I changed another computer and tried again, still the same. But I can access the PV on 10.1.201.13 on the pc, either via caget or pvget.
>>>>> Maybe the rtems_telnetd_initialize() in rtems_init() should be run?
>>>>> Some code in the rtems_init.c:1112,
>>>>> #if __RTEMS_MAJOR__>4
>>>>> // if telnetd is requested ...
>>>>> // printf(" Will try to start telnetd with prio %d ...\n", rtems_telnetd_config.priority);
>>>>> // result = rtems_telnetd_initialize();
>>>>> // printf (" telnetd initialized with result %d\n", result);
>>>>> #endif
>>>>> Thanks!
>>>>> chengsn
>>>>>> Sent Time: 2022-06-17 16:04:46 (Friday)
>>>>>> hi chengsn,
>>>>>> That doesn't look so bad. Unfortunately, I don't have an MVME2500 at the moment on which I can reproduce the whole thing.
>>>>>> I have built telnet access into the rtems_init:
>>>>>> #ifndef RTEMS_LEGACY_STACK
>>>>>> // setup own ntp-client to get time
>>>>>> /telnet
>>>>>> char line[LINE_SIZE];
>>>>>> int fid[3], save_fid[3];
>>>>>> printf("info: pty dev name = %s\n", name);
>>>>>> save_fid[1] = dup2(1,1);
>>>>>> fid[1] = dup2( fileno(stdout), 1);
>>>>>> if (fid[1] == -1 ) printf("Can't dup stdout\n");
>>>>>> save_fid[2] = dup2(2,2);
>>>>>> fid[2] = dup2( fileno(stderr), 2);
>>>>>> if (fid[2] == -1 ) printf("Can't dup stderr\n");
>>>>>> const char *prompt = "tIocSh> ";
>>>>>> while (1) {
>>>>>> fputs(prompt, stdout);
>>>>>> fflush(stdout);
>>>>>> /* telnet close not detected ??? tbd */
>>>>>> if (fgets(line, LINE_SIZE, stdin) == NULL) {
>>>>>> dup2(save_fid[1],1);
>>>>>> dup2(save_fid[2],2);
>>>>>> return;
>>>>>> if (line[strlen(line)-1] == '\n') line[strlen(line)-1] = 0;
>>>>>> if (!strncmp( line, "bye",3)) {
>>>>>> printf( "%s", "Will end session\n");
>>>>>> return;
>>>>>> iocshCmd(line);
>>>>>> You could try connecting to the system with "telnet 10.1.201.13" and you
>>>>>> should then be in an EPICS shell.
>>>>>> To exit, type "bye" (not CTRL-], otherwise the shell is blocked).
>>>>>> Viele Grüße
>>>>>> Heinz Junkes
>>>>>> Experience directly varies with equipment ruined.
>>>>>>> On 16. Jun 2022, at 12:14, chengsn via Tech-talk <tech-talk at aps.anl.gov> wrote:
>>>>>>> Sorry, I got something wrong, the EPICS 7 version I used was downloaded from github, and just now I re-tryed the base-7.0.6.1 version: $ wget https://epics.anl.gov/download/base/base-7.0.6.1.tar.gz.
>>>>>>> Then, I ran the exampleApp :
>>>>>>> ***** Until now no NTP support in RTEMS 5 with rtems-libbsd *****
>>>>>>> ***** Ask ntp server once... *****
>>>>>>> time from ntp : 06/16/22 09:59:35.000001019 UTC
>>>>>>> ***** Setting up file system *****
>>>>>>> ***** Initializing NFS *****
>>>>>>> nfsMount("10.1.201.31", "/tftpboot", "/tftpboot")
>>>>>>> Mount 10.1.201.31:/tftpboot on /tftpboot
>>>>>>> check for time registered , C++ initialization ...
