1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: Re: More precise timing for record processing
From: "Sobhani, Alex via Tech-talk" <[email protected]>
To: "Arnold, Ned D." <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 30 May 2023 16:35:57 +0000
Thanks.
But I would have thought there is some kind of record type that is specific for periodic timing, because it seems to me like there are some problems that apply to a "clock" are not as important to a sequencer that is meant to be run on-command.
For example, with no central unification of the "pulses" I believe these records will probably just have as accurate of a relative time-delta as possible. But what about cases where the absolute time is more important? If a pulse takes too long to trigger, then will the subsequent pulse be shorter? Also how would the user start/stop these?
Alex
Sent: Tuesday, May 30, 2023 9:45 AM
To: [email protected] <[email protected]>; Sobhani, Alex <[email protected]>
Subject: [EXTERNAL] Re: More precise timing for record processing
Alex -
You can use the delay field in a sequence record to create specific scan frequencies ... like that shown below. Change TestRecord1.DLY1 to the period you want it to scan.  If multiple records need to be processed at this rate, TestRecord2 could become an event record that posts a soft event which causes other records to scan.
   Ned
record(seq,TestRecord1) {
    field(PINI,"1")
    field(DLY1,"3")
    field(LNK1,"TestRecord2.PROC CP NMS")
    field(LNK2,"TestRecord1 CP NMS")
record(calcout,"TestRecord2") {
        field(INPA,"TestRecord2.VAL NPP NMS")
        field(CALC,"A+1")
From: Tech-talk <[email protected]> on behalf of Sobhani, Alex via Tech-talk <[email protected]>
Sent: Sunday, May 28, 2023 08:35 PM
Subject: More precise timing for record processing
The SCAN field lets you choose from .1, .2, .5, 1, 2, 5, or 10 seconds. In cases where this is not enough, is there a simple way to make a record process at other intervals such as 2.7 seconds or 5.4 seconds, specified at runtime? I know you can add options for more periods of the SCAN field by editing dbd files, but you cannot change your mind at runtime.
I envision something like this:
record(timer, “BL0:mytimer”){
                field(PERI, 2.7)
                field(FLNK, “BL0:mytrigger”)
And then subfields to enable/disable it.
Does anything like this exist? I would imagine that something like this would be very generally useful.
Alex
Re: More precise timing for record processing Ralph Lange via Tech-talk
More precise timing for record processing Sobhani, Alex via Tech-talk
Re: More precise timing for record processing Arnold, Ned D. via Tech-talk
Prev: Re: Issues with epics module and ISEG HAL service libraries André Hartmann via Tech-talk
Next: Re: More precise timing for record processing Ralph Lange via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Prev: Re: More precise timing for record processing Arnold, Ned D. via Tech-talk
