1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024
Subject: Re: Simulated limit switches on motorSim motor
From: Kevin Peterson via Tech-talk <tech-talk at aps.anl.gov>
To: "Nariyoshi, Pedro" <nariyosh at frib.msu.edu>, "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Tue, 28 Nov 2023 10:04:16 -0600
There isn't a field that allows setting the hardware switch state based on a linked PV. You can, however, set the soft limits of the soft motor so that the hardware limits of the real motors are never activated.
Kevin
On 11/28/23 09:36, Nariyoshi, Pedro wrote:
Hi Kevin,
I figured I could try to remove the SPC_NOMOD from the dbd (and a bo/calcout record to write to it), but it feels too hackish. What I was really trying to figure out is if there was a field I could put a link in to set the limit switch fields (similar to RDBL/DINP/etc).
*Pedro Nariyoshi*
Software Controls Engineer
Facility for Rare Isotope Beams
Michigan State University
640 South Shaw Lane
East Lansing, MI 48824, USA
Tel. 517-908-7352
Email: nariyosh at frib.msu.edu <mailto:nariyosh at frib.msu.edu>
1633986722804
*Sent:* Tuesday, November 28, 2023 10:18:13 AM
*To:* Nariyoshi, Pedro; tech-talk at aps.anl.gov
*Subject:* Re: Simulated limit switches on motorSim motor
[EXTERNAL] This email originated from outside of FRIB
Pedro,
The HLS/LLS/RHLS/RLLS fields are read-only.
Kevin
On 11/21/23 12:24, Nariyoshi, Pedro via Tech-talk wrote:
I am working on creating virtual motors to control some slits. One problem I have is that I couldn't find a way to set the HLS/LLS/RHLS/RLLS fields. Is there a way to control these (whether having an input link to these values or a writing them directly with a calcout or bo record)?
Thank you very much
*Pedro Nariyoshi*
640 South Shaw Lane
Tel. 517-908-7352
Email: nariyosh at frib.msu.edu <mailto:nariyosh at frib.msu.edu <mailto:nariyosh at frib.msu.edu>>
1633986722804
Simulated limit switches on motorSim motor Nariyoshi, Pedro via Tech-talk
Re: Simulated limit switches on motorSim motor Kevin Peterson via Tech-talk
Re: Simulated limit switches on motorSim motor Nariyoshi, Pedro via Tech-talk
Prev: Re: "duty cycle" records Kevin Peterson via Tech-talk
Next: Re: Simulated limit switches on motorSim motor Nariyoshi, Pedro via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024
Prev: Re: Simulated limit switches on motorSim motor Nariyoshi, Pedro via Tech-talk
Next: Re: Simulated limit switches on motorSim motor Torsten Bögershausen via Tech-talk
ANJ, 29 Nov 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