>>>>>>> ***** Preparing EPICS application *****
>>>>>>> chdir("/tftpboot/mv2500/")
>>>>>>> ***** Starting EPICS application *****
>>>>>>> #< envPaths
>>>>>>> ## Register all support components
>>>>>>> dbLoadDatabase("dbd/test.dbd")
>>>>>>> test_registerRecordDeviceDriver(pdbbase)
>>>>>>> ## Load record instances
>>>>>>> dbLoadTemplate("db/user.substitutions")
>>>>>>> dbLoadRecords("db/testVersion.db", "user=chengsn")
>>>>>>> dbLoadRecords("db/dbSubExample.db", "user=chengsn")
>>>>>>> #var mySubDebug 1
>>>>>>> #traceIocInit
>>>>>>> iocInit
>>>>>>> Starting iocInit
>>>>>>> ## EPICS R7.0.6.1
>>>>>>> ## Rev. 2022-06-16T17:52+0800
>>>>>>> iocRun: All initialization complete
>>>>>>> ## Start any sequence programs
>>>>>>> #seq(sncExample, "user=chengsn")
>>>>>>> ***** Primary Network interface : tsec0 *****
>>>>>>> all out ---> interface = tsec2
>>>>>>> all out ---> reason = IPV4LL
>>>>>>> all out ---> pid = 1
>>>>>>> all out ---> ifmetric = 203
>>>>>>> all out ---> ifwireless = 0
>>>>>>> all out ---> ifflags = 4294936643
>>>>>>> all out ---> ifmtu = 1500
>>>>>>> all out ---> interface_order = tsec0 tsec2 tsec1
>>>>>>> all out ---> if_up = true
>>>>>>> all out ---> if_down = false
>>>>>>> all out ---> new_ip_address = 169.254.57.184
>>>>>>> all out ---> new_subnet_cidr = 16
>>>>>>> all out ---> new_network_number = 169.254.0.0
>>>>>>> all out ---> new_subnet_mask = 255.255.0.0
>>>>>>> all out ---> new_broadcast_address = 169.254.255.255
>>>>>>> all out ---> interface = tsec0
>>>>>>> all out ---> reason = RENEW
>>>>>>> all out ---> ifmetric = 201
>>>>>>> all out ---> old_ip_address = 10.1.201.13
>>>>>>> all out ---> old_subnet_cidr = 24
>>>>>>> all out ---> old_broadcast_address = 10.1.201.255
>>>>>>> all out ---> old_network_number = 10.1.201.0
>>>>>>> all out ---> old_server_name = 10.1.201.31
>>>>>>> all out ---> old_subnet_mask = 255.255.255.0
>>>>>>> all out ---> old_routers = 10.1.201.1
>>>>>>> all out ---> old_dhcp_lease_time = 600
>>>>>>> all out ---> old_dhcp_message_type = 5
>>>>>>> all out ---> old_dhcp_server_identifier = 10.1.201.31
>>>>>>> all out ---> old_dhcp_renewal_time = 300
>>>>>>> all out ---> old_dhcp_rebinding_time = 525
>>>>>>> all out ---> new_ip_address = 10.1.201.13
>>>>>>> all out ---> new_subnet_cidr = 24
>>>>>>> all out ---> new_broadcast_address = 10.1.201.255
>>>>>>> all out ---> new_network_number = 10.1.201.0
>>>>>>> all out ---> new_server_name = 10.1.201.31
>>>>>>> all out ---> new_subnet_mask = 255.255.255.0
>>>>>>> all out ---> new_routers = 10.1.201.1
>>>>>>> all out ---> new_dhcp_lease_time = 600
>>>>>>> all out ---> new_dhcp_message_type = 5
>>>>>>> all out ---> new_dhcp_server_identifier = 10.1.201.31
>>>>>>> all out ---> new_dhcp_renewal_time = 300
>>>>>>> all out ---> new_dhcp_rebinding_time = 525
>>>>>>> But I cannot input anything in the shell.
>>>>>>> Is this normal?
