1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024
Subject: RE: fanout is not working
From: Mark Rivers via Tech-talk <tech-talk at aps.anl.gov>
To: "Tran, Phi Dung" <ptran1 at bnl.gov>, "Pearson, Matthew" <pearsonmr at ornl.gov>, "Goetze, Kurt A." <goetze at anl.gov>
Cc: Tech-talk <tech-talk at aps.anl.gov>
Date: Wed, 1 Nov 2023 19:03:07 +0000
  • I received the following message in EPICS: "CA client library is unable to contact CA repeater after 50 tries." I believe this issue is the root of my problem, as I am attempting to create a different virtual IOC to control motors located in another existing IOC.
That is not your problem.  CA repeater is needed only to see beacon messages when an IOC restarts, etc.  I makes your client reconnect quicker under those circumstances, but is not required for normal function.
From: Tech-talk <tech-talk-bounces at aps.anl.gov> On Behalf Of Tran, Phi Dung via Tech-talk
Sent: Wednesday, November 1, 2023 1:49 PM
To: Pearson, Matthew <pearsonmr at ornl.gov>; Goetze, Kurt A. <goetze at anl.gov>
Subject: Re: fanout is not working
Hi Matt,
After implementing the changes you suggested and it is still not working.   I received the following message in EPICS: "CA client library is unable to contact CA repeater after 50 tries." I believe this issue is the root of my problem, as I am attempting to create a different virtual IOC to control motors located in another existing IOC.  Should I just add your suggestions into the existing ioc so it does not need to search globally for the motor PV.
Please advice
Phi
Sent: Wednesday, November 1, 2023 10:40 AM
To: Tran, Phi Dung <ptran1 at bnl.gov>; Goetze, Kurt A. <goetze at anl.gov>
Hi Phi,
I changed TWV to REL and used caput to test each motor separately since I want to make relative motions.
I’m not sure I understand that. TWV is a number (the relative distance to move).
I just added DOL into my fanout field but it did not work either.
Using the DOL field also requires setting the OMSL to “closed_loop”.
If you want to move all 3 motors the same relative distance, the way I’d do this is something like:
record(ao, “relative_dist”) {
  field(OUT, “relative_dist_fanout PP”)
record(dfanout, “relative_dist_fanout) {
  field(OUTA, “motor1.TWV”)
  field(OUTB, “motor2.TWV”)
  field(OUTC, “motor3.TWV”)
  field(FLNK, “relative_dist_go”)
record(dfanout, “relative_dist_go”) {
  field(VAL, “1”)
  field(OUTA, “motor1.TWF PP”)
  field(OUTB, “motor2.TWF PP”)
  field(OUTC, “motor3.TWF PP”)
Cheers,
Matt
Sent: Wednesday, November 1, 2023 9:59 AM
To: Goetze, Kurt A. <
goetze at anl.gov>; Tran, Phi Dung <ptran1 at bnl.gov>
Cc: Tech-talk <
Are you sure writing the position to $(M).TWF actually works with caput? Normally TWF (and TWR) just accept a ‘1’ to initiate a relative move specified by the distance in TWV. If the 3 motors are moving, they may just be moving a TWV relative distance.
What you may want is this instead?
record(dfanout, "$(P)-F") {
    field(DESC, "move ib,ob,ds MTR")
    field(OUTA, "$(OUTBOARDMTR) PP MS")
    field(OUTB, "$(INBOARDMTR) PP MS")
    field(OUTC, "$(DOWNSTREAMMTR) PP MS")
Cheers,
Matt
From: Tech-talk <tech-talk-bounces at aps.anl.gov> On Behalf Of Goetze, Kurt via Tech-talk
Sent: Tuesday, October 31, 2023 1:48 PM
Subject: [EXTERNAL] RE: fanout is not working
Hi Phi,
You’re close, but I don’t think you can poke the motor record’s value into the dfanout that way.
One way you could do it is by processing the motor record, FLNK the motor record to the dfanout, and have the dfanout’s .DOL field set to the motor record’s .VAL field (NPP).  That may not be the exact solution but that’s the direction I would head.
Kurt
Sent: Tuesday, October 31, 2023 11:31 AM
To: tech-talk at aps.anl.gov
Subject: fanout is not working
I have created a virtual motor and can successfully use the `caput` and `caget` commands to set and read its value, respectively. However, my `dfanout` record is not moving the motors with relative motions as expected. I have confirmed that the motors respond correctly when I use `caput` to directly interact with the fields in `dfanout`.
record(motor, "$(P)"){
      field(DTYP, "Soft Channel")
      field(DESC, "Move Y,ib,ob,ds mtrs")
      # Where to write the setpoint to
      # Output to upstream, inboard and outboard motors
      field(OUT, "$(P)-F PP MS")
      field(PREC,"7")
#Move Y motors ib,ob,ds in same direction
    field(OUTA, "$(OUTBOARDMTR).TWF PP MS")
    field(OUTB, "$(INBOARDMTR).TWF PP MS")
    field(OUTC, "$(DOWNSTREAMMTR).TWF PP MS")
    field(PREC, "7")
Please advice.
Thank you,
Phi
RE: fanout is not working Pearson, Matthew via Tech-talk
fanout is not working Tran, Phi Dung via Tech-talk
RE: fanout is not working Goetze, Kurt via Tech-talk
Re: fanout is not working Tran, Phi Dung via Tech-talk
Prev: Re: fanout is not working Tran, Phi Dung via Tech-talk
Next: RE: fanout is not working Pearson, Matthew via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024
ANJ, 01 Nov 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
