1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: Re: [EXTERNAL] AreaDetector, order of DetectorState_RBV and AcquireBusy
To: "Eckert, Sebastian" <[email protected]>, "Pearson, Matthew" <[email protected]>, "[email protected]" <[email protected]>
Cc: "Rossa, Lutz" <[email protected]>
Date: Tue, 28 Feb 2023 15:06:57 +0000
Hi Sebastian,
I have pushed a new version to the wait_done branch.  Rather than relying on the statusTask to poll for the camera status, it is now done directly at the end of the dataTask.  Please try this version.
Let's also take this conversation to the Github issue: https://github.com/areaDetector/ADAndor/issues/54
Sent: Tuesday, February 28, 2023 8:43 AM
To: Eckert, Sebastian <[email protected]>; Pearson, Matthew <[email protected]>; [email protected] <[email protected]>
Cc: Rossa, Lutz <[email protected]>
> The while loop Mark added runs for infinite time. ADStatus is not updated in the section.
I just realized why that is happening.  That thread has the mutex locked, so the status thread cannot run.
The loop I added has an epicsThreadSleep().  You need to change that to:
    unlock();
    epicsThreadSleep(0.01);
    lock();
Sent: Tuesday, February 28, 2023 8:40 AM
To: Mark Rivers <[email protected]>; Pearson, Matthew <[email protected]>; [email protected] <[email protected]>
Subject: AW: [EXTERNAL] AreaDetector, order of DetectorState_RBV and AcquireBusy
Dear Mark and Matt,
Thanks for he prompt help!
We therefore tried to move the callParamCallbacks(); line before the loop without success.
The next idea was
this->unlock();  ...  this->lock();
before and after the while loop, which allows exiting the loop.
The problem with the wrong order of state changes still persists, though.
Also waiting for ADStatusIdle (instead of != ADStatusAcquire) does not help.
We then tried to implement an option to wait for the camera once a trigger was received in the writeInt32 function:
if(value){
        epicsTimeStamp startTime, nowTime;
        epicsTimeGetCurrent(&startTime);
        while (adstatus != ADStatusIdle){
           epicsThreadSleep(0.02);
           getIntegerParam(ADStatus, &adstatus);
           if (adstatus == ADStatusIdle) break;
           epicsTimeGetCurrent(&nowTime);
           if (epicsTimeDiffInSeconds(&nowTime, &startTime) > 10.) break;
This also does not seem to help, as the camera stays in AcquireBusy = 0 and DetectorState_RBV = 1 for the waiting time and then inverts being stuck in the same error state.
Our feeling is that the dataTask thread blocks the camera so that the DetectorState_RBV is not updated in time. Do you have any other idea what we could try?
Best
Sebastian
Von: Mark Rivers <[email protected]>
Gesendet: Freitag, 24. Februar 2023 23:15:11
An: Pearson, Matthew; Eckert, Sebastian; [email protected]
Betreff: RE: [EXTERNAL] AreaDetector, order of DetectorState_RBV and AcquireBusy
Sebastian,
I have created a Github issue https://github.com/areaDetector/ADAndor/issues/54 and a new branch that I think should fix the problem https://github.com/areaDetector/ADAndor/tree/wait_done
Please try the new branch to see if it fixes the problem.  I noticed there was an existing PR for this problem. https://github.com/areaDetector/ADAndor/pull/45
However, I think my solution is simpler and more robust, because that PR does not handle the case where the detector returns an error.
-----Original Message-----
From: Tech-talk <[email protected]> On Behalf Of Pearson, Matthew via Tech-talk
Sent: Friday, February 24, 2023 11:22 AM
To: Sebastian Eckert <[email protected]>; [email protected]
Subject: RE: [EXTERNAL] AreaDetector, order of DetectorState_RBV and AcquireBusy
In that driver the DetectorState_RBV is updated via a function called statusTask that runs in its own thread. It monitors the detector state (using the Andor SDK function GetStatus) and the sensor temperature sensors and cooling system. The image readout is done in a different thread using a function called dataTask, which also updates the ADAcquire parameter, which controls the callback and the state of the AcquireBusy record.
