The EPICS core developers have long been aware that there are problems
with the use and Posix implementation of epicsThreadSleepQuantum()
on Linux, but they haven't risen to the level of itchiness that we
have scratched them ourselves — patches or pull requests welcome!
Implementing the suggestions here
might be one possible route.
This email provides some additional background information.
The text in the old Application Developers guide that described the
function says:
This function returns the
minimum slumber interval obtainable with
epicsThreadSleep() in seconds. On most OS there is a
system scheduler interrupt interval which determines the
value of this parameter. Knowledge of this parameter is
used by the various components of EPICS to improve
scheduling of software tasks in time when the reduction
of average time scheduling errors is important. If this
parameter is unknown or is unpredictable for a
particular OS then it is safe to return zero.
I obviously forgot that last sentence when I wrote the code in
dbScan.c which divides by the quantum, so that should get fixed
although nobody has actually reported being hit by it in over 10
years.
EPICS Base provides a performance measurement program that you can
run to measure/estimate what the epicsThreadSleepQuantum()
result should be on your system. On EPICS 7.0.x it can be run like
this:
./modules/libcom/test/O.linux-x86_64/epicsThreadPerform
epicsThreadSetPriority called by non epics thread
testPriority main error expected from epicsThreadSetPriority
id 0x7ea450 old 0 new 0
testPriority thread
id 0x7ecd50 old 50 new 99
Estimating sleep quantum..........done
The epicsThreadSleepQuantum() call returns 0.010000 sec.
This doesnt match the quantum estimate of 0.000163 sec
within 10%.
It takes 0.059363 micro sec to call epicsThreadGetIdSelf ()
epicsThreadPrivateGet() takes 0.023940 microseconds
Adjust O.linux-x86_64 in the path for
your particular host architecture. The above was on a RHEL-7 system,
RHEL-8 gives me effectively the same result. On my Apple M1 MacBook
Pro though the output looks like this:
./modules/libcom/test/O.darwin-aarch64/epicsThreadPerform
id 0x600003f3c0b0 old 0 new 0
testPriority thread
id 0x600003d3c000 old 50 new 99
This doesnt match the quantum estimate of 0.009273 sec
within 1%.
It takes 0.011298 micro sec to call epicsThreadGetIdSelf ()
epicsThreadPrivateGet() takes 0.005903 microseconds
In EPICS Base-3.15 the path to use is ./src/libCom/test/O.linux-x86_64/epicsThreadPerform
but the output is identical. I don't particularly like the "doesn't
match the quantum estimate ... within n%" language in the output,
but those of you with a statistical background might recognize an
attempt to be mathematically correct.
Thus on a Mac the value returned by epicsThreadSleepQuantum()
is reasonably accurate, while on a fairly recent and fast Linux box
the "minimum slumber interval" may be up to about 2 orders of
magnitude smaller.
The concept of the quantum is important for systems like RTEMS and
VxWorks that schedule thread delays using a fixed "tick" interval,
so the IOC code does need to account for that and we can't just
remove it completely. The issues #106
and LP:
#1861612 are related to that.
- Andrew
On 1/6/23 9:14 AM, Ricardo Cardenes via
Tech-talk wrote:
On Fri, Jan 6, 2023 at 11:48
AM Érico Nogueira Rolim via Tech-talk < [email protected]>
wrote:
On Linux, that function uses essentially '1.0 / sysconf
( _SC_CLK_TCK )'. The sysconf value is usually 100 (Hz),
and it would explain why EPICS thinks it won't achieve the
desired scan rate. I don't think a modern kernel will
actually be limited by its tick rate, so I don't know how
accurate that heuristic is.
sysconf provides information about the system to the
user. Last time I checked (but this was many years ago) the
tick rate for Linux is configured at the kernel's build
time: if sysconf(_SC_CLK_TCK) is returning 100, that means
the kernel has been built with a 100 Hz tick rate, and
that's about it. Years ago there was the option of building
the kernel with higher rates (for more responsive systems),
from top of my head I believe the alternative values were
350Hz (maybe 250? can't remember) and 1000Hz, plus an
additional "NO_HZ" mode where you build a "tickless kernel"
but this is of no use to us, I believe.
Googling a bit I see a "divider" kernel parameter so that
a 1000Hz compiled value can be divided a boot time to the
one we want to use (eg. divider=10 -> 100Hz), but I'm not
sure if this is the case for Barret. At best the kernel
might be built with a 1000Hz, with a "divider=10" by default
in the boot options, and it would be just a matter of
changing that. At worst default kernel is simply built
configured to use 100Hz, and then a different pre-compiled
one could be used (distros often include one with PREEMPT
built in, maybe at 1000Hz), and failing everything else a
custom kernel could be built.
Cheers,
Ricardo
Either way, the 'period' value isn't touched after this
verification, so I think the IOC will still attempt to
use it. You could try running a simple counter in your
SCAN and checking with camonitor if the 100Hz rate is
actually achieved.
I think scanppl() might have trouble detecting overruns
with a period of 0.01, though:
if (period > 0.0 &&
(fabs(period - ppsl->period) > 0.05))
continue;
By the way, epicsThreadSleepQuantum() can return 0.0 if
the sysconf errors out, which I believe would result in a
SIGFPE in initPeriodic() when dividing by quantum.
Aviso Legal: Esta mensagem e
seus anexos podem conter informações confidenciais
e/ou de uso restrito. Observe atentamente seu
conteúdo e considere eventual consulta ao remetente
antes de copiá-la, divulgá-la ou distribuí-la. Se
você recebeu esta mensagem por engano, por favor
avise o remetente e apague-a imediatamente.
Disclaimer: This email and its
attachments may contain confidential and/or
privileged information. Observe its content
carefully and consider possible querying to the
sender before copying, disclosing or distributing
it. If you have received this email by mistake,
please notify the sender and delete it immediately.
Complexity comes for free, Simplicity you have to work for.
- Re: Scan rate '.01 second' not achievable Michael Davidsaver via Tech-talk
- Scan rate '.01 second' not achievable Barrett (US), Patrick E via Tech-talk
- Re: Scan rate '.01 second' not achievable Érico Nogueira Rolim via Tech-talk
- Re: Scan rate '.01 second' not achievable Ricardo Cardenes via Tech-talk
Re: Scan rate '.01 second' not achievable Hu, Yong via Tech-talk
<2023>
2025
2026
<2023>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