>>>>>>> -----原始邮件-----
>>>>>>> 发件人:chengsn at ihep.ac.cn
>>>>>>> 发送时间:2022-06-16 17:14:33 (星期四)
>>>>>>> 收件人: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
>>>>>>> 抄送:
>>>>>>> 主题: Some Questions With RTEMS 5 in MVME2502
>>>>>>> Hello All,
>>>>>>> I followed the steps at EPICS with RTEMS, compiled RTEMS 5, and ran an example hello on MVME2502. The dtb file was generated from the linux source file: $ dtc -I dts -O dtb linux/arch/powerpc/boot/dts/fsl/mvme2500.dts -o mvme2500.dtb
>>>>>>> If I didn't change the macro definition #define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER to #define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER in the file test.c, the OUTPUT is:
>>>>>>> Bytes transferred = 12331 (302b hex)
>>>>>>> WARNING: adjusting available memory to 30000000
>>>>>>> ## Booting kernel from Legacy Image at 01000000 ...
>>>>>>> Image Name: hello
>>>>>>> Created: 2022-06-09 15:06:14 UTC
>>>>>>> Image Type: PowerPC Linux Kernel Image (gzip compressed)
>>>>>>> Data Size: 51612 Bytes = 50.4 KiB
>>>>>>> Load Address: 00004000
>>>>>>> Entry Point: 00004000
>>>>>>> Verifying Checksum ... OK
>>>>>>> ## Flattened Device Tree blob at 00c00000
>>>>>>> Booting using the fdt blob at 0xc00000
>>>>>>> Uncompressing Kernel Image ... OK
>>>>>>> ft_fixup_l2cache: FDT_ERR_NOTFOUND
>>>>>>> ?H?@?LR???r????I?C?=GC?c?
>>>>>>> Then, I compiled EPICS base 7.0.6.1, made a EPICS exampleApp test, ran the image file bin/RTEMS-qoriq_e500/test.img. The OUTPUT is:
>>>>>>> Image Name: test
>>>>>>> Created: 2022-06-08 16:51:21 UTC
>>>>>>> Data Size: 2734725 Bytes = 2.6 MiB
>>>>>>> ?C???)???G?}[k???C8V?o?????????????k???J?G&k)?J?gb!?CruB??????g?s ?C1H?cbjR?C?b???c??=?????????C1H?cbjR?C?b???c??=???????? ?C1H?cbjR?C?b???c??=?????????C1H?cbjR?C?b???c??=???????? ?C1H?cbjR?C?b???c??=????????1b?R?W?jR?C?b???c?????gb
>>>>>>> So, I had to change the macro definition #define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER to #define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER in the file base/modules/libcom/RTEMS/posix/rtems_config.c.
>>>>>>> Did I do something wrong?
>>>>>>> After recompiling EPICS and making the exampleApp, the IOC started to get the ip through DHCP. I set some file paths in the rtems_init.c file, but there was some other information after the IOC initialization was completed:
>>>>>>> diff --git a/modules/libcom/RTEMS/posix/rtems_init.c b/modules/libcom/RTEMS/posix/rtems_init.c
>>>>>>> index 403cd0785..d7886b6ab 100644
>>>>>>> --- a/modules/libcom/RTEMS/posix/rtems_init.c
>>>>>>> +++ b/modules/libcom/RTEMS/posix/rtems_init.c
>>>>>>> @@ -97,10 +97,10 @@ epicsEventId dhcpDone;
>>>>>>> * may provide by dhcp/bootp
>>>>>>> * or environments from the "BIOS" like u-boot, motboot etc.
