Thank you very much for your help! I have downloaded the current version of phoebus by going to the URL and copying the https in the get code button: I first run the check: mvn clean verify -f dependencies/pom.xml And this works The build fails when using mvn clean install It appears to fail on some maving plugin. I am using jkd 20.0.2 and maven 3.9.3. I will try to use the -DskipTests for the clean install The errors I get are (it is long): [INFO] [INFO] Results: [INFO] [ERROR] Failures: [ERROR] ServerClientTest.testSinglePV:259 [ERROR] ServerClientTest.testSinglePV:259 [ERROR] ServerClientTest.testSinglePV:259 [ERROR] ServerClientTest.testSinglePV:259 [ERROR] ServerClientTest.testSinglePV:259 [ERROR] ServerClientTest.testSinglePV:259 [ERROR] ServerClientTest.testSinglePV:259 [ERROR] ServerClientTest.testSinglePV:259 [ERROR] ServerClientTest.testSinglePV:259 [ERROR] ServerClientTest.testSinglePV:259 [ERROR] ServerClientTest.testSinglePV:259 [ERROR] ServerClientTest.testSinglePV:259 [INFO] [ERROR] Tests run: 63, Failures: 12, Errors: 0, Skipped: 0 [INFO] [INFO] ------------------------------------------------------------------------ [INFO] Reactor Summary for phoebus (parent) 4.7.3-SNAPSHOT: [INFO] [INFO] phoebus (parent) ................................... SUCCESS [ 0.720 s] [INFO] dependencies ....................................... SUCCESS [ 0.024 s] [INFO] install-jars ....................................... SUCCESS [ 1.351 s] [INFO] phoebus-target ..................................... SUCCESS [ 2.541 s] [INFO] core ............................................... SUCCESS [ 0.023 s] [INFO] core-vtype ......................................... SUCCESS [ 5.098 s] [INFO] core-formula ....................................... SUCCESS [ 6.524 s] [INFO] core-framework ..................................... SUCCESS [ 27.566 s] [INFO] core-types ......................................... SUCCESS [ 1.141 s] [INFO] core-util .......................................... SUCCESS [ 6.069 s] [INFO] core-pva ........................................... FAILURE [02:12 min] [INFO] core-pv ............................................ SKIPPED [INFO] core-security ...................................... SKIPPED [INFO] core-ui ............................................ SKIPPED [INFO] core-logbook ....................................... SKIPPED [INFO] core-email ......................................... SKIPPED [INFO] core-launcher ...................................... SKIPPED [INFO] app ................................................ SKIPPED [INFO] app-diag ........................................... SKIPPED [INFO] app-log-configuration .............................. SKIPPED [INFO] app-probe .......................................... SKIPPED [INFO] app-pvtable ........................................ SKIPPED [INFO] app-pvtree ......................................... SKIPPED [INFO] app-update ......................................... SKIPPED [INFO] app-email .......................................... SKIPPED [INFO] app-email-ui ....................................... SKIPPED [INFO] app-errlog ......................................... SKIPPED [INFO] app-filebrowser .................................... SKIPPED [INFO] app-logbook ........................................ SKIPPED [INFO] app-logbook-inmemory ............................... SKIPPED [INFO] app-logbook-ui ..................................... SKIPPED [INFO] app-logbook-olog ................................... SKIPPED [INFO] app-logbook-olog-client ............................ SKIPPED [INFO] app-logbook-olog-client-es ......................... SKIPPED [INFO] app-logbook-olog-ui ................................ SKIPPED [INFO] app-logbook-elog ................................... SKIPPED [INFO] app-rtplot ......................................... SKIPPED [INFO] app-databrowser .................................... SKIPPED [INFO] app-databrowser-timescale .......................... SKIPPED [INFO] app-display ........................................ SKIPPED [INFO] app-display-model .................................. SKIPPED [INFO] app-display-representation ......................... SKIPPED [INFO] app-3d-viewer ...................................... SKIPPED [INFO] app-display-representation-javafx .................. SKIPPED [INFO] app-display-fonts .................................. SKIPPED [INFO] app-display-runtime ................................ SKIPPED [INFO] app-display-editor ................................. SKIPPED [INFO] app-display-convert-medm ........................... SKIPPED [INFO] app-display-convert-edm ............................ SKIPPED [INFO] app-display-navigation ............................. SKIPPED [INFO] app-display-adapters ............................... SKIPPED [INFO] app-display-thumbwheel ............................. SKIPPED [INFO] app-display-linearmeter ............................ SKIPPED [INFO] app-alarm .......................................... SKIPPED [INFO] app-alarm-model .................................... SKIPPED [INFO] app-alarm-ui ....................................... SKIPPED [INFO] app-alarm-logging-ui ............................... SKIPPED [INFO] app-alarm-datasouce ................................ SKIPPED [INFO] app-scan ........................................... SKIPPED [INFO] app-scan-model ..................................... SKIPPED [INFO] app-scan-client .................................... SKIPPED [INFO] app-scan-ui ........................................ SKIPPED [INFO] app-channel ........................................ SKIPPED [INFO] app-channel-channelfinder .......................... SKIPPED [INFO] app-channel-utility ................................ SKIPPED [INFO] app-channel-views .................................. SKIPPED [INFO] app-perfmon ........................................ SKIPPED [INFO] app-pace ........................................... SKIPPED [INFO] app-save-and-restore ............................... SKIPPED [INFO] save-and-restore-model ............................. SKIPPED [INFO] save-and-restore-common ............................ SKIPPED [INFO] save-and-restore-service ........................... SKIPPED [INFO] save-and-restore ................................... SKIPPED [INFO] save-and-restore-logging ........................... SKIPPED [INFO] app-console ........................................ SKIPPED [INFO] app-trends ......................................... SKIPPED [INFO] app-trends-rich-adapters ........................... SKIPPED [INFO] app-trends-simple-adapters ......................... SKIPPED [INFO] app-utility ........................................ SKIPPED [INFO] app-utility-preference-manager ..................... SKIPPED [INFO] app-imageviewer .................................... SKIPPED [INFO] app-credentials-management ......................... SKIPPED [INFO] app-eslog .......................................... SKIPPED [INFO] product ............................................ SKIPPED [INFO] services ........................................... SKIPPED [INFO] service-alarm-server ............................... SKIPPED [INFO] service-archive-engine ............................. SKIPPED [INFO] service-scan-server ................................ SKIPPED [INFO] service-alarm-logger ............................... SKIPPED [INFO] service-alarm-config-logger ........................ SKIPPED [INFO] service-save-and-restore ........................... SKIPPED [INFO] ------------------------------------------------------------------------ [INFO] BUILD FAILURE [INFO] ------------------------------------------------------------------------ [INFO] Total time: 03:04 min [INFO] Finished at: 2023-07-27T10:32:54-05:00 [INFO] ------------------------------------------------------------------------ [ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:3.0.0-M7:test (default-test) on project core-pva: There are test failures. [ERROR] [ERROR] Please refer to /home/jenkins/Mu2e/Online/online2023Jul26/phoebus/core/pva/target/surefire-reports for the individual test results. [ERROR] Please refer to dump files (if any exist) [date].dump, [date]-jvmRun[N].dump and [date].dumpstream. [ERROR] -> [Help 1] [ERROR] [ERROR] To see the full stack trace of the errors, re-run Maven with the -e switch. [ERROR] Re-run Maven using the -X switch to enable full debug logging. [ERROR] [ERROR] For more information about the errors and possible solutions, please read the following articles: [ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MojoFailureException [ERROR] [ERROR] After correcting the problems, you can resume the build with the command [ERROR] mvn <args> -rf :core-pva [jenkins@pegasus phoebus]$ T Thanks, Merrill Jenkins On 7/27/23 10:10, Kasemir, Kay wrote:
-- +++++++++++++++++++++++++ Merrill Jenkins Professor of Physics ==== Mailing Address ==== Physics 411 University Blvd. N. MSPB RM 115 Mobile, AL 36688 phone 251.414.8013 Dept: 251.460.6224
ANJ, 27 Jul 2023 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
