If the device uses Ethernet rather than a serial port you need to add:
- xxx_DBD+=drvAsynIPPort.dbd
-----Original Message-----
From: Tech-talk <tech-talk-bounces at aps.anl.gov> On Behalf Of Pierrick M Hanlet via Tech-talk
Sent: Tuesday, February 14, 2023 1:03 PM
To: tech-talk at aps.anl.gov
Subject: Re: Help getting modbus module started
Hi Christian,
You will also need to add some things to your xxxApp/src/Makefile:
- xxx_DBD+=modbusSupport.dbd
- xxx_DBD+=drvAsynSerialPort.dbd
- xxx_LIBS+=modbus
I think that this should do it for you.
Good luck,
Pierrick
On 2/14/23 11:38, Christian Pauly via Tech-talk wrote:
> Hi folks
> I am trying hard to set up a Raspberry running an EPICS IOC for a
> Delta VFD motor driver / frequency inverter. The device is controlled
> via modbus, using a large set of individual 16bit integer read/write
> registers for configuration, and few more registers for control.
> At the moment it is configured to talk Modbus ASCII via RS485, and
> with a simple Python program using minimalmodbus-lib i can talk to the
> controller.
> Now i started with a fresh EPICS 3.15.7 base, (in ~/EPICS/base) and
> installed ASYN-R4-43 (~/EPICS/modules/asyn-R4-43) and modbus
> (~/EPICS/modules/modbus_R3-2).
> I initiated a new application ~/EPICS/projects/FUcontrol, ran
> "makeBaseApp.pl -t example FUcontrol", "makeBaseApp.pl -i -t example
> FUcontrol" - and thats basically it.
> And now i am stuck how to include modbus (includes / libs / dbd files)
> into my exampleApp.
> I kind of managed to include ASYN already by adding
> ASYN=... to the RELEASE file
> and to the Makefile:
> FUcontrol_LIBS += asyn
> In my ioc startup st.cmd i can run the commands
> drvAsynSerialPortConfigure("RS485", "/dev/ttyUSB0", 0, 0, 0) to
> configure the interface.
> But if i add
> modbusInterposeConfig("RS485",2,1000,0)
> i get an error on startup claiming that modnusinterposeconfig can not
> be found.
> So:
> Is there any simple step-by-step instructions how to add modbus to an
> existing ioc application ?
> I could not find anything "simple" in the documentation. I saw the
> examples which come with modbus, but all these already look quite
> complicated to me...
> Or any good advise on how to continue from here ?
> Thanks for any help !
> Christian
Pierrick Hanlet
Fermi National Accelerator
Accelerator Front End Controls
+1-630-840-5555 -- lab
+1-312-687-4980 -- mobile
"Whether you think you can or think you can't, you're right" -- Henry Ford
- Help getting modbus module started Christian Pauly via Tech-talk
- Re: Help getting modbus module started Pierrick M Hanlet via Tech-talk
Re: Help getting modbus module started Christian Pauly via Tech-talk
<2023>
Re: Help getting modbus module started Mark Rivers via Tech-talk
Cpp code not recognizing asyn parameter Marco A. Barra Montevechi Filho via Tech-talk
<2023>
