sorry, here it is: C:\EPICS\epics-support\areaDetector\ADSupport\supportApp\xml2Src>make clean
perl -CSD -MExtUtils::Command -e rm_rf O.windows-x64 O.Common
perl -CSD C:/EPICS/epics-base/bin/windows-x64/makeMakefile.pl O.windows-x64 ../../..
perl -CSD -MExtUtils::Command -e mkpath O.Common
make -C O.windows-x64 -f ../Makefile TOP=../../.. \
T_A=windows-x64 install
make[1]: Entering directory 'C:/EPICS/epics-support/areaDetector/ADSupport/supportApp/xml2Src/O.windows-x64'
perl -CSD C:/EPICS/epics-base/bin/windows-x64/mkmf.pl -m nanohttp_stream.d -I. -I../O.Common -I. -I. -I../os/WIN32 -I..
/os/default -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -IC:/EPICS/epics-s
upport/ipac/include -IC:/EPICS/epics-support/sscan/include -IC:/EPICS/epics-support/seq-2.2.8/include -IC:/EPICS/e
pics-support/calc/include -IC:/EPICS/epics-support/autosave/include/os/WIN32 -IC:/EPICS/epics-support/autosave/include
-IC:/EPICS/epics-support/busy/include -IC:/EPICS/epics-support/asyn/include -IC:/EPICS/epics-support/motor/incl
ude -IC:/EPICS/epics-support/modbus/include -IC:/EPICS/epics-support/devlib2/include -IC:/EPICS/epics-support/Stre
amDevice/include -IC:/EPICS/epics-base/include/compiler/msvc -IC:/EPICS/epics-base/include/os/WIN32 -IC:/EPICS/epi
cs-base/include nanohttp_stream.obj ../nanohttp_stream.c
"Installing generic include file ../../../include/nanohttp_stream.h"
mkdir ../../../include
cl -nologo -FC -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3
-DPIC -DNOLIBTOOL -DWIN32 -MD -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I../os/WIN32 -I../o
s/default -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -IC:/EPICS/epics-sup
port/ipac/include -IC:/EPICS/epics-support/sscan/include -IC:/EPICS/epics-support/seq-2.2.8/include -IC:/EPICS/epi
-IC:/EPICS/epics-support/busy/include -IC:/EPICS/epics-support/asyn/include -IC:/EPICS/epics-support/motor/includ
e -IC:/EPICS/epics-support/modbus/include -IC:/EPICS/epics-support/devlib2/include -IC:/EPICS/epics-support/Stream
Device/include -IC:/EPICS/epics-base/include/compiler/msvc -IC:/EPICS/epics-base/include/os/WIN32 -IC:/EPICS/epics
-base/include -c ../nanohttp_stream.c
nanohttp_stream.c
C:\EPICS\epics-support\areaDetector\ADSupport\supportApp\xml2Src\nanohttp_stream.c(203): warning C4244: "Funktion": Konv
ertierung von "SOCKET" in "int", möglicher Datenverlust
C:\EPICS\epics-support\areaDetector\ADSupport\supportApp\xml2Src\nanohttp_stream.c(319): warning C4267: "=": Konvertieru
ng von "size_t" nach "int", Datenverlust möglich
C:\EPICS\epics-support\areaDetector\ADSupport\supportApp\xml2Src\nanohttp_stream.c(509): warning C4244: "Funktion": Konv
C:\EPICS\epics-support\areaDetector\ADSupport\supportApp\xml2Src\nanohttp_stream.c(551): warning C4244: "return": Konver
tierung von "__int64" in "int", möglicher Datenverlust
C:\EPICS\epics-support\areaDetector\ADSupport\supportApp\xml2Src\nanohttp_stream.c(611): warning C4267: "Initialisierung
": Konvertierung von "size_t" nach "int", Datenverlust möglich
C:\EPICS\epics-support\areaDetector\ADSupport\supportApp\xml2Src\nanohttp_stream.c(612): warning C4267: "Initialisierung
": Konvertierung von "size_t" nach "const int", Datenverlust möglich
C:\EPICS\epics-support\areaDetector\ADSupport\supportApp\xml2Src\nanohttp_stream.c(630): warning C4267: "Initialisierung
C:\EPICS\epics-support\areaDetector\ADSupport\supportApp\xml2Src\nanohttp_stream.c(725): warning C4267: "=": Konvertieru
C:\EPICS\epics-support\areaDetector\ADSupport\supportApp\xml2Src\nanohttp_stream.c(851): warning C4244: "Funktion": Konv
C:\EPICS\epics-support\areaDetector\ADSupport\supportApp\xml2Src\nanohttp_stream.c(772): warning C4244: "Initialisierung
