1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
Subject: Re: areadetector on windows, xml2
From: Mark Rivers via Tech-talk <tech-talk at aps.anl.gov>
To: William Kirstaedter <kirstaedter at fhi-berlin.mpg.de>
Cc: tech-talk <tech-talk at aps.anl.gov>
Date: Thu, 9 Mar 2023 16:44:29 +0000
Please send the complete output when you type the following commands in xml2Src
make clean
make
Sent from my iPhone
On Mar 9, 2023, at 10:38 AM, William Kirstaedter <kirstaedter at fhi-berlin.mpg.de> wrote:
Hi Mark,
  • Is XML2_EXTERNAL defined to be NO in areaDetector/configure/CONFIG_SITE.local?
I haven't configured CONFIG_SITE.local at all - NO seems to be the default. (?)
  • Just before you get that error do you see xml2.lib being built?  Does it exist in the ADSupport/lib/windows-x64 directory?
no, and no.
thanks for helping :)
William Kirstaedter (PP&B) Fritz-Haber-Institut der MPG
Faradayweg 4-6 14195 Berlin
Tel: 030 8413 5405 Mail: kirstaedter at fhi-berlin.mpg.de
Am 07.03.2023 um 13:43 schrieb Mark Rivers:
Re: areadetector on windows, xml2 William Kirstaedter via Tech-talk
Re: areadetector on windows, xml2 Mark Rivers via Tech-talk
Prev: Re: areadetector on windows, xml2 William Kirstaedter via Tech-talk
Next: Re: areadetector on windows, xml2 William Kirstaedter via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
ANJ, 09 Mar 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
