Another option:
Look at the EVENT scanning mechanism. You can set as many records as you want to process when specific (you choose the names) IOC-wide "soft" events are happening. Such events can be generated by calling a routine in EPICS Base. If you create a thread, implementing your dream of a fancy delay mechanism, it can just generate that soft event - and all the records you configured to listen to that event will be processed. The easiest and most flexible way to create such a facility would be writing a device support based on the asynPortDriver C++ class. In that case, start/stop, configuring the event name and period/frequency, statistics etc. can all happen transparently through device support, at run time. With such an implementation, adding an additional flexible scan period boils down to one more line in a substitutions file. Cheers, ~Ralph
| ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