So I think it's possible that the acquisition has finished (and all the plugins have completed execution), and then AcquireBusy is set back to 0, but the DetectorState_RBV is still 1 either because statusTask has not run yet or the detector really is still busy for a few milliseconds after the image readout has been completed.
If I look at the Andor SDK user manual I see this in the section for the SDK function GetStatus:
This function will return the current status of the Andor SDK system. This function should be called before an acquisition is started to ensure that it is IDLE and during an acquisition to monitor the process
which implies that we can't start a new acquisition until GetStatus reports Idle.
I can't remember now if I've tested sequences of ADAcquire commands with no delay in between them. However, the driver does check the ADStatus parameter (obtained from the SDK GetStatus, and which also corresponds to DetectorState_RBV) before allowing a new acquisition to start. In this case, if ADStatus is still reporting busy, it doesn't start an acquisition and it also doesn't set the ADAcquire back to zero, so the AcquireBusy record gets stuck in busy state.
As an interim solution, a short delay between image acquisitions will help fix this problem, or also monitor the DetectorState_RBV value as you mentioned.
Perhaps the driver should not complete image acquisition by setting ADAcquire back to 0 until the detector state also reports Idle.
Cheers,
Matt
From: Tech-talk <[email protected]> On Behalf Of Sebastian Eckert via Tech-talk
Sent: Friday, February 24, 2023 6:50 AM
To: [email protected]
Subject: [EXTERNAL] AreaDetector, order of DetectorState_RBV and AcquireBusy
we are using AreaDetector with an Andor IKON usb 2.0 camera. Acquisitions are triggered with a monitor on the AcquireBusy field and wait for plugins enabled which should guarantee that the camera and all connected routines are done before a new acquisition is triggered (the only active plugins are image and the HDF5). Frequently we have cases where AcquireBusy has returned already to zero after an acquisition, while the DetectorState_RBV is still 1. This condition is present for roughly 10ms.
In these cases a new trigger sets AcquireBusy to 1 while DetectorState_RBV eventually goes to zero after the completed (previous) acquisition. A fresh camera image is not taken and AcquireBusy stays 1 until aborted manually.
As a workaround, we can also monitor DetectorState_RBV to guarantee it is 0 before triggering a new acquisition.
Is this behavior expected, or should the scenario AcquireBusy=0 and DetectorState_RBV=1 not be possible?
Best
Sebastian
Aufsichtsrat: Vorsitzender Dr. Volkmar Dietz, stv. Vorsitzende Dr. Jutta Koch-Unterseher
Geschäftsführung: Prof. Dr. Bernd Rech, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
14109 Berlin
Deutschland
Diese E-Mail kann vertrauliche und/oder rechtlich geschützte Informationen enthalten. Wenn Sie diese E-Mail irrtümlich erhalten haben, informieren Sie bitte sofort den*die Absender*in und vernichten Sie diese Mail. Das unerlaubte Kopieren, die Veröffentlichung sowie die unbefugte Weitergabe dieser Mail ist nicht gestattet.
This email may contain confidential and/or proprietary information. If you have received this e-mail in error, please inform the sender immediately and destroy this e-mail. Unauthorized copying, publishing or distribution of this e-mail is not permitted.
AreaDetector, order of DetectorState_RBV and AcquireBusy Sebastian Eckert via Tech-talk
RE: [EXTERNAL] AreaDetector, order of DetectorState_RBV and AcquireBusy Pearson, Matthew via Tech-talk
RE: [EXTERNAL] AreaDetector, order of DetectorState_RBV and AcquireBusy Mark Rivers via Tech-talk
AW: [EXTERNAL] AreaDetector, order of DetectorState_RBV and AcquireBusy Eckert, Sebastian via Tech-talk
Re: [EXTERNAL] AreaDetector, order of DetectorState_RBV and AcquireBusy Mark Rivers via Tech-talk
Prev: Re: [EXTERNAL] AreaDetector, order of DetectorState_RBV and AcquireBusy Mark Rivers via Tech-talk
Next: Re: Archiver appliance sampling buffer overflows after migration from Version 2018 to Version 1.1.0 Wang, Lin via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Next: Periodic scan Issue with PV record scan type as IO Intr Arnab Dasgupta via Tech-talk