": Konvertierung von "__int64" in "int", möglicher Datenverlust
C:\EPICS\epics-support\areaDetector\ADSupport\supportApp\xml2Src\nanohttp_stream.c(781): warning C4244: "Initialisierung
C:\EPICS\epics-support\areaDetector\ADSupport\supportApp\xml2Src\nanohttp_stream.c(782): warning C4244: "Initialisierung
C:\EPICS\epics-support\areaDetector\ADSupport\supportApp\xml2Src\nanohttp_stream.c(783): warning C4244: "Initialisierung
C:\EPICS\epics-support\areaDetector\ADSupport\supportApp\xml2Src\nanohttp_stream.c(971): warning C4244: "Funktion": Konv
C:\EPICS\epics-support\areaDetector\ADSupport\supportApp\xml2Src\nanohttp_stream.c(998): warning C4244: "Funktion": Konv
C:\EPICS\epics-support\areaDetector\ADSupport\supportApp\xml2Src\nanohttp_stream.c(1013): warning C4244: "Funktion": Kon
C:\EPICS\epics-support\areaDetector\ADSupport\supportApp\xml2Src\nanohttp_stream.c(1023): warning C4244: "Funktion": Kon
C:\EPICS\epics-support\areaDetector\ADSupport\supportApp\xml2Src\nanohttp_stream.c(1199): warning C4244: "Funktion": Kon
vertierung von "SOCKET" in "int", möglicher Datenverlust
C:\EPICS\epics-support\areaDetector\ADSupport\supportApp\xml2Src\nanohttp_stream.c(1288): warning C4101: "i": Unreferenz
ierte lokale Variable
C:\EPICS\epics-support\areaDetector\ADSupport\supportApp\xml2Src\nanohttp_stream.c(1285): warning C4101: "ia6": Unrefere
nzierte lokale Variable
C:\EPICS\epics-support\areaDetector\ADSupport\supportApp\xml2Src\nanohttp_stream.c(1281): warning C4101: "ia": Unreferen
C:\EPICS\epics-support\areaDetector\ADSupport\supportApp\xml2Src\nanohttp_stream.c(1279): warning C4101: "h": Unreferenz
C:\EPICS\epics-support\areaDetector\ADSupport\supportApp\xml2Src\nanohttp_stream.c(1635): warning C4267: "=": Konvertier
C:\EPICS\epics-support\areaDetector\ADSupport\supportApp\xml2Src\nanohttp_stream.c(1639): warning C4267: "=": Konvertier
C:\EPICS\epics-support\areaDetector\ADSupport\supportApp\xml2Src\nanohttp_stream.c(1655): warning C4267: "+=": Konvertie
C:\EPICS\epics-support\areaDetector\ADSupport\supportApp\xml2Src\nanohttp_stream.c(1658): warning C4267: "+=": Konvertie
C:\EPICS\epics-support\areaDetector\ADSupport\supportApp\xml2Src\nanohttp_stream.c(1661): warning C4267: "+=": Konvertie
C:\EPICS\epics-support\areaDetector\ADSupport\supportApp\xml2Src\nanohttp_stream.c(1662): warning C4267: "+=": Konvertie
C:\EPICS\epics-support\areaDetector\ADSupport\supportApp\xml2Src\nanohttp_stream.c(1731): warning C4267: "=": Konvertier
C:\EPICS\epics-support\areaDetector\ADSupport\supportApp\xml2Src\nanohttp_stream.c(2082): warning C4244: "=": Konvertier
link -nologo -subsystem:windows -dll -LTCG -incremental:no -opt:ref -release -MACHINE:X64 -out:nanohttp_stream.dll
-implib:nanohttp_stream.lib nanohttp_stream.obj xml2.lib ws2_32.lib
LINK : fatal error LNK1181: Eingabedatei "xml2.lib" kann nicht geöffnet werden.
make[1]: *** [C:/EPICS/epics-base/configure/RULES_BUILD:316: nanohttp_stream.dll] Error 1181
make[1]: Leaving directory 'C:/EPICS/epics-support/areaDetector/ADSupport/supportApp/xml2Src/O.windows-x64'
make: *** [C:/EPICS/epics-base/configure/RULES_ARCHS:58: install.windows-x64] Error 2
different machine, but should not matter. installation is equal. I should also mention: I always install an epics-support directory along the epics-base,
so its located at C:\EPICS\epics-support thanks again!
Am 09.03.2023 um 17:44 schrieb Mark
Rivers:
Please send the complete output when you type the following commands in xml2Src Attachment:
smime.p7s
ANJ, 09 Mar 2023 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
