On 1/8/23 19:46, Michael Davidsaver wrote:
On 1/6/23 09:24, Andrew Johnson via Tech-talk wrote:
$ ./modules/libcom/test/O.darwin-aarch64/epicsThreadPerform
*The epicsThreadSleepQuantum() call returns 0.010000 sec.**
**This doesnt match the quantum estimate of 0.009273 sec within 1%.*
It takes 0.011298 micro sec to call epicsThreadGetIdSelf ()
epicsThreadPrivateGet() takes 0.005903 microseconds
In EPICS Base-3.15 the path to use is ./src/libCom/test/O.linux-x86_64/epicsThreadPerform but the output is identical. I don't particularly like the "doesn't match the quantum estimate ... within n%" language in the output, but those of you with a statistical background might recognize an attempt to be mathematically correct.
Thus on a Mac the value returned by epicsThreadSleepQuantum() is reasonably accurate, while on a fairly recent and fast Linux box the "minimum slumber interval" may be up to about 2 orders of magnitude smaller.
fyi. on my laptop (intel core i5) with a debian stable kernel (CONFIG_NO_HZ_IDLE)
$ ./modules/libcom/test/O.linux-x86_64/epicsThreadPerform ...
This doesnt match the quantum estimate of 0.000165 sec within 10%.
epicsThreadSleepQuantum() is indeed off by two orders of magnitude.
Worth noting that epicsTimeTest attempts to measure epicsThreadSleep(0)
and gets a smaller interval (62us vs 165us).
./modules/libcom/test/O.linux-x86_64/epicsTimeTest
# Resolution 1 ns
# epicsThreadSleep(0.0) Delta 61510 ns
# Small Delta 91 ns
- Scan rate '.01 second' not achievable Barrett (US), Patrick E via Tech-talk
- Re: Scan rate '.01 second' not achievable Érico Nogueira Rolim via Tech-talk
- Re: Scan rate '.01 second' not achievable Ricardo Cardenes via Tech-talk
- Re: Scan rate '.01 second' not achievable Andrew Johnson via Tech-talk
- Re: Scan rate '.01 second' not achievable Michael Davidsaver via Tech-talk
Re: Help: Asyn record getting incomplete input Marco A. Barra Montevechi Filho via Tech-talk
<2023>
<2023>