>>>>>>> -char rtemsInit_NTP_server_ip[16] = "";
>>>>>>> -char bootp_server_name_init[128] = "[email protected]:/epics";
>>>>>>> -char bootp_boot_file_name_init[128] = "/epics/myExample/bin/RTEMS-beatnik/myExample.boot";
>>>>>>> -char bootp_cmdline_init[128] = "/epics/myExample/iocBoot/iocmyExample/st.cmd";
>>>>>>> +char rtemsInit_NTP_server_ip[16] = "10.1.201.31";
>>>>>>> +char bootp_server_name_init[128] = "10.1.201.31:/tftpboot";
>>>>>>> +char bootp_boot_file_name_init[128] = "/tftpboot/mv2500/bin/RTEMS-qoriq_e500/test.img";
>>>>>>> +char bootp_cmdline_init[128] = "/tftpboot/mv2500/iocBoot/ioctest/st.cmd";
>>>>>>> struct in_addr rtems_bsdnet_bootp_server_address;
>>>>>>> /* TODO check rtems_bsdnet_bootp_cmdline */
>>>>>>> some OUTPUT:
>>>>>>> MVME2500=> run epicsTest
>>>>>>> Speed: 1000, full duplex
>>>>>>> Using eTSEC1 device
>>>>>>> TFTP from server 10.1.201.31; our IP address is 10.1.201.125
>>>>>>> Filename 'mv2500/bin/RTEMS-qoriq_e500/test.img'.
>>>>>>> Load address: 0x1000000
>>>>>>> Loading: #################################################################
>>>>>>> done
>>>>>>> Bytes transferred = 1997059 (1e7903 hex)
>>>>>>> Using eTSEC1 device
>>>>>>> Filename 'mvme2500.dtb'.
>>>>>>> Load address: 0xc00000
>>>>>>> Loading: #
>>>>>>> done
>>>>>>> Image Name: test
>>>>>>> Created: 2022-06-08 14:23:06 UTC
>>>>>>> Data Size: 1996995 Bytes = 1.9 MiB
>>>>>>> WARNING: OS Clock time was read before being set.
>>>>>>> Using 1990-01-02 00:00:00.000000 UTC
>>>>>>> initConsole --- Info ---
>>>>>>> stdin: fileno: 0, ttyname: /dev/console
>>>>>>> stdout: fileno: 1, ttyname: /dev/console
>>>>>>> stderr: fileno: 2, ttyname: /dev/console
>>>>>>> tcgetattr failed: Not a character device
>>>>>>> time set to : 04/14/14 07:30:06.000000839 UTC
>>>>>>> Startup.
>>>>>>> epicsThreadSetPriority called by non epics thread
>>>>>>> ***** RTEMS Version: rtems-5.0.0 (PowerPC/Generic (E500/float-gprs/SPE)/qoriq_e500) *****
>>>>>>> ***** Initializing network (libbsd, dhcpcd) *****
>>>>>>> nexus0: <RTEMS Nexus device>
>>>>>>> ofwbus0: <Open Firmware Device Tree> on nexus0
>>>>>>> -------------- IFCONFIG -----------------
>>>>>>> tsec0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
>>>>>>> options=8000b<RXCSUM,TXCSUM,VLAN_MTU,LINKSTATE>
>>>>>>> ether ec:9e:cd:13:47:66
>>>>>>> inet6 fe80::ee9e:cdff:fe13:4766%tsec0 prefixlen 64 scopeid 0x1
>>>>>>> inet 10.1.201.13 netmask 0xffffff00 broadcast 10.1.201.255
>>>>>>> nd6 options=21<PERFORMNUD,AUTO_LINKLOCAL>
>>>>>>> media: Ethernet autoselect (1000baseT <full-duplex>)
>>>>>>> status: active
>>>>>>> tsec1: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
>>>>>>> ether ec:9e:cd:13:47:67
>>>>>>> inet6 fe80::ee9e:cdff:fe13:4767%tsec1 prefixlen 64 scopeid 0x2
