1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024
Subject: Re: [EXTERNAL] Re: Best Site to Download Latest Version of Phoebus
From: "Kasemir, Kay via Tech-talk" <tech-talk at aps.anl.gov>
To: Charles Merrill Jenkins <mjenkins at southalabama.edu>, Phoebus Tech Talk <tech-talk at aps.anl.gov>
Date: Thu, 27 Jul 2023 15:48:50 +0000
Hi:
> The build fails when using
> mvn clean install
> … [ERROR]   ServerClientTest.testSinglePV:259
>…[ERROR] To see the full stack trace of the errors, re-run Maven with the -e switch.
So it fails a unit test. That’s somewhat interesting, in principle the tests should pass, and they do for the automatic build on github. The issue could be related to bad luck for tests that depend on timing, or maybe it’s related to localization, some text looks different.
> I will try to use the -DskipTests for the clean install
Right, first build without the tests. Once that succeeds, you can try to debug the test failure, but that would be a second, optional step.
>  I am using jkd 20.0.2 and maven 3.9.3.
The JDK version could be a factor in the test result, but to know more we’d have to get the complete stack trace of the test failure.
Re: [EXTERNAL] Re: Best Site to Download Latest Version of Phoebus Tynan Ford via Tech-talk
Best Site to Download Latest Version of Phoebus Charles Jenkins via Tech-talk
Re: Best Site to Download Latest Version of Phoebus Charles Merrill Jenkins via Tech-talk
Re: [EXTERNAL] Re: Best Site to Download Latest Version of Phoebus Kasemir, Kay via Tech-talk
Re: [EXTERNAL] Re: Best Site to Download Latest Version of Phoebus Charles Merrill Jenkins via Tech-talk
Prev: Re: [EXTERNAL] Re: Best Site to Download Latest Version of Phoebus Charles Merrill Jenkins via Tech-talk
Next: Re: [EXTERNAL] Re: Best Site to Download Latest Version of Phoebus Tynan Ford via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024
ANJ, 27 Jul 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