>>>>>>> media: Ethernet autoselect (none)
>>>>>>> status: no carrier
>>>>>>> tsec2: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
>>>>>>> options=b<RXCSUM,TXCSUM,VLAN_MTU>
>>>>>>> ether ec:9e:cd:13:47:68
>>>>>>> inet6 fe80::ee9e:cdff:fe13:4768%tsec2 prefixlen 64 scopeid 0x3
>>>>>>> lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> metric 0 mtu 16384
>>>>>>> options=680003<RXCSUM,TXCSUM,LINKSTATE,RXCSUM_IPV6,TXCSUM_IPV6>
>>>>>>> inet 127.0.0.1 netmask 0xffffff00
>>>>>>> inet6 ::1 prefixlen 128
>>>>>>> inet6 fe80::1%lo0 prefixlen 64 scopeid 0x4
>>>>>>> groups: lo
>>>>>>> -------------- NETSTAT ------------------
>>>>>>> Routing tables
>>>>>>> Internet:
>>>>>>> Destination Gateway Flags Netif Expire
>>>>>>> default 10.1.201.1 UGS tsec0
>>>>>>> 10.1.201.0/24 link#1 U tsec0
>>>>>>> 10.1.201.13 link#1 UHS lo0
>>>>>>> 127.0.0.1 link#4 UH lo0
>>>>>>> Internet6:
>>>>>>> ::1 link#4 UH lo0
>>>>>>> fe80::%tsec0/64 link#1 U tsec0
>>>>>>> fe80::ee9e:cdff:fe13:4766%tsec0 link#1 UHS lo0
>>>>>>> fe80::%tsec1/64 link#2 U tsec1
>>>>>>> fe80::ee9e:cdff:fe13:4767%tsec1 link#2 UHS lo0
>>>>>>> fe80::%tsec2/64 link#3 U tsec2
>>>>>>> fe80::ee9e:cdff:fe13:4768%tsec2 link#3 UHS lo0
>>>>>>> fe80::%lo0/64 link#4 U lo0
>>>>>>> fe80::1%lo0 link#4 UHS lo0
>>>>>>> debug: tsec0: sending ARP announce (2 of 2)
>>>>>>> debug: tsec2: sending DISCOVER (xid 0xa096e1f), next in %0.1f seconds
>>>>>>> time from ntp : 06/15/22 06:51:49.000000839 UTC
>>>>>>> chdir("/tftpboot/mv2500/iocBoot/ioctest/")
>>>>>>> #< envPaths
>>>>>>> dbLoadDatabase("../../dbd/test.dbd")
>>>>>>> #dbLoadTemplate("db/user.substitutions")
>>>>>>> dbLoadRecords("../../db/testVersion.db", "user=chengsn")
>>>>>>> dbLoadRecords("../../db/circle.db", "user=chengsn")
>>>>>>> dbLoadRecords("../../db/dbSubExample.db", "user=chengsn")
>>>>>>> #var mySubDebug 1
>>>>>>> #traceIocInit
>>>>>>> iocInit
>>>>>>> Starting iocInit
>>>>>>> ## EPICS R7.0.6.2-DEV
>>>>>>> ## Rev. R7.0.6.1-103-g3fadf4a26cfe33dcb9eb-dirty
>>>>>>> RTEMShost> tsec2: sending DISCOVER (xid 0xa096e1f), next in 31.1 secondstimed outallowing 8 seconds for IPv4LL timeouttsec2: probing for an IPv4LL addresstsec2: checking for 169.254.92.20tsec2: sending ARP probe (1 of 3), next in 1.6 secondstsec2: sending ARP probe (2 of 3), next in 1.7 secondstsec2: sending ARP probe (3 of 3), next in 2.0 secondstsec2: using IPv4LL address 169.254.92.20tsec2: adding IP address 169.254.92.20/16tsec0: adding host route to 10.1.201.13 via 127.0.0.1tsec0: ipv4_addroute: mtsec0: adding route to 10.1.201.0/24tsec0: ipv4_addroute: mtsec2: adding host route to 169.254.92.20 via 127.0.0.1tsec2: ipv4_addroute: mtsec2: adding route to 169.254.0.0/16tsec2: ipv4_addroute: mtsec2: writing lease `/var/db/dhcpcd-tsec2.lease'tsec2: executing `ioc boot' IPV4LL
>>>>>>> dhcpcd ---> 'interface=tsec2'
>>>>>>> 'interface' = 'tsec2'
>>>>>>> dhcpcd ---> 'reason=IPV4LL'
>>>>>>> 'reason' = 'IPV4LL'
>>>>>>> dhcpcd ---> 'pid=1'
>>>>>>> dhcpcd ---> 'ifmetric=203'
>>>>>>> dhcpcd ---> 'ifwireless=0'
>>>>>>> dhcpcd ---> 'ifflags=4294936643'
>>>>>>> dhcpcd ---> 'ifmtu=1500'
>>>>>>> dhcpcd ---> 'interface_order=tsec0 tsec2 tsec1'
>>>>>>> dhcpcd ---> 'if_up=true'
>>>>>>> dhcpcd ---> 'if_down=false'
>>>>>>> dhcpcd ---> 'new_ip_address=169.254.92.20'
>>>>>>> dhcpcd ---> 'new_subnet_cidr=16'
>>>>>>> dhcpcd ---> 'new_network_number=169.254.0.0'
>>>>>>> dhcpcd ---> 'new_subnet_mask=255.255.0.0'
>>>>>>> dhcpcd ---> 'new_broadcast_address=169.254.255.255'
>>>>>>> tsec2: sending ARP announce (1 of 2), next in 2.0 secondstimed outtsec2: sending ARP announce (2 of 2)tsec2: soliciting a DHCP leasetsec2: sending DISCOVER (xid 0x614c417a), next in 3.6 secondstsec2: sending DISCOVER (xid 0x614c417a), next in 7.3 secondstsec2: sending DISCOVER (xid 0x614c417a), next in 15.5 secondstsec2: sending DISCOVER (xid 0x614c417a), next in 32.5 secondstsec2: sending DISCOVER (xid 0x614c417a), next in 63.6 secondstsec2: sending DISCOVER (xid 0x614c417a), next in 63.5 secondstsec2: sending DISCOVER (xid 0x614c417a), next in 63.6 secondstsec2: sending DISCOVER (xid 0x614c417a), next in 63.9 secondstsec0: renewing lease of 10.1.201.13tsec0: rebind in 225 seconds, expire in 300 secondstsec0: sending REQUEST (xid 0x504868fd), next in 4.5 secondstsec0: acknowledged 10.1.201.13 from 10.1.201.31 `10.1.201.31'tsec0: leased 10.1.201.13 for 600 secondstsec0: renew in 300 seconds, rebind in 525 secondstsec0: IP address 10.1.201.13/24 already existstsec0: adding host route to 10.1.201.13 via 127.0.0.1tsec0: ipv4_addroute: mtsec0: adding route to 10.1.201.0/24tsec0: ipv4_addroute: mtsec2: adding host route to 169.254.92.20 via 127.0.0.1tsec2: ipv4_addroute: mtsec2: adding route to 169.254.0.0/16tsec2: ipv4_addroute: mtsec0: writing lease `/var/db/dhcpcd-tsec0.lease'tsec0: executing `ioc boot' RENEW
>>>>>>> Then, the IOC will keep restarting...
>>>>>>> What should I do to get the IOC working properly?
>>>>>>> Best regards,
>>>>>>> chengsn
- Re: Re: Some Questions With RTEMS 5 in MVME2502 chengsn via Tech-talk
- Some Questions With RTEMS 5 in MVME2502 chengsn via Tech-talk
- Re: Some Questions With RTEMS 5 in MVME2502 chengsn via Tech-talk
- Re: Some Questions With RTEMS 5 in MVME2502 Heinz Junkes via Tech-talk
PVA monitor request parameters Pearson, Matthew via Tech-talk
RE: Phoebus alarm does not honor filter Zhang, Tong via Tech-talk
<2022>
2025
<2022>
2025
